05-12-2007, 01:37 PM | #1 |
Member#: 108965
Vehicle:2005 Subaru WRX STi |
Help, Hydra Issues. DBW etc..
I have been fighting this problem for some while now. What happens is sometimes when i am driving, the throttle will become very over-sensitive and the throttle plate will open and close, causing the car to buck very badly.
While this is happening, if i put the car into nuetral with no gas, it will stall out. Also if i can get the car to not stall out when in nuetral/clutch in, the rpms bounce up and down from almost dying to ~200rpms-1500 rpms. this is a random occurance, but i am sure its hydra / DBW related. The other issue i am having is sometimes i will get NO throttle response at all. I will be driving, everything is good and then ..Nothing. The gas just goes dead. Eventually it will come back, sometimes it doesn't. When there is no throttle response, the idle is at about 2k rpms and just kind of sits there. I am convinced this is a hydra problem and i know there was a recall for the 04/05sti hydra EMS. The ignition output switch is weak on the 04/05's and the hydra does not get the correct amount of voltage which leads to the "safe mode" which i think is what i randomly get into. I.E. the car is sitting at 2k rpms. If you have any input, please let me know! Thanks __________________
05-12-2007, 02:18 PM | #2 |
Member#: 108965
bump.
05-12-2007, 06:12 PM | #3 |
Member#: 108965
anyone.
05-13-2007, 09:38 AM | #4 |
Member#: 54918
Vehicle:673 WHP Element Tuning Pro Comp Engine |
It definitely sounds like your car is hitting the DBW failsafe mechanism. Now whether or not it's a Hydra issue vs a problem with voltage, grounds to the DBW system, or a sensor failing is what needs to be determined. Also make sure nothing is tapped into any of the DBW TPS signals such as those used for gauges, boost controllers etc, as the system is very sensitive so if one of the various sensors is tapped it can pull the voltage down enough to cause this problem.
What you can do and send us an email (not pm) with your serial number of your Hydra and based on that we can usually tell if an update to your Hydra may help. We made changes to the DBW range for older units in October of 2006. Thanks, Phil www.elementtuning.com |
05-13-2007, 09:44 AM | #5 |
Member#: 108965
Awesome, thanks Phil. Should i send the email to hydra-usa or to what email address.
This is posted on the hydra EMS forums as well in a little more detail if you want to look there. That thread also has my serial # etc... http://hydraems.com/forums/viewtopic...=54&highlight= |
05-13-2007, 04:07 PM | #6 |
Member#: 54918
Ok based on what I read in your other post you may not be getting enough voltage to the ECU to perform properly since replacing your battery fixed the problem temporarily. "Upload" your map and look at voltage reported by the Hydra on your tuning screen. If your alternator is bad and your car is basically running off the battery you can actually fry the electronics. Let me know what you see while the car is running, this is very important. You should see at least 13 volts when the car is running.
Box 117 is really old and is not likely to have the latest update but Hydra EMS would know when the last update was. If this is something that is happening consistently and out of the blue it's not likely an update will fix the problem. There is likely a problem somewhere that needs to be fixed. You could elimate the Hydra EMS by sending that email so Hydra EMS and test it along with updating the software and hardware. Based on what you are saying your sub and main TPS sensors are not maintaining the proper voltage span turning the failsafe on. When these sensors don't read consistently between the two the failsafe will cut the throttle. Like I had mentioned before tapping the TPS signal pulls the voltage down on one sensor only affecting the span. Make sure you don't have anything tapping into any TPS signal. Thanks, Phil www.elementtuning.com |
05-13-2007, 05:16 PM | #7 |
Member#: 108965
Thanks a bunch, Phil. I sent out an email to hydra usa and i am trying to find out where my gauges or anything might be tapped into. Any easy way of doing this?
I am going to check my voltage right now, but it seems that only sometimes the DBW issue occurs. I assume you want the voltage of when the issue is occuring. Thanks, Amit |
05-13-2007, 06:43 PM | #8 |
Member#: 108965
I Just drove the car for about 20 minutes or so and it drove great with no issues at all. I hooked up the Hydra and it read 12.5-12.6v. This is low according to you, but there were no DBW issues. This makes me very confused. Also my AFR was really low (through the hydra) ~11.1, but i am just assuming that is because i dont have a Wideband 02.
Thanks Amit |
05-13-2007, 09:17 PM | #9 |
Member#: 121108
International
Vehicle:2006 06 Spec C OBP |
welcome to the club.... I have the same problem. '06 EDM
05-13-2007, 09:21 PM | #10 |
Member#: 108965
Sorry to hear that, do you have any more information that you can throw into here to help us all out?
