Old 05-08-2007, 09:47 AM   #1
snapperswrx
Guest
Member#:
Default Declined due to aftermarket exhaust?
Any one ever been declined due to having say an apexi gt exhaust on there car because it is not stock so they wont fix my trans or something else that will go wrong? Sounds kinda stupid but makes sense also. I have the exhaust but I was just wondering if I have to take it back for service will they decline me? If yes Ill just take it off when I have to get service done to it.
Old 05-08-2007, 09:56 AM   #2
conker69
Member#: 59692
2005 Impreza WRX STi
WRB-Gold
Depends....if it is a turbo-back exhaust then a decline would make sense since you are making more power than stock.
If it is a cat-back, try another dealer. Most dealers won't have a problem with the cat-back.
Taking parts off and then going to a dealer is fraud. I would suggest not doing this.
conker69 is offline   Reply With Quote
Old 05-08-2007, 10:03 AM   #3
Jon [in CT]
Member#: 2992
02 WRX Sedan
Many shops will refuse to touch an aftermarket exhaust system because it is illegal for them to re-install it.
http://www.epa.gov/Compliance/resour...hsysrepair.pdf
Jon [in CT] is offline   Reply With Quote
Old 05-08-2007, 10:40 AM   #4
salisburyv
Member#: 41863
04 STI (SOLD!!)
somthin special is comin
your best bet is to remove exhaust if bringing it to a dealer for warranty work. trust me. and any other after market part associated with engine performance. just to be safe. My shop wouldnt have a problem with it. but most do.
salisburyv is offline   Reply With Quote
Old 05-08-2007, 10:53 AM   #5
racingfish
Member#: 60976
1969 LGT
FATURBO
remember a tech can tell if the bolts have been wrenched on. and most of the times when converting back to stock in haste people forget to properly put things back together.
racingfish is offline   Reply With Quote
Old 05-08-2007, 10:59 AM   #6
subbzrosubie
Member#: 132456
05 Leggy!
^^^They absolutely can tell. Take everything off........
subbzrosubie is offline   Reply With Quote
Old 05-08-2007, 12:41 PM   #7
shemoves
Member#: 80663
1997 Outback
Honesty is the best policy. If you swap out your aftermarket stuff, plan on getting your claim denied. Know this as far as warranties are concerned...they have to be able to prove that the mod caused the failure. A CBE does not make enough power for them to be able to say it caused the damage, and in reality even just a TBE should not, but it is enough for them to deny a claim.
shemoves is offline   Reply With Quote
Old 05-08-2007, 01:13 PM   #8
subikid
Member#: 114122
1990 miata(RIP 05rs)
red
should have gotten SPT stuff :P
subikid is offline   Reply With Quote
Old 05-09-2007, 06:00 AM   #9
StiLimited
Member#: 121212
2007 Sti Limited
Urban Gray Metallic
The reason the SPT stuff does not void the warranty is that SOA knows they produce no extra power.
StiLimited is offline   Reply With Quote
Old 05-09-2007, 08:40 AM   #10
Opie
Floresbian
Member#: 470
2013 BRZ, 2011
Forester, '04 Chev 2500HD
Exhaust's do not produce power...period.
Opie is offline   Reply With Quote
Old 05-09-2007, 02:55 PM   #11
02WHITEDUB
Member#: 96793
02 ProTuned TD04
Now with more clunks!
/\Let's add some detail so it's correct.../\
Catback and axlebacks add no power.
Other exhaust components (header, UP, DP) can produce power.
02WHITEDUB is online now   Reply With Quote
Old 05-09-2007, 03:44 PM   #12
Opie
Floresbian
Member#: 470
2013 BRZ, 2011
Still false, no exhaust component adds power. Power is produced by the engine assembly only. Removing cats and restrictions may free up lost power, but they do not create power.
Old 05-09-2007, 04:33 PM   #13
ringe
Member#: 49998
2007 WRX CT Stg 2
But only if it is a section of exhaust that used to have a catalytic converter. There is nothing wrong with a cat-back exhaust from what I can tell in that document you posted.
ringe is offline   Reply With Quote
Old 05-09-2007, 04:46 PM   #14
crampfan
Member#: 74321
2004 wrx wag
black UTEC stg 4
Oh.......trick question
crampfan is offline   Reply With Quote
Old 05-09-2007, 05:17 PM   #15
Noeladams
Member#: 121517
2003 WRB WRX
& WHT 93L
Noeladams is offline   Reply With Quote
Old 05-09-2007, 09:33 PM   #16
02WHITEDUB
Member#: 96793
02 ProTuned TD04
Obviously nothing but the engine can 'produce' power.
Your statement would have been understood by most as "exhaust components offer no gains."
Warranty denied on power steering line leak due to exhaust mod rjrmoore Warranty Issues & SOA Problems 156 09-27-2005 05:36 PM
CEL due to running lean due to cat back or removed silencer?? wrx_snobordr Factory 2.0L Turbo Powertrain 14 12-03-2004 11:22 PM
Anyone get wierd handling results due to aftermarket front endlinks? Kostamojen Brakes, Steering & Suspension 28 03-26-2004 01:16 AM
Boost creep due to catless exhaust? Impreza EJ20 Factory 2.0L Turbo Powertrain 10 03-09-2003 02:12 AM
how eliminat the check engine light due to a high flow exhaust or a catless exhaust minisiu Factory 2.0L Turbo Powertrain 1 09-13-2002 03:28 AM
Message Board Statistics All times are GMT -4. The time now is 03:02 PM.
