Old 08-20-2007, 09:07 PM   #76
ghibli99
Member#: 90761
2003 S2000
Save the Manuals!
Probably been mentioned, but watch reflections on your shots, too. In some cases it can enhance, but in most cases, it takes attention away from the overall look of the car, and can obscure lines and other details. In this shot, I tried to find not only a good angle for the shot, but one that minimized environmental reflections on the car. Pulling your car away from a background can make a huge difference in terms of what is reflected not only on the side of your car, but on the roof, windows, and hood, too.
-Mike
ghibli99 is offline   Reply With Quote
Old 08-21-2007, 09:56 PM   #77
FD3SDriver
Member#: 132745
03 Mini Cooper S
Jet Black
Awesome write-up....def. seen some of your work before!
FD3SDriver is offline   Reply With Quote
Old 08-23-2007, 07:13 PM   #78
Okeyd57
Member#: 113271
2006 STi
Obsidian Black Pearl
Really helpful hints there Armin ! I will get a tripod, and I already have a stepladder ! Thanks a lot. Okey
Okeyd57 is offline   Reply With Quote
Old 09-05-2007, 07:17 PM   #79
davetrends
Member#: 158472
This thread is fabulous ... Im just wondering how better the pictures are before and after 'photoshop job' ?
Can you upload the original pictures before it processed with photoshop ?
I really curious about it especially with these pictures below.
Also what changes you made with photoshop other than the 'Frame' and 'Signatures'.
Again ... your pictures are fabulous ... Very good.
David @ Indonesia.
davetrends is offline   Reply With Quote
Old 09-05-2007, 09:02 PM   #80
Verdugo
Member#: 15341
2012 Borderline Pro
Photographer of the Year
David @ Indonesia.
Hi David,
I'd be happy to upload the "original" versions of these, however there are a few things to keep in mind.
1. I shoot in RAW format 99% of the time. This file format is called "RAW" for a good reason...it is simply the raw data that the camera pics up off the imaging sensor. That said, I obviously can't post a true raw image here, since it would need to be converted into JPEG. If I were to convert these to JPEG with all raw conversion settings set to zero, then the photos undoubtedly come out very dull, washed out, and unsaturated. Hence, this thread focuses on the photography element alone, and not the post-processing.
2. I won't upload the actual RAW file itself, since by doing that, I do give up my "digital negative" and thus, my copyright over the image.
3. 90% of my post processing is as simple as a bump in contrast and saturation. Occasionally, I'll use the shadow/highlight tool to bring out a little more detail, but that's about it. That said, I firmly do not believe if "straight out of the camera" photography. Why? Because that relies on your camera to do all the processing work for you, and I personally believe it's a cop-out not to actually spend just a few minutes to make your photo look better than it already was. Too often do I see a good photo that would be a spectacular photo if the photographer just spent about 30 seconds to adjust the contrast or saturation.
Now, having said that...here's a "straight out of camera" photo that I took yesterday here after work, since I shot these in JPEG mode instead of RAW. The only post-processing done to this is the resize, border, and signature...it's not even cropped properly:
And, here's some really old photos I took before I even know how to do RAW processing:
I hope this helps. The point is, I liken Photoshop to be an electronic version of doing the same kinds of things with chemicals in a dark room. No amount of chemicals or photoshop will magically turn a really crappy photo into a beautiful one
Armin
Verdugo is offline   Reply With Quote
Old 09-05-2007, 11:09 PM   #81
davetrends
Member#: 158472
Appreciated for your great reply. also thank you for same samples of your 'original' pictures. what you you mean by "shadow/highlight" ? I dont really get it. Do you simply blur or desaturate some of the spot to bring the focus into another parts ?
also for the orange/blue sky on the pic below .. was it real or photoshopped ? thnx again.
Old 09-06-2007, 12:30 AM   #82
robbieshonda
Member#: 122306
2002 Sti PTE 6262
Interlagos Blue 551/441
Probably around sundown but most slr camera leave the blue sky kinda grayish. So you can isolate the blue area of the sky and make the blue pop.
robbieshonda is offline   Reply With Quote
Old 09-06-2007, 01:43 AM   #83
Verdugo
Member#: 15341
2012 Borderline Pro
No problem. Shadow/highlight is a tool in Photoshop CS2 that allows you to lighten up some of the shadows or darken some of the overexposed areas. I don't do any blurring or desaturating (unless the entire image is desaturated)...that's all aperture and composition
The sky is completely real. It was taken right before sunset and it made the sky look absolutely perfect. The only thing changed in the sky was darkening it a little bit to make it pop a little more, but the colors are exact.
If you want to see a heavily photoshopped image, here's a good comparison:
vs.
Armin
Old 09-06-2007, 12:00 PM   #84
Ferg
built to spill
Member#: 14145
02 WRX BLOD
76 C30 Dually
A question to the pros and semi pros out there...
Have you ever been faced with a car that made you cry out loud, "Dear GOD, there is no trick I know that could make this thing look good!" And when faced with such a mountainous task how did you eventually find it's good side?
Ferg is offline   Reply With Quote
Old 09-06-2007, 01:23 PM   #85
Verdugo
Member#: 15341
2012 Borderline Pro
Ask the SoA photographers...I don't know how they do it with the 08...oh wait!
'Cause after all...I tried...and I think I failed...
Armin
Old 10-15-2007, 02:14 PM   #86
gc822
Member#: 81217
nice write up, I def need to improve on my picture taking skills. This helps a lot
gc822 is offline   Reply With Quote
Old 10-19-2007, 10:09 AM   #87
BluePearl04
Member#: 108569
04 STi
Originally Posted by Mopho View Post
I hope so, it was on the cover of Car and Driver
Thanks
I saw that photo and was like "I've seen that somewhere before." I should mail you the copy for an autograph!
