Go Back   NASIOC > NASIOC Classifieds > Private Vehicle 'For Sale' Classifieds
Old 05-14-2007, 09:49 PM   #1
MRX WRX
Member Sales Rating: (17)
Member#: 114566
2005 STI
aspen white
Default beautiful 93 FD RX7 FS
Silver 1993 RX-7 FD, Single-Turbo
Here’s an overview:
1993 base model.
One owner - Bought new in Houston.
Adult owner. Never abused. No drag or street racing, just occasional high speeds on the open highways when it’s safe.
Garaged and pampered.
Top-quality components and maintenance.
There is very little you could do to improve the performance of this car and keep it streetable. I have spent over $25,000 since 2002.
Although I haven’t raced this car, it was built to race. Marcus Williams built this car to be reliable and very fast. He is a designer, mechanic, and racer who has built many race and street cars. Here’s what he says: “As it is setup right now very few cars (if any) should give you any problems. This car will run at least a 12.20 the way it sits at 15 psi on pump gas. Without changing anything but sticky drag tires it will probably run 11.7's with ease. Turn the boost up to 20 and you will get into the 11.2/3's. Install a KAAZ, axles, 75 nitrous shot, and 23 psi and you are in the 10's. But keep in mind that to run anything over 18 psi you will need more injectors and I don’t think the PFC will go that high with its MAP sensor.”
So here are the details:
Original silver paint with fine black and red pinstripe down each side.
Paint has a couple of small nicks and tiny scratches but otherwise very clean and shiny.
Couple of minor bumps over the years that were professionally repaired by River Oaks Paint and Body (they do all work for the Jag and Mercedes dealers). No accidents.
Black interior. Black plastic on driver armrest has the usual scratches.
Black leather seats. Replaced the cloth seats when I bought the car new. Have new leather seat covers to replace the current ones. Driver seat has wear on left bolster. Passenger seat is like new.
New black floor mats (not Mazda).
Engine and suspension by Marcus Williams of Williams Tuning.
Engine rebuilt at 67,000 miles in 2002. Current mileage = 79,700. $11,970
Front and Rear Rotor Housings, new $1318
2 piece carbon 3.1 mm apex seals
Street port
Viton oil seal rings and hylamar coolant seals, solid thermal pellet
Everything else remains oem.
Turbo: Rebuilt by Majestic Turbo 12/2003
Garret 62-1 with a 4" inlet
to4e "large mouth" compressor housing
"P" trim turbine wheel on center
.96 a/r "on center" exhaust housing
360 degree race bearings
Header: Equal length stainless
Down pipe: 4" high flow
Intercooler: RotarySC front mount
Blow off valve: Tial
Wastegate: Tial 40mm
Fuel system: Bosch pump in the tank with-6 AN feed line. Adjustable fuel pressure regulator and under the hood fuel pressure gauge Sized for nitrous and 500+HP.
Injectors: RC engineering 1300cc secondaries, stock primaries
Ignition: HKS Twin Power Ignition + harness* $469
NGK '9's plugs with NGK wires
HiPerCoat ceramic coated turbine housing
HiPerCoat ceramic coated down pipe
Turbonetics turbo heat shield $73
Greddy Upgraded Piping for Greddy Intercooler
Fluidyne radiator $700
Evans NPG+ waterless 0 psi coolant $25/gallon
New water pump
New stock thermostat
Filler vents directly to new stock overflow tank (no AST)
New relays for radiator fans $185
Two push fans installed on radiator for extra cooling.
Stock water pump pulley installed. Have smaller anodized pulley
New hoses
APEX’i Power FC ECU $1,150
APEX’i AVC-R Digital Boost Controller $400 Controller is ceiling mounted.