05-13-2007, 09:40 PM | #11 | |
Member#: 54918
05-13-2007, 09:45 PM | #12 | ||
Member#: 54918
Based on what you are telling me your car has some issues so stay focused on that and hopefully we'll come up with something to check out. I'm leaving the country for awhile so stay on course so I can help you before I have to hand you over to someone else for help. Thanks, Phil www.elementtuning.com |
05-14-2007, 03:32 PM | #13 |
Member#: 108965
No new parts recently, phil. Have been running this setup for a while now and the issue started a little while ago.
Is there anyway i can easily check to see if anything is tapped into the TPS sensor areas to bring down the voltage. Thanks alot for your help so far! -Amit |
05-14-2007, 10:09 PM | #14 |
Member#: 108965
This is rediculous. I just drove around for 30 minutes doing everything possible to replicate this problem. Nothing happend at all, the car drove great. Before the drive i unplugged the hydra harness and reconnected everything to make sure everything was tight. Maybe this had something to do with it?
Also when i go home, i hooked up the hydra and it read 12.5 volts. I turned on all the lights, the fog lights, and my system all the way up, and it was still between 12.5-12.6v. This is getting very frustrating. Amit |
05-15-2007, 09:34 AM | #15 | |
Member#: 101256
South East
Vehicle:2019 STI Red |
05-15-2007, 12:44 PM | #16 |
Member#: 108965
Yes, i am running the Blitz SBC-ID boost controller. Ill check it over hopefully today or tomorrow. Anyway anyone has a pinout or something of how the EBC would be hooked up?
Thanks Amit |
05-15-2007, 02:02 PM | #17 |
Member#: 54918
Of course it's "Murphy's Law." It's very possible it was something with the harness. It's very important to make sure everything is connected securely and that the kick plate isn't digging into the wiring harness. I have seen this a few times where the sharp kick plate can actually nick the wire sheathing and ground out the wire etc. It's possible by removing the plate, etc that you fixed your problem.
With that said 12.5-12.6 volts is an unacceptable amount of voltage for a running STI. It should be no less than about 13.3 volts even with your lights on an AC running. I really think you have a grounding issue somewhere, cut power cable(s), or an alternator that is on it's last legs. Thanks, Phil www.elementtuning.com |
05-15-2007, 03:36 PM | #18 |
Member#: 108965
Yes it has seemed to stop when i removed the cover. The hydra is just sitting there unprotected and no problems so far. I agree with the voltage issue, is there any way to test my alternator to see if it is going out?. Ill check all my grounds as well.
Thanks Amit Sharma. |
05-15-2007, 05:14 PM | #19 |
Member#: 101256
South East
I'm sure it wont be too hard to find the pinout for your year model STI. The boost controller will likely be tied into the TPS, vehicle speed sensor, rpm signal, and injector #1. There maybe one or two more or less. I've never installed that particular BC. Locate your installation instructions for your boost controller along with the appropriate ECU pinout and double check everything. Good luck!
05-15-2007, 10:47 PM | #20 |
Member#: 108965
Thanks a lot man. I will make sure to get the pinout etc... Tomorrow and the installation instructions.
Wish me luck. Amit |
05-16-2007, 09:08 PM | #21 |
Member#: 108965
Well, the Blitz SBC ID is not tapped into any TPS sensor so ti should not drag voltage down. I cant think of ANYTHING that would be. Ill check for grounds tomorrow.
Amit |
05-22-2007, 10:59 PM | #22 |
Member#: 108965
Well i went through a whole tank of gas without replicating the problem.
seems like it was either a lose harness which i reattached or the cover plate was grounding out a wire. amit |
09-21-2007, 12:12 AM | #23 |
Member#: 113734
South East
Vehicle:2023 FL5 Type R Subaruless |
Kinda sounds familiar but not exactly, now if I could jet get mine to work right
10-14-2007, 03:10 AM | #24 |
Member#: 108965
Sorry for the late response. What really ended up being the issue was a wire actually got pulled out of the harness. I had to resolder it into the harness and it worked as good as new. PM if you have any questions.
10-23-2007, 12:00 AM | #25 |
Member#: 110648
PRSIC
Vehicle:2005 Hydramist 35R82 93oct 479whp 456tq |
in the hydra harness?
Need help with bizarre DBW code/intermittent function | Big C | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 4 | 05-10-2010 12:18 PM |
Help with issue on this forum.....(Computer issue.) | JDMbyBlood | General Community | 5 | 10-30-2008 05:55 PM |
Hydra issues when stopped | MULEZSTI | Other Engine Management | 7 | 06-02-2008 12:06 PM |
Hydra issues Firmware upgrade?? | Pi7467mp | Other Engine Management | 3 | 09-13-2006 07:46 PM |
Help Hydra and stops.. | Sparcomx | Other Engine Management | 3 | 01-16-2006 01:15 PM |
