Old 05-06-2007, 11:15 PM   #1
vwjettavr67
Member#: 99192
Default TDC Tuning RR500 TUNED STI
Results are in this weekend I spent almost all day with Mike from up at TDC Tuning in NH.. Let me tell you was great experience and alot of fun..
Results:
05 sti
Helix RR500 turbo
perrin fmic
Tail BOV
perring Big Maf
740cc injectors
invidia downpipe
HKS cat back
PSI: 22 tapering to 18 at redline
HP: 320
TQ: 360 at 3700rpm
Dyno used is Dynomite dyno, though many may feel numbers are low dyno is very accurate and reads lower then the usual dynojets and mustang dynos...
The car pulls great, and is very smooth.. Im sure Mike could of pushed even more out of the car but like I said I had been there all day and the car had been through many dyno runs already and we were both happy with where the car was at for now..
I highly recommend going there for either a tune or even a dyno day which they are always holding..
vwjettavr67 is offline   Reply With Quote
Old 05-06-2007, 11:30 PM   #2
CatfaceType-R
Member#: 81102
that's some pretty insane early torque...must be fun!!! Green can't do that
CatfaceType-R is offline   Reply With Quote
Old 05-06-2007, 11:47 PM   #3
BlueFish
Member#: 50896
2006 STi
What does a stock sti put down on that dyno?
BlueFish is offline   Reply With Quote
Old 05-07-2007, 12:39 AM   #4
nhsilversti
Member#: 50895
. www.48hrs.info
donation chairman
i dont agree
http://forums.nasioc.com/forums/show...&postcount=144
btw, im not saying anything bad about tdc.
nhsilversti is offline   Reply With Quote
Old 05-07-2007, 01:15 AM   #5
BlackSTI2006
Member#: 105404
2006 FPGreenSTI SOLD
04 GMC 2500HD Duramax CC
i dunno but i just had 2 sti's dyno there that i put an open ecu tune of mine on and they put down (stage 2 setups basically, tbe,cai's and thats it) 20psi put down 290/320 and the 19psi put down 300/310 ......
BlackSTI2006 is offline   Reply With Quote
Old 05-07-2007, 02:39 AM   #6
Sypher
Member#: 106366
2006 WRX
hey blacksti is that at the exact same dyno? if it is then the original poster made 20whp more then a Stage 2 Sti. Alot more TQ but..... man I thought this thing was basically a 20G with an 8CM hotside I was expecting yah know like 360whp
Sypher is offline   Reply With Quote
Old 05-07-2007, 04:52 AM   #7
CatfaceType-R
Member#: 81102
Originally Posted by nhsilversti View Post
i dont agree
well we can agree to disagree....
Old 05-07-2007, 07:44 AM   #8
turbo tecnica
Member#: 74470
2013 Accord Sport
72 LS1 Vette
I was waiting to see how the RR500 did out in consumers hands. I am on the fence about the TDC dyno (no drama here, don't worry). I have been tuned on it a couple times (by Jon). First was in my old 02 WRX with a VF39. Before I got tuned and had the turbo installed, I dynoed 238hp/239tq with an OTS Cobb stage 2 map. I thought it was high compared to others I had seen, so I figured the dyno read a little higher than others. Last May or April the dyno got recalibrated because something had broken on it, and was supposedly reading lower than usual afterwards. I got my STi tuned with alky and put down 311hp/335wtq, which I thought wasn't bad if the dyno was reading low (since I had seen so many alky setups with a good bit more than that, esp. torque). Someone from the TDC dyno day this weekend just said on their bugeye they put down 240whp/239wtq on the dyno... which leads me to believe it isn't reading low anymore? It's hard to tell. Either way, the torque you have comes in early and I bet is a blast - congrats... I miss that.
turbo tecnica is offline   Reply With Quote
Old 05-07-2007, 12:28 PM   #9
CatfaceType-R
Member#: 81102
i usually add or subract ~20 whp for people's setups...it ends up either making a lot more sense or showing that a dyno is programmed to make one smile and some dynos have to much load on them(low numbers) and a road tune is needed!
Old 05-07-2007, 01:15 PM   #10
vwjettavr67
Member#: 99192
Yea, I was hoping for more hp from this turbo.. and it def feels like it just wants to put out so much more... i will post in the future if i go on another dyno just to see a comparison. I think mike said the stock sti put out 230hp and 250tq something like that dont hold me to that though.. This was the first time the car was dynoed and still has the stock intake tube so that is def holding it back aswell. all in all was great time and car is a blast, cant go wrong for 1000 dollar turbo.. which I got for even less cause my boy got one aswell..
