Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 12-18-2001, 11:03 AM   #1
gmflex
Member#: 9796
2004 STI
Thumbs up Perrin Subaru Performance uppipe
Quality construction and perfect fit. I had an extra EGT bung welded in for my EGT gauge and it works great. I would definitely recommend this uppipe. It's a great deal for $200.
gmflex is offline   Reply With Quote
Old 01-23-2002, 01:15 AM   #2
QA Guy
Member#: 6739
Where can you get this for $200? I haven't seen it that cheap.
QA Guy is offline   Reply With Quote
Old 01-23-2002, 09:39 AM   #3
AmSFighter
Member Sales Rating: (1)
Member#: 8923
2007 BMW 433whp N54
Gray
I'd like to know also! That is a bad arse deal. Thanks.
-James-
AmSFighter is offline   Reply With Quote
Old 01-25-2002, 03:28 AM   #4
Jung918
Member#: 10969
http://www.vividracing.com/prod_uppipes.php
that is the only place that i know that carrys the up-pipe
Jung918 is offline   Reply With Quote
Old 01-28-2002, 09:45 PM   #5
wrxracer
Member#: 5275
2002 impreza WRX
WR BLUE
Question perrin up-pipe
so, any "CEL" with this up-pipe? have you installed it and where did you buy from? let us know........
wrxracer is offline   Reply With Quote
Old 01-31-2002, 08:23 PM   #6
Mr.Freeze
Member#: 12692
bust a move check it
out i'm rockin' steady
I would also have to say that the Perrin uppipe is top notch. Quality was second to none, and for the price nothing compares. I bought mine with the original group buy so the $200 price may not be around but many places carry them GRD Performance (GRD_REX handle on i-club) and vividracing, to name a few.
Nirmit
Mr.Freeze is offline   Reply With Quote
Old 01-31-2002, 11:07 PM   #7
Jung918
Member#: 10969
what is the web site for GRD-Performance...?
Old 12-10-2002, 01:39 AM   #8
scoobybrande
Member#: 12362
Platinum Silver
Thumbs down
I have a Perrin up-pipe installed, but it didn't go in properly. I bolted in the top end to the turbo first, and that went very smoothly. But then two things were wrong; first, the end which mates to the exhaust manifold was not square to the manifold, so I had to torque down the hardware pretty tight to make the seal. Second, and most important actually, the two bolt holes on the bottom end of the up-pipe are the wrong distance apart, there was no way the bolts would fit through, so I had to seriously ream the holes on the up-pipe and exhaust manifold out to make room.
scoobybrande is offline   Reply With Quote
Old 12-10-2002, 02:17 AM   #9
supermarkus
Member Sales Rating: (13)
Member#: 6971
2008 WRX STi
SSM
If you torqued the turbo to the up-pipe first, that's exactly what Perrin says not to do on his web-site. His instructions specifically say to do the up-pipe/manifold junction first.
Read me
As for your other fit problem, I've never heard of the Perrin pipe having that problem, that's something you should talk to Adam and Jeff about, they need to know if there are these kinds of "QA" problems. It sounds like you got a lemon of a pipe and installed it incorrectly, you really shouldn't have to torque on these junctions. Factory spec is only 28 ftlbs or something like that, over torque them and they have a tendency to leak.
supermarkus is offline   Reply With Quote
Old 12-10-2002, 02:35 PM   #10
scoobybrande
Member#: 12362
Platinum Silver
Supermarkus has a valid point, but what I neglected to say was that I originally tried to install it the way Perrin describes, but that was was literally impossible, not just a pain like the way I described. Despite my displeasure, I'm probably going to buy other Perrin parts!
