Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC > TXIC Vendor Classifieds
Closed Thread
Old 06-12-2006, 05:05 PM   #1
Edo Performance
Vendor Sales Rating: (54)
Member#: 70537
Subaru Stars Everything In Stock: STi, ZeroSports, Braille, and More...
STi front strut bar Legacy GT/Wagon - Price: $255
STi Strutbars are designed to improve chassis rigidity and reduce flex. The strutbar is made of an aluminum tube shaft, high strength and rigidity are obtained without unnecessary weight gain.
STi Rear Link Set (Full Pillowball) - 05 STi - Price: $575.00
The four piece STi lateral link set upgrades 6 of the link bushings to pillow ball type joints and the remaining 2 bushings (rear outer bushings) to STi group N hardened bushings. For use with stock pyro-ball swaybar links as on the MY04 STi. 6-pc. set can be used on MY04 STi but requires changing rear swaybar to non-STi version
STi Rear Trailing Arm Set - 02+ WRX/STI - Price: $275.00
STi pillow ball trailing link set reduces dynamic toe changes and significantly improves the handling.
STi Pink Spring Set - Legacy GT - Price: $379
STi lowering spring set reduces the vehicle's center of gravity for improved handling characteristics while still maintaining reasonably good ride comfort. Excellent for fast road and mild competition use. Can be used with factory struts, or more effectively with STi factory or sport adjustable strut set.
STi Pink Spring Set - 04+ WRX/STI - Price: $379
STi Pink Spring Set - 2004-2005 Forester XT - Price: $379
Edo Performance is offline
Old 06-12-2006, 05:05 PM   #2
Edo Performance
Member#: 70537
STi Spec C 12L Intercooler Water Tank - Price: $269
The 12L Spec Intercooler tank will greatly increase the capacity of your Intercooler sprayer in your STI. It comes with tank mounting brackets and pump. This is a Genuine subaru part and has STI molded into it. This piece mounts behind the rear seat inside the trunk.
STi Pink Injector 565cc WRX 2002-2005 - Price: $375
Subaru Rates these injectors at 525cc, other companies have rated them at 510cc, 520cc, 550cc, or 565cc, but when flow tested they consistently flow 565cc so don't get confused; these are what you want. These injectors use the same clip as factory injectors for true plug-and-play installation. These are genuine STi, so you will have a clean idle and low speed response. Because the EJ20 engine works better with a rich air/fuel ratio; these injectors are a must for upping the boost or switching to a smaller bolt-on turbo (IHI VF22 or VF34).
STi V-Limited Lip: 05+ Legacy - Price: $539
STi V-Limited Front Lip: 04-05 WRX/STI - Price: $539
STi V-Limited Front Lip: 06+ WRX/STI - Price: $539
STi Spec C Front Lip (Painted): 06+ WRX/STI - Price: $475
Currently, the only available color we have in stock is World Rally Blue
Old 06-12-2006, 05:06 PM   #3
Edo Performance
Member#: 70537
2006 ZeroSports Body Kit
(front)
(rear)
Front Bumper: $945
Side Skirts: $558
Rear Bumper: $945
Roof Vane (spoiler): $297
Complete JDM ZeroSports Appearance
ZeroSports Bodykits and Body Components
ZeroSports Front Lip - $330.75
ZeroSports Front Bumper - $737.10
ZeroSports Rear Bumper - $737.10
ZeroSports Rear Spoiler - $652.05
ZeroSports WRX Spoiler Adapters - $187.11
ZeroSports WRX Grill - $255.15
ZeroSports Headlight Garnish - $141.75
Old 06-12-2006, 05:08 PM   #4
Edo Performance
Member#: 70537
ZeroSports Twinscroll Turbo and Oil
Turbo - $2200.00
Engine Oil R (10w-50)- $99
Engine Oil TB (10w-40)- $89.10
ZeroSports Exhaust Setup
ZeroSports HighFlow Catted Down-pipe - $831.60
ZeroSports Up-pipe - $470.61
ZeroSports World Leaguer Exhaust - $737.10
ZeroSports Exhaust Manifold - $1620.00
Old 06-12-2006, 05:09 PM   #5
Edo Performance
Member#: 70537
Braille 12v Auto Battery - $155.00
The Specs: (detail)
- Voltage: 12
- AH: 15
- PCA: 700 Pulse Cranking Amps
- Length: 5.8"
- Width: 3.3"
- Height: 5.9
- Weight: 11.5 lb or 5.2kg (More than 10lbs lighter than stock battery!!)
- Use: Road Racing, Drag Racing, Rally Racing, Auto- Cross and Daily Use
There will be more posted at a later time. If there are any questions, you know how to get a hold of me.
