Old 12-17-2001, 06:24 PM   #1
SGOSWRX
Member#: 10921
04 04 STi
12.8 @ 105 mph
Default Removing heat shield?
How do you get the heat shield off? I can reach some of the screws but how do you get to the screws on the side near the bottom. I can't see how to get to them. I spent an hour trying to get the heat shield off and its still on my WRX.
I need help.
Thanks for any advise.
SGOSWRX is offline   Reply With Quote
Old 12-17-2001, 06:26 PM   #2
mdntridr
Member#: 8886
2004 Ford Ranger
'05 Honda VTX1300C
Default Re: Removing heat shield?
I need help.
Which one are you talking about?
If it's the turbo heatshield then jack up the car, crawl underneath and get at the bolts from there.
Good luck.
--Greg--
mdntridr is offline   Reply With Quote
Old 12-17-2001, 06:34 PM   #3
en3d
Member#: 5238
GGA Black
If you are talking about the turbo heat shield and the side screws to the passenger side... if you can't get to them with any of your tools from the bottom then...
Take the stock air box out and you will have direct access to them.
en3d is offline   Reply With Quote
Old 12-17-2001, 07:34 PM   #4
D_REX
Member#: 8945
MY02 WRX
I just slid an air ratchet down into the gap. I think you could do the same with a ratchet, maybe a little more dificult?
D_REX is offline   Reply With Quote
Old 12-17-2001, 07:38 PM   #5
TurboRex
Member#: 8635
04 STI, 07 FXT
I used an open end wrench from the top. I believe all the screws are the same size. But then again I am a caveman.
Greg
TurboRex is offline   Reply With Quote
Old 12-17-2001, 07:49 PM   #6
K-WRX
Member#: 6925
2006 Cayman S
If you think getting them out is tough, wait til you try to screw them back in - I could only manage 2 of the 3.
K-WRX is offline   Reply With Quote
Old 12-17-2001, 09:55 PM   #7
D_REX
Member#: 8945
MY02 WRX
What heat shield are YOU talking about? The turbo heat shield has something like 8 screws. Although I have to admit mine only has 2 holding it in place.
Old 12-20-2001, 12:22 PM   #8
K-WRX
Member#: 6925
2006 Cayman S
Sorry, I should have made it more clear - I was talking about the 3 screws at the bottom of the turbo heat shield.
Remove heat shield? binx159 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 03-23-2009 05:37 PM
How hard to remove heat shield on cilinder #4 for EGT??? BBBsti LTD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-26-2005 03:25 PM
Removing heat shields...is this ok? 2sour4u Normally Aspirated Powertrain 17 12-25-2003 01:19 AM
Removing Heat Shields? Ryan24 North West Impreza Club Forum -- NWIC 2 08-25-2002 06:00 PM
Installed exhaust- can I remove heat shield? SoLiDbReAkZ Service & Maintenance 8 04-18-2002 11:10 PM