Old 12-10-2002, 07:03 PM   #11
hkwan
Member#: 7536
2005 WRX STi
Besides the fitting, any comment on the expected performance of the pipe?
hkwan is offline   Reply With Quote
Old 12-12-2002, 02:38 PM   #12
DonkeyPunch
Member Sales Rating: (5)
Member#: 18987
2014 Forester
Dark Grey Metallic
Here is my impression, great product, beefy construction, good thick flanges. Thing fit perfect, no leaks after putting it in. A little increase in noise, but nothing to bad. Had to put mid pipe cat back on other wise I would be running catless (guilty conscience), no check engine light, the provide 2.2 kOhm resistor to put into egt socket keeps that from happening. Turbo spool is faster, and egt's dropped. More lowend power, if I went catless I'm sure I would notice a bigger difference, maybe I will just for fun someday put mid pipe cat elim back on for giggles. Install took about 4.5 to 5 hours. Here are my recommendations, buy extra nuts for the header stud before doing this, they are the same as the nuts for the turbo to downpipe nuts, I stipped two or three nuts while doing this, and yes I used a metric butt ton of liquid wrench. I bought from motormatrix.com, I don't recommend them though I have a write up in the vendor reveiw forum about them, terrible service. But all in all money very well spent, even if just from a reliablity standpoint, so the turbo doesn't get destroyed by broken off cat material, or broken egt probe, the factory one is pretty weak looking, not like the autometer one I have.
Good luck and happy wrenching.
DonkeyPunch is offline   Reply With Quote
Old 12-12-2002, 02:52 PM   #13
hkwan
Member#: 7536
2005 WRX STi
Would you be able to quantify some of the improvement? How many degree doest the EGT drop by? Spooling up faster by how many RPM?
Old 01-07-2003, 12:13 PM   #14
pjcoregon
Member#: 15384
I can't answer for the EGTs... but after my perrin uppipe was installed my spool-up went from 3100 rpms to 2400 rpms.
Great uppipe... and Jeff is a great guy to talk to about the parts.
pjcoregon is offline   Reply With Quote
Old 01-11-2003, 12:08 AM   #15
PaulRex
Member Sales Rating: (3)
Member#: 12454
10 Toyota Taco
K8 SV650SF
Perrin upipes, as well as other Perrin performance products are also available from NinosAutoAccessories http://forums.nasioc.com/forums/memb...o&userid=17347 a vendor here and on i-club.com. I bought my Perrin upipe from him for $250 w/new gaskets..
Paul
PaulRex is offline   Reply With Quote
Old 08-07-2003, 06:13 PM   #16
BENSREX
Member Sales Rating: (6)
Member#: 39718
2007 WRX
If anyone is looking for a Perrin uppipe, I have a brand new one. It is the newest one (exact one found on site, shiny metal). I'm asking $225 obo for it. BRAND NEW! I will pay shipping in the U.S if you buy for $225.
BENSREX is offline   Reply With Quote
Old 08-08-2003, 01:32 PM   #17
why
Member#: 40717
2004 WRX wagon
What kind of gains can be expected from this?
why is offline   Reply With Quote
Old 08-11-2003, 03:26 PM   #18
SjpWrx
Member#: 22554
2007 Corolla no PW!
WHITE miss my WRX :(
i also have a perrin Uppipe, as far as gains go its about 11 whp if im correct (dont quote me i think i read that some where) but more importantly youve removed the cat in the pipe that tends to break up and cause turbo faluire.. so that the biggest advatnge..
later steve
SjpWrx is offline   Reply With Quote
Old 08-14-2003, 11:21 PM   #19
thewhitewrx
Member#: 36007
1992 Galant VR-4
Darkness
Default bump
im setting up a group buy thru a nasioc vendor for next month. 200 shipped and 25 for the gaskets....good deal for a good up pipe
_dan
http://forums.nasioc.com/forums/show...hreadid=406595
thewhitewrx is offline   Reply With Quote
FS (OR): Perrin Performance Uppipe wrxridah Engine/Power/Exhaust 1 04-05-2010 01:25 AM
TurboXS Flex Uppipe for External Wastegate? Or Perrin Non-Flex Uppipe? TROLL Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 07-04-2006 11:28 AM
stock uppipe FS...make your own performance uppipe! Subaruist Private 'For Sale' Classifieds 3 08-28-2003 04:26 PM
Two thumbs up to Perrin Subaru Performance SK00Impreza Vendor Reviews 3 12-18-2001 03:50 PM
Anybody dealt with Perrin Subaru Performance? Patrick [Buffalo] Vendor Reviews 2 11-02-2001 01:08 PM