BluePearl04 is offline   Reply With Quote
Old 11-24-2007, 01:56 AM   #88
code_hat
Member#: 90896
CO RallyX'er
circuitmotorsports.net
First time I've read this Armin. Excellent job and very precise. Hopefully everyone will use this as a resource.
code_hat is offline   Reply With Quote
Old 02-20-2008, 12:39 PM   #89
marrenr813
Member#: 135668
2015 WRX
thank you for this.
marrenr813 is offline   Reply With Quote
Old 03-08-2008, 11:11 PM   #90
SubieWReX
Member#: 151080
07 BME AutoX WRX
Awesome pictures man!
SubieWReX is offline   Reply With Quote
Old 03-12-2008, 12:05 PM   #91
luggnuttz
Member#: 115032
'03 WRX
Default After the Storm
On my way out to Blythe in prep for Desert Storm Rally and it was storming like crazy, then out the desert the sky just got beautiful. This wasn't taken in the best light (sunrise/sunset), but the sky was dramatic so i went for it. I have very little time in that I really can't choose when and where most of the time. CP filter is responsible for the sky, not a photo shop gradient.
taken with my 30D, Tammy 17-50mm f2.8, with a CP filter.
later
lugnutz
luggnuttz is offline   Reply With Quote
Old 03-12-2008, 12:47 PM   #92
Brainchild Customs
Member#: 127343
NCCA #1 Car '08
www.brainchildcustoms.com
[quote=Verdugo;19279701]
haha i love this pic of J-beard
Brainchild Customs is offline   Reply With Quote
Old 04-07-2008, 10:10 PM   #93
SubieGenius
Member#: 176874
2000 Impreza 2.5 Rs
SilverThorne
Cool
I am taking photography and although its not digital i love taking pictures of my car and developing them. Lighting and unusual angle are my fave! especially using filters or texture screens. No such thing as a perfect picture...Unless the subject is a scooby! lol
SubieGenius is offline   Reply With Quote
Old 04-29-2008, 02:24 AM   #94
NoLuck
Member#: 156798
Suggestions?
NoLuck is offline   Reply With Quote
Old 04-29-2008, 10:56 AM   #95
bmeyette
Member#: 178657
some really great tips & pics here. Thanks for posting them
bmeyette is offline   Reply With Quote
Old 05-02-2008, 06:28 AM   #96
Verdugo
Member#: 15341
2012 Borderline Pro
Originally Posted by NoLuck View Post
Suggestions?
First off, I'd probably turn the wheels a little to face the camera. The position of the car isn't bad, but I usually prefer to have it on the left side so that it look like it's moving toward the right. I'd also be aware of your surroundings...the caution tape doesn't look too great Finally, try getting a little lower
Old 05-23-2008, 05:02 AM   #97
HoMaR
Member#: 105595
'06 Impreza STi
SGM
Armin,
I love this thread you've started and have tried all the basic techniques you mentioned. However, I can never get the car to be as crystal clear in the picture as you do, and I've tried almost everything from dropping the ISO and opening the aperture up to holding a long shutter w/ tripod. Any suggestions? (using Nikon D60 w/ various ED VR lenses).
HoMaR is offline   Reply With Quote
Old 05-23-2008, 06:00 AM   #98
Verdugo
Member#: 15341
2012 Borderline Pro
Originally Posted by HoMaR View Post
Armin,
I'm glad the thread has been helpful so far. Can you post some sample photos so I can try to see what might be the problem? One thing to keep in mind is that shooting with a wide open aperture doesn't necessarily yield the sharpest results. Often times a lens is sharpest between f/5.6 - f/11, but it really does depend on the lens. You might also want to try using the Unsharp Mask filter in Photoshop to sharpen things up a bit. In any case, I'm happy to help.
Armin
Old 05-23-2008, 06:07 AM   #99
HoMaR
Member#: 105595
'06 Impreza STi
SGM
I know I completely ignored some of your rules, but this was the sharpest one I could find.
Thanks for your help!
Old 05-23-2008, 06:16 AM   #100
Verdugo
Member#: 15341
2012 Borderline Pro
Well, first off, they're not rules, they're tips...I don't make the rules, and if I said they were my rules, I'd be a conceited bastard
Second, I don't really see any problem with sharpness in that photo. You could try running the unsharp mask at say 35 and it'll sharpen it a little, but otherwise the photo looks just fine in terms of sharpness. Are you shooting at the maximum resolution and JPEG quality, or RAW for that matter? If you aren't, that's what I'd recommend. Sure, you save space on your memory card, but even if you shoot at max quality and then shrink down to a nice web size, the overall quality and sharpness of the photos is better than when you just shot the photos and uploaded without shrinking down.
Armin
Koji's Quick and Dirty DIY Guide (AKA Tips for the adventerous DIY newbie) Koji Interior & Exterior Modification 30 04-11-2009 12:31 PM
EJ25 to EJ25 swap, first time, good tips and tricks to know? Patrick Olsen Subaru Conversions 8 11-27-2006 11:14 PM
Tips & Tricks to a clutch install MRF582 Transmission (AT/MT) & Driveline 12 11-05-2005 04:39 AM
Band photography, tips and tricks? Matt A Off-Topic 7 08-18-2004 05:50 PM
Quick and dirty way to extract pdf files to word or publisher? ChosenWon Off-Topic 10 12-17-2003 11:18 AM
