Old 05-07-2007, 02:59 AM   #1
runner19
Member#: 39562
My02 WRX Sedan 5MT
WR blue
Default Clutch need bleeding every 3 days
I have 2002 WRX. The clutch works fine after a bleed but after approx three days it becomes difficult to change gears. And ti needs to be rebled.
I had the clutch master and slave cylinder rebuilt and a new clutch hose installed. But it is still doing this.
Where else could be a leaking?
runner19 is offline   Reply With Quote
Old 05-07-2007, 07:01 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Not too many possibilities here, either the line is leaking or the cylinders were not rebuilt properly.
Best thing to do is forget about the rebuilding and get a brand new master and slave, make sure the threads on the hose aren't damaged and use new seals.
Old 05-07-2007, 09:19 AM   #3
John*G
Member#: 19562
95 coupe
red
I Would replace the master cylinder with a new one first. It is probably sucking in air around the seals when you let up on the clutch.
John*G is offline   Reply With Quote
Old 05-09-2007, 04:34 AM   #4
runner19
Member#: 39562
My02 WRX Sedan 5MT
WR blue
The dealer had the cylinders rebuilt. Before I spend any more money on this, is there a way to test the sytem prior to replacing the parts.
Old 05-09-2007, 06:52 AM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Not really, the fact that you are having to bleed it constantly confirms that it is not holding pressure and has a leak somewhere.
If this was done at a dealer recently there will be a warranty on the work, take it back and have them take care of it.
Need a 3 day backpacking trip for Memorial day weekend RedHotLama North West Impreza Club Forum -- NWIC 22 05-27-2006 03:33 AM
Oil change: every 3 months or 3,000mi? Kitt Service & Maintenance 19 02-05-2005 07:44 PM
Need to learn Visual Basic 6, in 3 days, need help/tutorials Protege Menace Off-Topic 5 11-03-2003 04:51 PM
Directions for bleeding the clutch needed MattC Transmission (AT/MT) & Driveline 1 11-29-2002 07:20 PM
SoCal guys...I need some beater rims for say about 3 days.... YahDude Southern California Impreza Club Forum -- SCIC 2 06-13-2001 01:35 PM
