Old 11-09-2012, 12:46 PM   #9901
SkimSTI
Member#: 134785
2006 STi 413whp
PM Hobbs for mouth-hugs
Originally Posted by Verdugo View Post
I picked my favorites from my Formula DRIFT Irwindale coverage, and posted both links to all of the photos here...be sure to check it out! Our very own Andy (SkimSTI) shot for us as well, and you can find his photos on those links too!
http://forums.nasioc.com/forums/show....php?t=2430042
Was such a great event.....
SkimSTI is offline   Reply With Quote
Old 11-09-2012, 01:10 PM   #9902
Saleen326
Member#: 244991
I would upgrade to the D7000 purely for the fact that the AF motor is in the body instead of having to buy the AF-S lenses.
Saleen326 is online now   Reply With Quote
Old 11-09-2012, 02:06 PM   #9903
Jellynuts
Member#: 305774
2007 STi
CGM
Originally Posted by Jive Turkey View Post
okay so. i've been reading and my delicate brain cannot understand what the full frame vs regular run of hte mill slr thing is. do i spend money on an ew lens or should i upgrade my body, but then do my DX lenses that ihave now become useless? any suggestion would be great but i'm looking to either upgrade my D5000 to something better or i want to find a good 85mm...thanks fellas.
I'm a little late in replying to this but...
IMO, and purely on non-video perspective, I would choose full frame bodies before lenses.
I am by every means an amateur photographer, and only shoot for my own pleasure, but ever since I picked up my FF body, any (non-DX) lens I've shot with has been a magical experience. (I did end up selling all my DX lenses).
If you're a guitarist, I can use this analogy:
A quality guitar through a cheap amp will sound like crap.
A cheap guitar through a quality amp will sound good.
I am NOT saying that quality glass through a starter body will produce poor results. But I have found that my FF body is like a good amp and just makes everything more satisfying.
But when it comes to video, I have no experience :P
Jellynuts is offline   Reply With Quote
Old 11-09-2012, 02:29 PM   #9904
Verdugo
Member#: 15341
2012 Borderline Pro
Photographer of the Year
Again, it really depends on what you're shooting. If you don't shoot wide angle very often, then a full frame camera might actually be a bit useless, especially since the crop factor gives you more range on the telephoto end. That's why a lot of automotive photographers I know don't even have a full frame camera, but still produce very excellent results. A good example of this is Larry Chen at Speedhunters...he uses a Canon 1DX which isn't full frame (It's APS-H, which is in between APS-C and full frame), but his work really speaks for itself. He even shoots wide angle and still gets great results from his non-full frame camera.
Verdugo is offline   Reply With Quote
Old 11-09-2012, 10:16 PM   #9905
INKMAN
Member#: 267837
2014 Focus ST (ST3)
Tuxedo Black
Here's another one I was playing around with.
INKMAN is offline   Reply With Quote
Old 11-10-2012, 12:51 AM   #9906
Jive Turkey
Member#: 219492
would the lenses i have now be useless on the d7000 then?
Jive Turkey is offline   Reply With Quote
Old 11-10-2012, 01:56 AM   #9907
Saleen326
Member#: 244991
I'm not sure and hopefully someone can chime in and let us know because I'm rather interested in swapping my D5000 for the D7000 now after looking at the specs.
Old 11-10-2012, 01:41 PM   #9908
Verdugo
Member#: 15341
2012 Borderline Pro
The red's a little bright...maybe take the luminance down a little bit. I'd also probably move the car at tiny bit to the right and down in the frame. I would also chop out that electrical box and corresponding line on the wall.
Old 11-10-2012, 01:42 PM   #9909
Verdugo
Member#: 15341
2012 Borderline Pro
No your lenses will work perfectly fine on a D7000. Nothing to worry about there...the only issue will be if you move to full frame, because DX lenses will either force it to be cropped on the camera or you can set it without the DX crop, but then have to deal with really bad vignetting.
Old 11-10-2012, 02:52 PM   #9910
INKMAN
Member#: 267837
2014 Focus ST (ST3)
Tuxedo Black
I will give that a shot later. Cloning all that stuff out with LR4 is going to be a project!
Old 11-10-2012, 05:44 PM   #9911
INKMAN
Member#: 267837
2014 Focus ST (ST3)
Tuxedo Black
Well that was a challenge! It's extremely hard to do in Lightroom and takes a lot of trial and error. I like the way it came out though. I re framed it as you suggested and turned down the red luminance. I think the color is spot on now.
And here's another of the same shot you critiqued last time except this one has the right focus.
Old 11-11-2012, 10:37 AM   #9912
stoker68
Member#: 208185
2009 WRX 5-door
Dark Gray Metallic
Nothing spectacular, but I rather like this one I got of the clean car last night.
[IMG] _DSC0069_70_71_tonemapped-169-WM by David Burbank, on Flickr[/IMG]
And at a stop light (a little blurry for my liking):
[IMG] _DSC0080-4 by David Burbank, on Flickr[/IMG]
stoker68 is offline   Reply With Quote
Old 11-12-2012, 01:52 AM   #9913
Max713
Member#: 205845
Auto? Close enough
Looking for some critique on this one Armin.
