Old 04-03-2008, 04:46 PM   #26
SpreadHeadLINC
Member#: 149802
2005 WRX Wagon
Thanks guys. SVXdc, you are the man. One-stop shop, for sure.
Cheers,
Andrew
SpreadHeadLINC is offline   Reply With Quote
Old 05-27-2008, 05:28 AM   #27
aure
Member#: 180221
2004 Impreza WRX
Hey guys I recently took out my Pioneer deh-p690UB from my old lexus that had a stock amp w/ premier sound. I was told that the lex needed to be completely rewired due to the amp that was "in" the pioneer deck...I have an 04 WRX now and I am looking to put this deck into the subie. Am I going to run into that same problem? Or can I grab a wiring harness for a subie and I am good to go? Thanks for the help.
Looked up the subie wiring harness on Circuitcity.com and it said I would need two wiring harnesses to complete the intall...true?
Pioneer DEH - P690UB http://www.pioneerelectronics.com/PUSA/Products/CarAudioVideo/Source/CD-Players/DEH-P690UB
aure is offline   Reply With Quote
Old 05-27-2008, 12:16 PM   #28
mcdeve8
Member#: 143174
2005 WRX Wagon
CGM
As far as I know, you should be able to grab a Subie harness and wire it up. I'm not familiar with Lexus's and the only thing I can think of is that it's stock system had an amplifier and needed low level inputs from the deck. Unless the 04 is different the metra harness number is 70-8901 (single piece).
mcdeve8 is offline   Reply With Quote
Old 05-27-2008, 12:43 PM   #29
aure
Member#: 180221
2004 Impreza WRX
and one last noobie question...am i going to need to run anything new to the battery? or just unhook when installing and rehook when done installing? dont need to hook up a new fuse as if i had an amp and subs in the back too. thanks.
Old 05-27-2008, 01:02 PM   #30
mcdeve8
Member#: 143174
2005 WRX Wagon
CGM
The head unit should have its own fuse. No extra fuse should be necessary.
Old 05-28-2008, 12:50 AM   #31
aure
Member#: 180221
2004 Impreza WRX
Really a great help...thanks a lot for the replies mcdeve
Old 07-04-2008, 12:18 AM   #32
ilitical
Member#: 183801
2015 WRX Base
ISM
Followed the tutroial and somewhere during my install, my dome lights, clock, alarm all stopped working. im unsure of what i did wrong, i just plugged the subaru harness in and attached all the wires from the HU harness and now they are all dead. I checked every fuse and all where good.
One thing i had to do to get power to the head unit was run the power wire from the HU to the accessory wire on the harness becuz it wasnt recieving power, could it be overloading the circuit? The radio and amp, etc. work but no dome lights, clock, or alarm. =[ help!
ilitical is offline   Reply With Quote
Old 07-15-2008, 11:11 AM   #33
brianroy86
Member#: 182320
2006 WRX Ltd Wagon
Black (wicked tuned)
you should just need to run the yellow power cables together, and don't forget the red ignition wire (i think its red). If you don't, the radio won't get power when you turn the car on. I just put a sony HU in my 05 impreza with no real problems. I did have my accessory wire hooked up to the ATT wire, which made the radio ATT whenever i turned off my headlights though lol. You can just unhook the acc cable, no need for it with the aftermarket radio i guess. at least not on mine
One problem I am having though is that the climate control/HU panel does not fit around the new radio. Anyone have a suggestion on how to cut out a little bit of the space so i can get it in? I'm tryin a dremmel, but its a weird angle because the dremmels a little too long to get in there right. Plus the corners are proving to be difficult
brianroy86 is offline   Reply With Quote
Old 07-15-2008, 05:30 PM   #34
mcdeve8
Member#: 143174
2005 WRX Wagon
CGM
This is just a guess, but your clock/dome power issue might be related to the constant power wire (yellow on harness) not providing 12VDC (don't have a schematic so I'm not positive). Do you have power on both sides of the fuse for the clock/dome light?
If you use the accessory wire only for power, the memory on the deck will clear every time the car is shut off.
Old 07-29-2008, 03:04 PM   #35
The Hammer
Member#: 185679
Is there a 3.5mm jack or RCA jacks on the back of the original stereo? I was thinking of trying to run a plug for an mp3 player to an aux jack on the existing stereo if one is there. Hate to take everything apart if it wouldn't work anyway. Thanks.
The Hammer is offline   Reply With Quote
Old 07-29-2008, 05:02 PM   #36
mcdeve8
Member#: 143174
2005 WRX Wagon
CGM
Here's a thread with information on the stock head unit.
http://forums.nasioc.com/forums/showthread.php?t=749402
As far as I know there are no RCA's or 3.5mm jacks on the stock unit.
Old 08-06-2009, 12:55 PM   #37
wolftroutcobra
Member#: 218979
2005 Saab 9-2x aero
I have to assume so, but are these instructions the same on a 9-2x?
wolftroutcobra is offline   Reply With Quote
Old 08-06-2009, 05:29 PM   #38
Uncanny
Member#: 133012
2015 STi
Lightning Red
Yes45
Uncanny is offline   Reply With Quote
Old 09-11-2010, 01:17 AM   #39
Protege Menace
Member#: 41950
faq u rug
I'd like to thank you for posting this, it helped tremendously when I put my stereo in tonight.