-kev.
www.edoperformance.com
[email protected]
512-462-0125 x21
Old 06-12-2006, 10:43 PM   #6
Xtant
Member#: 105710
2006 WRX Wagon
WR Blue Pearl
Do you have the STi pinks for an 06 Wagon specifically?
Xtant is offline
Old 06-13-2006, 02:49 AM   #7
Edo Performance
Member#: 70537
sorry, nothing specifically for 06 wagon. i can check to see if any of the springs are compatible though.
Old 06-13-2006, 02:43 PM   #8
dirtymatt
Member Sales Rating: (4)
Member#: 110461
pink is soooo perrrrrty
dirtymatt is offline
Old 06-13-2006, 05:00 PM   #9
Xtant
Member#: 105710
2006 WRX Wagon
WR Blue Pearl
Please do. I'm ready to buy
Xtant is offline
Old 06-17-2006, 03:29 PM   #10
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
Do you have any clutches/flywheels for an 04 wrx? Thanks.
scoobdude is offline
Old 06-18-2006, 06:39 PM   #11
Edo Performance
Member#: 70537
Sorry, no clutches or flywheels in stock. We can get Exedy and ACT though. Let me know if you're interested.
Old 06-19-2006, 09:58 AM   #12
uathatis
Member Sales Rating: (14)
Member#: 117300
would the front bumper zerosports 06 fit a wagon? or would the sizing be wrong
uathatis is offline
Old 06-19-2006, 02:08 PM   #13
FatStraws
Member Sales Rating: (12)
Member#: 57954
04 No More Subaru
Former ZeroSports Stg. IV
the bumper will fit, but i would recommend cahnging your fenders so that the fender "flares" will match up with the bumper
FatStraws is offline
Old 06-22-2006, 01:42 PM   #14
Xtant
Member#: 105710
2006 WRX Wagon
WR Blue Pearl
Any wagon rear sway bars and end links in stock? Price on install of springs purchased elsewhere?
Xtant is offline
Old 06-22-2006, 05:33 PM   #15
EL PAALO
Member Sales Rating: (6)
Member#: 103927
2007 GTI
UG
legacy wagon pinks? :'(
EL PAALO is offline
Old 06-22-2006, 07:41 PM   #16
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
I would be interested in the clutch and flywheel soon. Pm me a price on what you can get. thanks
Old 06-24-2006, 12:25 PM   #17
Xtant
Member#: 105710
2006 WRX Wagon
WR Blue Pearl
WRX Wagon rear sway bars and end links?
Xtant is offline
Old 06-24-2006, 12:32 PM   #18
Edo Performance
Member#: 70537
Sorry...nothing for wagons =(
Old 06-24-2006, 01:34 PM   #19
Mad Ra88it
Member#: 113563
98 Unicorn
Can I get a Price on a MY02 Clutch kit.
thanks.
Mad Ra88it is offline
Old 07-28-2007, 09:35 PM   #20
quaam
Member Sales Rating: (1)
Member#: 113615
2006 WRX Wagon
BLACK
how much do the fenders go for?
quaam is offline
Old 07-28-2007, 10:49 PM   #21
Khooda
Member Sales Rating: (3)
Member#: 102780
05 WRX
CGM
Group buy on the rear lateral links?? And trailing arms too??
Khooda is offline
Old 07-31-2007, 02:37 AM   #22
Edo Performance
Member#: 70537
let's see who is interested on the rear lateral links and trailing arms
Old 07-31-2007, 02:38 AM   #23
Edo Performance
Member#: 70537
bump bump for good stock
Old 07-31-2007, 09:11 PM   #24
Khooda
Member#: 102780
05 WRX
CGM
Bump it up for cheaper lateral links!
Khooda is offline
Old 08-21-2007, 12:12 AM   #25
sperry7
Member Sales Rating: (10)
Member#: 110079
06 WRX
Black on Black
Where are you guys located?
sperry7 is offline
Closed Thread
Veterans Day Sale, Moroso, Kelford, Braille and More Adrenalin Rush Engine/Power/Exhaust 12 11-27-2008 10:24 AM
SOCAL- Everything for $950!! coilovers, STi key, uppipe, and more fexterz11 Interior/Dressup/Audio & Security 0 01-21-2008 04:59 PM
carbon dress up, txs intakes, k&n panel filter, zerosports pipe, and more! anthonyrb98 Private 'For Sale' Classifieds 64 05-27-2006 04:27 PM
wrx carbotech rotors, turboxs racepipe, zerosports grill, and more! anthonyrb98 Private 'For Sale' Classifieds 142 09-11-2005 02:13 AM
APS, MRT, GFB, Braille and more, Specials!! MastroWRX Engine/Power/Exhaust 5 08-11-2004 08:58 PM