Max713 is offline   Reply With Quote
Old 11-12-2012, 03:03 PM   #9914
Verdugo
Member#: 15341
2012 Borderline Pro
Both of these are looking really good, although in the second shot I'd clone out the dark spot in front of the driver's side front tire and the little tire mark in front of the passenger's side front tire. I also think the driver's side of the car in the second pic is a little too dark compared to the front.
Overall, I think you've reached a point where in order to take the next step forward in your processing, you've got to be able to use layers. If anything, this is a testament to the amount that you can do from solely within Lightroom, and that's really awesome.
Old 11-12-2012, 03:09 PM   #9915
Verdugo
Member#: 15341
2012 Borderline Pro
Honestly, I don't like the color and tones you've got going on in the first pic. The car and ground are decidedly purple...it's fine for the clouds in the sky to be that color, but together with the really vivid green grass you've got going, it's a bit too surreal for my tastes. There's some weird composition going on as well, since the extreme blurry foreground curves up to the right for some unknown reason. On top of all that, you've got random reflections in the rear bumper.
I like where you're going with the gauge shot and be bokeh looks gorgeous, but it just isn't sharp enough on the gauge. The red's really turned up high as well...I might try desaturating it a little and maybe even taking down the red luminance too.
Old 11-12-2012, 03:20 PM   #9916
Verdugo
Member#: 15341
2012 Borderline Pro
Originally Posted by Max713 View Post
Auto? Close enough
The lighting on the bike looks fine, but I've never been a fan of plain black backgrounds. This one in particular makes it seem like the bike is floating and not even on any sort of kick stand, and the shadows fade into the blacks of the background very easily. On top of that, you've got some weird debris on the ground that should've been cloned out.
Old 11-12-2012, 03:24 PM   #9917
Verdugo
Member#: 15341
2012 Borderline Pro
I went out last Saturday night to take some new pics of my friend's Evo, since he got a new Do-Luck front bumper. Which do you guys prefer...
Light Streak?
or...
No Light Streak?
Old 11-12-2012, 03:42 PM   #9918
platnumn
Member#: 91996
2009 Audi R8
06 WRX Ltd. - Sold
Light Streak?
or...
No Light Streak?
I prefer no streak, but I love the extra pop it gives the picture.
What IS the light streak?
platnumn is offline   Reply With Quote
Old 11-12-2012, 03:44 PM   #9919
Verdugo
Member#: 15341
2012 Borderline Pro
It was a truck that decided to unexpectedly interrupt my long exposure
Old 11-12-2012, 03:58 PM   #9920
SkimSTI
Member#: 134785
2006 STi 413whp
i am leaning towards non streaked image as well, Armin. i dont like the position of the streak being so close to the car... PLUS taking away from the beautiful night city scape you have there.
Old 11-12-2012, 04:03 PM   #9921
INKMAN
Member#: 267837
2014 Focus ST (ST3)
Tuxedo Black
Thanks! I completely agree with you, I definitely need Photoshop. The tri pod is coming soon. I was going to get it this week but I bought a flash instead.( not for automotive stuff) Multiple polarizations is my next move and hopefully will bring me to the next level. I love the results I've been getting with my 85mm. Awesome lens for under $400!!
Old 11-12-2012, 04:14 PM   #9922
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I also like the one without the streak. It takes away from the car and city scene.
I like the work you've been doing with Lightroom. I really need to get it and try it out.
On those two photos they look like they need to be rotated about a degree counter clockwise, but maybe that's just me...
xluben is offline   Reply With Quote
Old 11-12-2012, 04:25 PM   #9923
INKMAN
Member#: 267837
2014 Focus ST (ST3)
Tuxedo Black
Thanks! Yeah I played around with the level a lot because in the first photo the building is not level and in the second the ground line is also not level, so it kind of throws it off. I personally love Lightroom. I have learned a ton and it is so fast and easy to use, If you could do multiple layers and had better cloning capabilities it would be amazing but I guess that's what PS is for. I do feel like I've reached a limit with my photos as far as processing and I'm always wanting to learn as much as I can.
Old 11-17-2012, 08:54 PM   #9924
R3VOLUTION
Member#: 294879
2006 WRX STI
R3VOLUTION is offline   Reply With Quote
Old 11-19-2012, 07:35 PM   #9925
rsutton1223
Member#: 280744
2009 CTSV 1,216whp
Black Raven
I get to play with this car for a couple of days...more to come...
Lady in Red by rsutton198 | oneninty8.com, on Flickr
rsutton1223 is offline   Reply With Quote
Koji's Quick and Dirty DIY Guide (AKA Tips for the adventerous DIY newbie) Koji Interior & Exterior Modification 30 04-11-2009 11:31 AM
EJ25 to EJ25 swap, first time, good tips and tricks to know? Patrick Olsen Subaru Conversions 8 11-27-2006 10:14 PM
Tips & Tricks to a clutch install MRF582 Transmission (AT/MT) & Driveline 12 11-05-2005 03:39 AM
Band photography, tips and tricks? Matt A Off-Topic 7 08-18-2004 04:50 PM
Quick and dirty way to extract pdf files to word or publisher? ChosenWon Off-Topic 10 12-17-2003 10:18 AM
