Old 05-09-2007, 05:33 PM   #1
chibich
Member#: 79134
2004 STI
Default Need help with intake manifold on 04 STI (pic request!)
I finished up doing my aps inlet install on my 04 sti, and I the car is acting like it has a vacuum leak. There is a small line to the left of the throttle body on the intake manifold, and I was wondering if someone could please take a picture of this line and the small one that is right below that and show where it goes (just to make sure that I have it hooked up correctly). All the other lines I am 99% positive are correct.
-I could also not find the torque specs of the intake manifold, just wanted to make sure everything is torqued down right and there are no leaks there.
chibich is offline   Reply With Quote
Old 05-09-2007, 05:55 PM   #2
VIR EURORALLY
Member#: 53517
STi Outback STi
That line should be approx. 2.5" long, correct? If so it comes out of the int. manifold and goes into the fuel pressure regulator below it.
http://www.iwsti.com/forums/showthre...nifold+removal
This has the torque specs in there.
VIR EURORALLY is offline   Reply With Quote
Old 05-09-2007, 10:26 PM   #3
chibich
Member#: 79134
2004 STI
yea, that is how I had it set up. guess I will have to start looking in other places. Thanks.
Old 05-10-2007, 08:36 AM   #4
STIBungy
Member#: 51684
The one to the left doesnt go anywhere because you snipped off the other end earlier, according to the instructions for the APS inlet. The smaller one that connects to the intake manifold goes to the new fuel pressure regulator that APS provided.
If you forgot to tighten down the manifold or tgv housing, the car idles really lean. I know that from experience.
STIBungy is offline   Reply With Quote
Help with intake manifold sensors. M-dub39 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-01-2009 11:20 PM
2004 STi Intake Manifold on 2007 STi i_drank_what Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 12-03-2008 11:08 AM
Problem with low boost on 04 STi. Need help! BGPKR Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 06-15-2006 08:12 AM
Need help with intake manifold removal Starkiller Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-11-2005 03:28 PM
Help with intake manifold lotusTT Normally Aspirated with bolt-on Forced Induction Powertrain 7 11-25-2003 10:24 PM
