Old 05-06-2007, 12:54 AM   #1
ScoobyWag03
Member#: 136089
2003 WRX
Question If I program a 2nd key fob will the original still work??
when i bought my car it only came with one set of keys.. i want a backup keyfob for the 2nd set i had made.. if i do this will the original fob still work?? or only one fob per car?? thanks for any help!
~Paul
ScoobyWag03 is offline   Reply With Quote
Old 05-06-2007, 09:17 AM   #2
EDS
Member#: 143290
2007 SE Wagon
Obsidian Black Pearl
Check your manual for model year specific information but I know I can have up to 4 different remotes (2007).
EDS is offline   Reply With Quote
Old 05-06-2007, 09:18 AM   #3
Mechie3
Member#: 120152
My car came with 2 fobs and 3 sets of keys (1 was a valet key).
Mechie3 is offline   Reply With Quote
Old 05-06-2007, 09:19 AM   #4
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
No
You must program/reprogram all remotes at the same time.
Jamie
Old 05-06-2007, 02:55 PM   #5
ScoobyWag03
Member#: 136089
2003 WRX
Originally Posted by Subie Gal View Post
No
Jamie
ahh i see.. thanks for your help!!!
~Paul
Old 05-06-2007, 03:02 PM   #6
clemsonteg
Member#: 134610
2003 WRX
SONIC YELLOW STG 4
I was given a 2nd key fob for mine that wasnt programmed, i programmed it and it worked just fine, and my original one works as well.
These are the instructions I used to program mine
Round Remote Transmitter Programming Instructions
1. Disarm the security system (if so equipped).
2. Open the driver's door and sit in the driver's seat.
3. Close the driver's door. 4. Place the ignition key in the ignition switch and cycle the switch from "LOCK" to "ON" ten times within 15 seconds. Be sure to stop at the "LOCK" position and leave the key in the ignition when you are done. The horn will sound once to indicate that you are in transmitter programming mode.
5. You must finish the next steps within 45 seconds of the horn honking.
1. Open the driver's door.
2. Close the driver's door.
3. Press and release any button on the transmitter. The horn will sound two times to indicate that the transmitter has been programmed.
6. After programming your remote, remove the key from the ignition switch. The horn will sound three times to indicate the system is now out of programming mode. Ensure your remotes work properly at this time
You may program up to four remotes at any one time. If you lose a remote, program the other four times to clear the code for the lost remote until you can replace it. Do not program your remotes with other Subarus in the vicinity- you may be unknowingly programming someone else's remote for your vehicle!
clemsonteg is offline   Reply With Quote
programming an electronic key fob corgimas Car Audio, Video & Security 63 02-12-2014 05:15 PM
Will I save cash If I import a 2nd hand STI from the U.S into Canada? goldwave84 General Community 13 06-26-2007 06:59 AM
Will This Clutch Still Work? stimpy Transmission (AT/MT) & Driveline 5 08-14-2003 03:06 PM
will my laptop still work???? smacksube South East Region Forum 9 06-02-2003 05:03 PM
Will my spare still Work w/17"'s? WindyWRX Brakes, Steering & Suspension 6 10-17-2002 04:27 AM
