Welcome to the North American Subaru Impreza Owners Club Thursday June 20, 2013
Old 05-11-2007, 01:54 PM   #1
02WRXer
Member#: 7824
2002 Impreza WRX
WRC Blue Pearl
Default 18's on a 04 how wide and low can I go ???
Since finishing my 240 and slapping on 10.5 all the way around I look at my stock 04 sti and feel bad for it. I know I can't go stupid wide without a widebody but how big can i go with rolled front and rear fenders I want to go with a 18 inch wheel and a low enough offset to get it flush. And what kinda of suspension would be ideal to run with the suggestions ya'll through out. Pics would kick ass to if ya'll have them.
Thanks in advance guys
02WRXer is offline   Reply With Quote
Old 05-12-2007, 12:54 AM   #2
specul8r
Member#: 49936
2004 STi
I'm going to be mounting Falken 255/35/18s on 18x8.5 48ET Advan RGIIs in about 4 weeks. I've got an '04 STi with rolled fenders, and this is about maximum width. I'm going to be running JDM pinks, and eventually Ohlins fixed perch struts with them. Good luck with your decision.
specul8r is offline   Reply With Quote
Old 05-12-2007, 08:03 AM   #3
aznmc16
Member#: 25253
2004 WRX STi
depending how low you drop your car, its probably ideal to go no further than 235's.
i have an 04 with 245/40/18 on 18x8.5 48offset lowered on tein supersports. it rubs when i had the suspension really low, and have had to raise the car to get rid of the rubbing. the rubbing was happening INSIDE the fender liner, hitting the metal frame. rolling fenders didn't matter, it was hitting the other side.
here is my car.
thats the lowest it'll go without rubbing.
aznmc16 is offline   Reply With Quote
Old 05-12-2007, 12:59 PM   #4
specul8r
Member#: 49936
2004 STi
here is my car.
You've got a few issues that caused rubbing. First; the teins lower your car significantly over stock. Second; 245/40/18's are 3/4" taller than the stock tire. The 255/35/18's are the same as stock, and if you're going with only a moderate drop, you'll likely be fine after a fender roll.
02 wagon... stock wheels. how wide of tire can I go? 03boxer4 Tire & Wheel 4 08-31-2008 09:03 PM
Reporting Car Value For Taxes On Private Party Sale: How Low Can you Go? REX8 Off-Topic 19 03-26-2008 04:25 PM
How low can I go with 18's 03mbpREX Brakes, Steering & Suspension 3 03-20-2006 02:59 PM
How low can you go on uncut bumpstops? eVoMotion Legacy Forum 7 11-03-2003 05:09 PM
how wide a tire can i go? fstede21 Brakes, Steering & Suspension 2 07-26-2002 09:37 PM
Message Board Statistics All times are GMT -4. The time now is 05:54 AM.
