Old 03-22-2013, 07:04 PM   #10376
Verdugo
Member#: 15341
2012 Borderline Pro
Photographer of the Year
Originally Posted by Jive Turkey View Post
on another note, can someone explain how i can make the photos where the car is squished but the wheels are big? i think its funny and looks good
That's just a bunch of Photoshop work. You basically have to cut out the car and the wheels from the scene and use the transform tools to squash the car and enlarge the wheels. Then, you paste it back into the scene (and probably have to clone out where the car used to be).
Verdugo is offline   Reply With Quote
Old 03-22-2013, 07:09 PM   #10377
Verdugo
Member#: 15341
2012 Borderline Pro
Originally Posted by INKMAN View Post
Got some unexpected snow during the shoot, so I went in a little different direction with these. I tend to shy away from the cooler tones but I think it worked well with these.
Looks great, the cooler tones definitely work well for this. Your side profile shot is the strongest of the bunch. I think you could crop the 3/4 shot a tiny bit to move the car a little more to the right in the frame, and your rear shot is just a tiny bit off center (you can tell by the side view mirrors).
Old 03-22-2013, 07:15 PM   #10378
Verdugo
Member#: 15341
2012 Borderline Pro
Originally Posted by jxlee View Post
Are a lot of you guys using reflectors for outside shoots? And is one usually enough or would you recommend having a couple?
So do you just deal with the shadows or use post processing to lessen/get rid of them? I just felt like having a reflector or two would save me time in photoshop by getting rid of a lot of the darker spots of the car.
I don't use a reflector for automotive photography, but I use it for people portraits. With automotive photography, you generally don't want to shoot from the shadow side in the first place, so you shouldn't have that problem to begin with. If I do have to shoot shadow side, I'll use multiple exposures to get the car, background, and (if needed) the foreground to the correct exposure, then combine them in post. Depending on your camera, you might not even need to do all that, since some cameras (like the D800) have ridiculously awesome dynamic range, and you can pull details out of the shadows by just processing a single raw file.
You can definitely use a reflector to achieve a similar effect, but you just have to make sure the lighting is even, which will normally require a pretty large reflector. Otherwise, you can use strobes to light up the areas that have shadows, but that also requires some post processing to even things out as well. I just personally prefer natural, ambient lighting and I don't really see it as being too difficult not to put yourself in a situation where you have to recover really dark shadows.
Old 03-24-2013, 10:12 AM   #10379
INKMAN
Member#: 267837
2014 Focus ST (ST3)
Tuxedo Black
First track day of the season was canceled so we had to keep ourselves busy
A couple more angles
INKMAN is offline   Reply With Quote
Old 03-25-2013, 02:38 AM   #10380
Thug Nastiy
Member#: 351309
2004 06STI swap vf34
Sedona Red
I need to go take some shots!
Thug Nastiy is offline   Reply With Quote
Old 03-25-2013, 02:43 PM   #10381
NCORWRX
Member#: 238919
007 LGT LTD
DGM stg1
Jeez, I can't go anywhere without seeing Armin's work! Cobb via FB has a very familiar looking bug-eye rolling shot
NCORWRX is offline   Reply With Quote
Old 03-25-2013, 03:26 PM   #10382
Let's Spool
Member#: 253231
2009 WRX Sedan SWP
1999 Legacy WarWag
Ok fellas, photo newbie here and I got a question... Just got my first dslr, a canon t2i, and it came with a 18-55 and 55-250 lens... Heading out to the NY auto show this week and looking to get some practice in, but I dont want to carry both lenses with me... I'm assuming the 18-55 will be better suited for this event?? Is this a correct assumption?? Also, any tips you have for me while I'm there in terms of settings, exposure, things to do not do, etc would be great... Thanks in advance!!
Let's Spool is offline   Reply With Quote
Old 03-25-2013, 04:02 PM   #10383
luan87us
Member#: 335013
2013 Premium WRX 5dr
I'm a newbie too but those 2 lens are pretty much the same. Just different length of zoom. I would suggest the 18-55 if it's indoor. Should be more than enough zoom.
Also just got a good deal on the Canon T3i with the 18-55 kit lens. Pretty excited to finally start this hobby I've been putting aside.
luan87us is offline   Reply With Quote
Old 03-25-2013, 08:41 PM   #10384
cvananden
Member#: 326698
2006 WRX Ltd.
San Remo Red
Use the 18-55 lens and set your camera to aperture priority. I think it says a/v on the setting dial.
This may help you to learn a little more while keeping you out of automatic and manual modes.
If your zoom isn't an image stabilized lens and if its like a 4 - 5.5 aperture, it'll be real tough to get a nice shot without a steady hand.
Also, look into getting the 50mm prime lens. The 1.8 is $100. Worth it if you don't want to spring for the 1.4 and 1.2
cvananden is offline   Reply With Quote
Old 03-26-2013, 09:01 AM   #10385
luan87us
Member#: 335013
I've been thinking about that 1.8 lens. Might be able to get it from someone locally for $70-$80. Would you recommend it as a low budget automotive photographer/videographer?
