Old 05-09-2007, 06:14 PM   #1
scoobyc
Member#: 141005
Default how to remove 06 wrx/sti bumper?
Tried a search but never came up with too much, just wondered if someone had a "how-to" or any tips? thanks
scoobyc is offline   Reply With Quote
Old 09-04-2007, 02:38 AM   #2
jeremy25056
Member#: 153968
2008 STI &
Ducati Hypermotard
honestly. just go under pull all the pins on the bottom. pop the hood pull the center grill out. and pull. it sounds bad but thats how its done.
jeremy25056 is offline   Reply With Quote
Old 09-04-2007, 03:26 AM   #3
WRXCJS
Member#: 142059
2010 STi
^ rofl.
There are 5-6 plastic pop up clips on the top that you will need to pop up the center and pull the entire clip out. You can keep the grills in place.
5-6 of the same clips line the bottom you'll only need to remove the ones that intersect with the body. There are 2 on each side and maybe 4 up front.
Then there will be two screws where the front clip intersects with the fender.
Then pull out.
WRXCJS is offline   Reply With Quote
Old 09-04-2007, 04:14 AM   #4
EdHilario
Member#: 137398
2004 Impreza
There are also two small plastic pins in the wheel well. 1 per side.
EdHilario is offline   Reply With Quote
how to remove 06 wrx fog light covers. asherbo Interior & Exterior Modification 15 12-16-2009 08:22 PM
How to remove an 04 front bumper. shamrock 05 Interior & Exterior Modification 5 07-29-2008 08:14 PM
How to remove 06 2.5i mirror cover edkudo Interior & Exterior Modification 0 05-01-2006 12:56 PM
someone have a link to some instructions on how to remove 03 wrx headlights? blackie Interior & Exterior Modification 3 09-24-2004 12:06 AM
Rear ended - how to remove small scuff on bumper? lowkey Interior & Exterior Modification 5 07-29-2004 12:31 AM