Old 05-07-2007, 01:39 PM   #11
CatfaceType-R
Member#: 81102
you can always get a new inlet, new intake, and a new up-pipe...
Old 05-07-2007, 01:47 PM   #12
vwjettavr67
Member#: 99192
sorry forgot to add that it is an after market up-pipe and header, i couldnt give you which one it is because it was on the car when I got it...
Old 05-07-2007, 04:26 PM   #13
BigJ04STi
Member#: 77239
2004 Impreza WRX
None
For the cost of that turbo... the numbers sound just fine... I mean it's like $999 or something...
But for the hype it was bringing, it doesn't seem like anything special, and the dyno won't tell about it's longevity...
I would like to see the curve if you have the dyno sheet.
BigJ04STi is offline   Reply With Quote
Old 05-07-2007, 07:59 PM   #14
bgod
Member#: 100274
My car has actually been on TDC's dyno before.
Last June in about 90 degree weather outside and about 100degree weather in the dyno room my car put down almost 320whp but I forget the torque.
This was with a fp20gtdo58cm oil cooled only and stock tmic. I believe boost was at 21 or 22psi if I remember correctly.
bgod is offline   Reply With Quote
Old 05-07-2007, 08:23 PM   #15
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
hey can you pm me some info about TDC tuning, i have a feeling thats the closest dyno to me (didnt think there were any 4wd ones up here heh)
Great numbers btw, first time ive seen that particular turbo dynod or at least in this forum anyway.. not bad man.
paul
PaulRex is offline   Reply With Quote
Old 05-08-2007, 05:43 PM   #16
Winner
Member#: 106050
- pm Josey Wales
OP congrats! I have a RR500 on the way and after the tune by Jorge at P&L(dynojet) i will also post
-was that on 93oct.?
Winner is offline   Reply With Quote
Old 05-09-2007, 12:24 AM   #17
V6TurboTA
Member#: 9090
09 Forester Gump
02WRX->04STi->09Gump
Nice numbers, when you running it at the track?
V6TurboTA is offline   Reply With Quote
Old 05-09-2007, 08:46 AM   #18
SuperSTI
Member#: 67182
2004 Subaru STi
11.0 @ 128mph - 93/Meth
I heard this turbo is more torque then anything.
Bump for octane?
SuperSTI is offline   Reply With Quote
Old 05-09-2007, 01:20 PM   #19
NHSRT4andSTi
Member#: 104608
2007 STI, 2005 EVO
white and Black
my STI turbo back, intake and tune did 316 whp and 355 tq.... fyi
and now 2 months later with SZ55, fmic, 750cc, tbe, intake it does 312whp and 315 TQ... kind of odd?
NHSRT4andSTi is offline   Reply With Quote
Old 05-10-2007, 12:09 AM   #20
BlackSTI2006
Member#: 105404
was that your numbers from the TDC dyno day with the new setup? You made like 360 or sumtin someone said at DSG for your tune right?
something is fishy.....if anything TDC should have read slightly higher than the DSG numbers.....
Old 05-10-2007, 05:26 PM   #21
SuperSTI
Member#: 67182
2004 Subaru STi
^^^^ hmmm
Old 05-10-2007, 06:33 PM   #22
benw
Member#: 103320
1998 swapped
Forester L
someone needs to post results for this turbo on a REAL dyno, not one whose numbers change constantly
benw is online now   Reply With Quote
Old 05-11-2007, 11:47 AM   #23
vwjettavr67
Member#: 99192
I will be getting dynoed agin in about 2-3 weeks in ny when im home
and dyno was with 93 octane
Old 05-11-2007, 03:20 PM   #24
V6TurboTA
Member#: 9090
09 Forester Gump
Old 05-15-2007, 02:37 PM   #25
vwjettavr67
Member#: 99192
Here is a link to my dyno, http://i154.photobucket.com/albums/s...JohnRrr500.jpg
will be going on another dyno to compare soon as well as the track...
also plan on doing new inlet pipe cause stock one is def holding me back and some water/meth
2010 STI SE airboy dyno sti mikey tuned, phatbotti tuning STi Mikey Proven Power Bragging 69 07-23-2010 10:39 PM
COBB Tuning Surgeline-Tuned STI runs 10.98 Cobb Tuning Proven Power Bragging 46 10-18-2009 03:31 AM
My RR500 Tune state NITROS Mid West Subaru Owners Club Forum -- MWSOC 1 01-11-2008 11:02 AM
Helix RR500 TUNED!! Winner Proven Power Bragging 115 12-20-2007 03:16 PM
Gauging Interest: 05 Legacy GT MT Accessport with TDC stg2 e-tune zuczek Engine/Power/Exhaust 5 09-16-2006 11:15 PM
