Old 05-04-2007, 08:35 AM   #1
Jeremy05sti
Member#: 142040
2005 STI
HTA Twisted
Default EWG What To Get?
I'm looking for a EWG option for my 05 on my stock vf39. Does anyone have any experience with one that work pretty much bolt right up with the stock location? I'm looking to do this due to an existing Boost Creep Issue as well as to have it for a future Turbo upgrade.
Jeremy05sti is offline   Reply With Quote
Old 05-04-2007, 09:21 AM   #2
STIBungy
Member#: 51684
You can either port the hole a little bigger or get it tuned to prevent boost creep. UR, Helix and TXS have ewg uppipes for stock mount turbos.
STIBungy is offline   Reply With Quote
Old 05-04-2007, 10:22 AM   #3
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
6spd, EJ255, VF39 & EWG
No, you can't get it tuned to prevent boost creep. I don't understand how this is going on. Boost creep is a MECHANICAL ISSUE; it cannot be cured by tuning. Element Tuning and Slowboy also make EWG uppipes.
wrxfactor is offline   Reply With Quote
Old 05-04-2007, 10:30 AM   #4
neonglh
Member#: 127886
Ultimate racing seems to be the best made Uppipe for EWG. If you hold it next to any of the other ones, you will see why.
--mark
neonglh is offline   Reply With Quote
Old 05-04-2007, 10:36 AM   #5
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
P&L Motorsports also has a very nice setup they have recently released.
Tony
Old 05-04-2007, 11:58 AM   #6
Jeremy05sti
Member#: 142040
2005 STI
HTA Twisted
can someone post some links to a few of these products.....? Thanks
I am well aware that boost creep cannot be tuned out, I am also well aware that you can port the IWG however If I wanted to do that I would not have opened this thread....
Also I'm looking for some kinda package.....EWG w/UP Something probably around 500-700 is what I'm going to be looking to pay.....
Old 05-04-2007, 02:57 PM   #7
neonglh
Member#: 127886
You can meet that price range easy. People are often selling Up pipes and a Tial 38mm WG and dump tube for around the 500 range.
--mark
Old 05-05-2007, 04:17 PM   #8
Mactizen
Member#: 80779
2004 STi WRB/gold
[email protected] stock vf39
UR kit with a 38mm here, good quality made a little power. Boost control is good but i need an ebc or mbc. For some reason it's 100% smooth yet. I have leaking issues with the 2 bolt flange, but i think lots of people do.
Mactizen is offline   Reply With Quote
Old 05-05-2007, 05:04 PM   #9
FASTRPH
Member#: 23448
2008 WRX STi
Love my P&L w/ 44mm Tial! No leaks here!
FASTRPH is offline   Reply With Quote
Old 05-05-2007, 06:56 PM   #10
DigitalPunk
Member#: 124236
2006 WRX Built EJ257
Version 8 Twinscroll
is it necessary to change the dp if you get an ewg?
DigitalPunk is offline   Reply With Quote
Old 05-06-2007, 06:28 PM   #11
FASTRPH
Member#: 23448
2008 WRX STi
Not necessarily...most EWG setups clear most downpipes. Check with your vendor to be 100% sure that yours will clear w/ your setup.
Old 05-06-2007, 06:35 PM   #12
Irishman
Member#: 29933
2004 STI
Silver/Silver
I believe the only DP that doesnt' work is the TXS because of the 4" bellmouth. I have the TXS DP with the UR upipe and 38mm Tial but had to do some fabricating ( denting the crap out of the side of the DP ).
Irishman is offline   Reply With Quote
Old 05-07-2007, 01:26 AM   #13
Mactizen
Member#: 80779
2004 STi WRB/gold
stock exhuast mani? or header? any leakage at the 2 bolt flange? I had none with the stock manifold and no with a header it leaks from time to time.
sorry to hijack
Old 05-07-2007, 09:13 AM   #14
sizzflair
Member#: 94268
1995 JDM STi RA ver2
2010 Exige S240
Somehow my tuner managed to get it fixed.... because I was creeping like crazy up to 1.5 bar before tuning... then to .13-4 bar and stay there... no changes in boost until it starts to taper down... no issues... I'm guessing my car was street-tuned in the cold, he was able to adjust it. Most of the "tuning" people get is done inside on a dyno, so they wouldn't tune it to be "fixed" to the cold weather/boost creep conditions
I do live in michigan (gets cold) and do have full catless exhaust
sizzflair is offline   Reply With Quote
Old 05-07-2007, 12:06 PM   #15
Jeremy05sti
Member#: 142040
2005 STI
HTA Twisted
Thanks for all the input guys.....Weird thing is that I just installed my AP v2.0 this weekend.....(you have to just love cobb for that) Anyways I have no boost creep anymore (at least none that I can notice) and no fuel cut and I'm running a full TBE and CAI.....Car runs great and runs much smoother than it did....Anyways I still plan on going with the EWG due to this will help the Turbo upgrade down the road....Right now I'm looking at the SBR UP w/tial 38mm WG....With that said anyone have any ideas on what EWG with the HKS downpipe?????
So the time has come to get new brakes, but not sure what to get - HELP! DJS_02_WRX Newbies & FAQs 31 12-30-2009 12:53 PM
Looking to get a fishing rod this spring, what to get hmmmm! mrtrex Off-Topic 9 01-01-2009 09:10 PM
What to get? EWG or New clutch. HSBabyFace Newbies & FAQs 9 03-19-2008 12:22 PM
What to get, what to get?! akira02rex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 05-01-2007 08:42 PM
unichip - ECU - what to get/what to expect Jon Cox Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 09-12-2001 06:31 PM
