05-05-2007, 07:42 PM | #1 |
Member#: 112422
how much boost then wit hydra?
how much psi should i run on my RSTI when my hydra comes in? and how high should i go? and yes i plan or expect to built my tranny as well and not rev more that 6100 rpm etc..
again, RSTI = 2004 rs with turbo and sti short block
05-07-2007, 12:17 AM | #2 |
Member#: 113734
South East
Vehicle:2023 FL5 Type R Subaruless |
Well what kind of Turbo?
05-07-2007, 09:16 AM | #3 |
Member#: 54918
Vehicle:673 WHP Element Tuning Pro Comp Engine |
I want to say we have tuned that setup to around 17-18 psi. You don't want to take the base map and just crank it up to 18 psi and let it rip, you must start at wastegate pressure and confirm the tune is solid before slowly turning up the boost pressure.
You will be running less boost than you would see on an STi with a similar turbocharger due to the higher compression on your hybrid motor. Thanks, Phil www.elementtuning.com |
05-10-2007, 02:39 AM | #4 | |
Member#: 112422
05-10-2007, 02:40 AM | #5 |
Member#: 112422
05-11-2007, 06:18 PM | #6 |
Member#: 54918
STi shortblock with RS heads equals > compression than STi engine.
05-12-2007, 05:28 PM | #7 |
Member#: 112422
okay.. get it now..um yeah...i was just planing on just sticking with about 15psi tuned and no more..and i dont beat on my car as much as i think most people do...even my friend told me how he could never drive the way i do and barely beat on it or watever..
and again, im sure i would eventually wana go higher in boost later..you know how we get greedy.lol |
05-12-2007, 10:17 PM | #8 | |
Member#: 143414
Vehicle:2004 STi - 500hp WRB |
05-13-2007, 09:39 AM | #9 | |
Member#: 54918
The better option is to tune it conservatively so you can beat on it all you want Thanks, Phil www.elementtuning.com |
How much boost for how long? | bcmaxx | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 10-05-2007 11:06 PM |
brembo fitment question. How much biger then wrx calipers | pulser9 | Brakes, Steering & Suspension | 3 | 06-26-2007 05:34 AM |
How much boost is TOO MUCH? | skimobile | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 27 | 07-31-2005 06:44 PM |
How much boost is to much boost? | xtheviperx | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 09-16-2002 08:49 AM |
How much boost and/or hp can the EJ20 in the 2002 WRX take? | GTLee | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 04-28-2001 12:44 AM |
