#1 |
Member#: 34882
Vehicle:2003 WRX Stage 4 |
Well I got the 04 STI Gauge Cluster in my 03 WRX. But when I fill up my gas. The gauge doesn't read full... its between the first two top lines... Anyone have these same issues?
#2 |
Member#: 53443
Vehicle:2001 LL Bean Outback Winestone |
Do you know if the sender unit in the tank is the same one between those models. You may need to replace it. The tank design may be different also so just changing the sender unit may not fix the problem either.
#3 |
Member#: 34882
Might be, But just tryin to see if anyone else who has had done this swap have the same issues... or is it just me :P
#4 |
Member#: 149526
NWIC
Vehicle:2002 aps dr65 hybrid 9.1x1 built block/heads |
i swapped a 02 with no problems, well i kept popping radio fuses but solved that
| Thread Tools | |
| Display Modes | |
| 04 STI cluster in 03 WRX but no cruise control light | Fierysun | Electrical & Lighting | 2 | 04-21-2010 10:39 AM |
| 04 STI gauges in a 03 2.5 RS... | Phreaker | Electrical & Lighting | 1 | 04-03-2008 01:09 PM |
| Installing boost gauge in 03 wrx wagon | nich0lai | Electrical & Lighting | 5 | 04-09-2006 11:14 AM |
| 04 STI suspension in 03 wrx | tux | Brakes, Steering & Suspension | 3 | 04-19-2005 03:22 PM |
| 04 USDM STI cluster in 03 WRX? | Equilibrium Tuning | Interior & Exterior Modification | 4 | 06-22-2003 08:34 AM |