The one tip I'd like to tell others trying to get the upper bezel off:
There are 2 very easy to pop clips in the middle, represented by yellow dots:
Then, the hard part is getting the top 2 clips out. I tried using quite a bit of force, but couldn't get them without possibly breaking the plastic. In the end I took a long screwdriver, stuck it straight up, behind the bezel, and pried so that the force of the screwdriver tip was right NEXT to the top 2 clips (shown as red dots) and made a force towards my face. Also, the top 2 clips are male on the bezel, which fit snuugly into the female holes on the dash itself, so you should be popping the bezel off straight towards you.
That was the one hiccup I had, not knowing exactly how the final clips were, since we are told to carefully wiggle them, and they are in there TIGHT, so a screwdriver behind it did the trick
Protege Menace is offline   Reply With Quote
Old 09-12-2010, 11:07 PM   #40
Viago
Member#: 257646
2005 Impreza 2.5 RS
I just got my first Subaru on 9/10/10.
2005 Impreza 2.5 RS
4dr WGN
Auto
I want to install either
Jensen VM9214 or VM9424
I am not sure if my Impreza will take a 7 inch wide HD. any clairification on it would help. My current is 2in Heigh and around 6 1/2 ish long (it does have the lil holder underneath that from many other how to's (this one, the 06 wrx one and the wrx carputer) i can tell can be removed to fit a 4in heigh HD
thanks.
Viago is offline   Reply With Quote
Old 09-15-2010, 05:25 PM   #41
mcdeve8
Member#: 143174
2005 WRX Wagon
CGM
Glad this writeup was helpful to you guys. I took a look on the Crutchfield site and it indicated that the Jensen VM9214 and VM9224 both fit in the '05 RS. Congrats on the new Subey.
Old 09-25-2010, 01:25 PM   #42
Viago
Member#: 257646
2005 Impreza 2.5 RS
thanks for your walk through. I had trubble getting mine to work. lol. but that was the head unit.
Old 01-07-2011, 12:20 AM   #43
dc5_girl
Member#: 129993
i love this post. thanks so much
dc5_girl is offline   Reply With Quote
Old 04-15-2011, 04:56 PM   #44
hype-R-29
Member#: 67431
subscribed for Sunday!..good info
hype-R-29 is offline   Reply With Quote
Old 04-15-2011, 05:05 PM   #45
hype-R-29
Member#: 67431
what color is the remote lead wire? for aftermarket amp turn on.. Blue?
Old 04-22-2011, 05:25 PM   #46
mcdeve8
Member#: 143174
2005 WRX Wagon
CGM
IIRC, yes, the remote turn on lead should be blue.
Usually, the aftermarket harnesses are wired for power as follows:
Red - Ignition Powered
Yellow - Constant power
Black - Ground
Blue - Remote Amp Lead
This is from the dusty recesses of my brain so you might want to double check.
Old 04-25-2011, 05:23 PM   #47
chad_wick
Member#: 267831
2006 STi
Gray
nice set up i want to install my on set up its not that hard thanks.
chad_wick is offline   Reply With Quote
Old 06-02-2011, 11:13 AM   #48
Didymus78wrx
Member#: 284534
2005 WRX
Default I have an 05 wrx, but it's and automatic
I am stuck on trying to get the part that houses the gear shift to come free. On the automatic it has the gear pattern and don't know if its attached or how to remove it. Any help is appreciated...Thanks in advance Tom
Didymus78wrx is offline   Reply With Quote
Old 06-02-2011, 05:25 PM   #49
mcdeve8
Member#: 143174
2005 WRX Wagon
CGM
Good question. From what I've found looking around, you can unscrew the shift knob and pop off the bezel assembly, similar to the manual version. At least that's what the link below shows. Or, it's bunk, and I'm a liar!
http://www.redlinegoods.com/SubaruWRX05install.shtm
Old 06-03-2011, 01:02 PM   #50
Didymus78wrx
Member#: 284534
2005 WRX
Default I got it
Hey, thanks. I got it, just had to put the car in neutral and take the leather knob off. I got the pioneer avh p3300bt, so hoping everything will work perfectly... Thanks again for the write up.
how to install and aem injector driver bloopsta26 Other Engine Management 0 11-05-2008 06:31 PM
How to disarm and remove the alarm/remote entry Danny Boy Car Audio, Video & Security 3 12-24-2006 01:29 PM
How to install your deck in a 2002 WRX? [freeman] Car Audio, Video & Security 8 02-28-2002 04:21 AM
Does anyone in this area know how to install and fine tune a TEC-II MY99 2.5GT Mid Atlantic Impreza Club -- MAIC 1 07-04-2001 01:07 AM
Need Directions on how to install and something for sale scoobyruman New England Impreza Club Forum -- NESIC 14 07-02-2001 09:58 AM