Old 03-26-2013, 09:28 AM   #10386
cvananden
Member#: 326698
2006 WRX Ltd.
San Remo Red
I'd get it. On your camera (mine also) we have cropped cameras. So it will function as about an 85mm.
You'd be shocked how useful that lens can be. As for using it specifically for auto, I'm bit sure of its benefits and I'm sure someone else here can answer that much better (I'm just starting to get into auto photos).
I'm sure if you Google image it, you'll see some results.
Old 03-26-2013, 03:44 PM   #10387
luan87us
Member#: 335013
Found some on BH for around $70 so I think I'll get it. Since it does produce much sharper image. Luckily bunch of my friends are using Canon cameras so I can borrow some of the nicer and more advance lenses when I get better
Old 03-26-2013, 05:00 PM   #10388
urbannerdmario
Member#: 335286
2005 Impreza WRX
the 50mm 1.8 is an awesome lens, but it does suck sometimes when your shot is limited by space.
urbannerdmario is offline   Reply With Quote
Old 03-26-2013, 07:06 PM   #10389
luan87us
Member#: 335013
Yeah when I used my friend T3i with the 50mm 1.4 lens it was pretty annoying because I have to stand pretty far away from my car lol. But I'll mostly do outdoor shoots so I should be fine. Plus I'll just throw the 18-55 on if I don't have a lot of space to work with. The differences shouldn't be too obvious on 720p video.
Old 03-27-2013, 12:03 AM   #10390
HAMTRAC
Member#: 232519
Couple quick edits from today's trip up to Cades Cove and the Tail of the Dragon from Gatlinburg
HAMTRAC is offline   Reply With Quote
Old 03-27-2013, 09:32 PM   #10391
INKMAN
Member#: 267837
2014 Focus ST (ST3)
Tuxedo Black
I really like the composition of the last two. Did you leave the reflections on the windshield there on purpose?
Old 03-28-2013, 12:51 AM   #10392
HAMTRAC
Member#: 232519
nope, no polorizer with me
Old 03-29-2013, 04:34 PM   #10393
rsutton1223
Member#: 280744
2009 CTSV 1,216whp
Black Raven
What 1300whp looks like...
1300+ hp On The Move by rsutton198 | oneninety8.com, on Flickr
rsutton1223 is offline   Reply With Quote
Old 03-29-2013, 08:19 PM   #10394
07LegacyGT
Member#: 155111
2011 WRX
photo looks great, would of liked to see it going straight though, because its weird that its turning into the building, but moving along side i think would look better..just my .02 cents
07LegacyGT is offline   Reply With Quote
Old 03-29-2013, 08:20 PM   #10395
rsutton1223
Member#: 280744
2009 CTSV 1,216whp
Black Raven
I have straight shots. The wheel company needed it at an angle and I didn't get the car when I needed it.
Old 03-29-2013, 10:39 PM   #10396
07LegacyGT
Member#: 155111
2011 WRX
well that explains it...for the record i wasn't commenting on the shot in any way, shot looks great haha
Old 03-31-2013, 10:30 AM   #10397
INKMAN
Member#: 267837
2014 Focus ST (ST3)
Tuxedo Black
Old 04-01-2013, 09:03 AM   #10398
rsutton1223
Member#: 280744
2009 CTSV 1,216whp
Black Raven
Oh I didn't take it that way at all! It's all good. I thought the same thing...
Old 04-01-2013, 04:37 PM   #10399
DNut
Member#: 151739
Two from a recent photo shoot with a Ford Taurus SHO that I'm trying to decide between.
Not sure if I prefer the top one or the bottom one.
The top one fills the frame more and has a slightly more interesting angle, but I don't know if there's too little space on the left and bottom.
The bottom one gives the car a little more room, but I wish that orange fence on the right wasn't there...
Oh yeah, and "buy a circular polarizer". I know!
DNut is offline   Reply With Quote
Old 04-01-2013, 05:08 PM   #10400
urbannerdmario
Member#: 335286
2005 Impreza WRX
SO GOOD!
i wish there were roads like this in so cal :/
Koji's Quick and Dirty DIY Guide (AKA Tips for the adventerous DIY newbie) Koji Interior & Exterior Modification 30 04-11-2009 11:31 AM
EJ25 to EJ25 swap, first time, good tips and tricks to know? Patrick Olsen Subaru Conversions 8 11-27-2006 10:14 PM
Tips & Tricks to a clutch install MRF582 Transmission (AT/MT) & Driveline 12 11-05-2005 03:39 AM
Band photography, tips and tricks? Matt A Off-Topic 7 08-18-2004 04:50 PM
Quick and dirty way to extract pdf files to word or publisher? ChosenWon Off-Topic 10 12-17-2003 10:18 AM