DEFI 52mm Boost Gauge (Black Face) @ 240
DEFI 52mm EGT Gauge (Black Face) @ 215
Defi-Link Control Unit
Autometer Dual Gauge Pod @ 33
Greddy turbo timer and harness $110
Random Technology 3” Hi-flow catalytic converter
Racing Beat Dual Tip Stainless Steel Exhaust $515
Broward 6-puck clutch, ACT pressure plate, throw-out bearing, release cyl - new 5/2004 $950
Clutch release fork
Pilot Bearing
Tein EFDC Flex shocks with EDFC (Electronic Damping Force Controller) to adjust the shock stiffness from inside the car. Front and rear shocks adjust separately. Three memory settings. Controller is ceiling mounted. 16-step adjustment. Pillow ball mounts. $1755 plus install
PFS sway bars with urethane bushings and mount braces $250
Cusco front strut tower 40mm D-bar $174
Widefoot heavy-duty front swaybar mounts, powder-coated $290
HYPERLINK "http://rx7.com/store/rx7/fdsuspension.html" \l "rptrailinglink" M2 Performance competition trailing arms and HYPERLINK "http://rx7.com/store/rx7/fdsuspension.html" \l "rptoelink" toe links $420 plus install
Steering rack, new
Widefoot heel-toe shift Gas Pedal Adapters. Heel and toe shifting makes this car a blast to drive. $56
Mazdaspeed Short Shift Kit @ $289.00
Stainless Steel Braided Brake Lines $120
EBC Greenstuff brake pads $150
Speed-bleeders
SSR De Colte Evolution-R wheels with satin spokes $1500
Wheels trued and polished by WheelCrafters-IMC $368
Yoko A032R tires - almost new - 245/45/17 F** 275/40/17 R These are the widest wheels and tires that will fit without rubbing. $720
Headlight wiring upgraded with Daniel Stern Headlamp Relay Installation Kit (12ga wire: 40A relays with dual output terminals, relay brackets/terminal blocks, terminals, extra-tough fused fuseholders and extra-tough headlamp sockets) Stock headlights are very bright now.
New alternator with stock and undersize pulley, $145
New small Honda 51R 650W battery
Jeff Hoskins stainless steel Honda 51r battery tray. $125?*
Air conditioner, new low and hi-pressure hoses + service $625
Tint on rear deck and side windows, 4/02 $120
Eclipse 54400 CD Receiver $346
XM Radio, custom mounted in ashtray console with 5 years prepaid XM service
Pioneer TSD608R 2-way rear speakers
Power antenna, new
Additional Konig V-Racing Jolt Pro fixed recline racing seat on RX-7 FD OEM seat rails. Simply unbolt the stock seat and bolt in the racing seat. You can slide fwd/bkwd but no reclining $300
1993 Workshop manual, small format, good condition $30
1993 Electric manual (also in workshop manual), large format $20 ?
These are numbers below are from you original build. The numbers above are the build plus extras I could find receipts for.
?engine 3350.00
when i quoted this i could cut the rotors my self but i had to send them out and it cost 350.00
?labor to R+R motor 1000.00?
front mount i/c (installed) 1700.00?
header 500.00?
turbo 950.00?
downpipe 300.00?
wastegate 400.00?
fuel pump (system) 1300.00?
1200cc injectors(installed) 500.00?
pullies (installed) 175.00?
midpipe (estimate) 300.00?
misc(hoses,fluids* etc etc) 150.00
dyno tuning 250.00 (with dyno charges)
tial blow off valve 300.00
air filter 25.00
surge tank 100.00
motor mount 270.00
crane Hi6 ignition 200.00 installed
strut tower bar 200.00 (est)
labor on gauges n/c
labor on PFC n/c
heat shields n/c
new pilot bearing n/c
total 10875.00
additional items
air filter 25.00
surge tank 100.00
motor mount 270.00
labor on gauges n/c
labor on PFC n/c
heat shields n/c
total 1095.00
prev total 10875.00
new total 11970.00
deposit 1 5000.00
deposit 2 1000.00
balance 5970.00
the car got some bad gas and busted an apex seal so it needs a motor (around 3k+) owner has outgown the car. last dyno it made 393 [email protected] on pump gas. asking 13k obo email for pix at [email protected]
MRX WRX is offline   Reply With Quote
Old 05-15-2007, 09:47 AM   #2
MRX WRX
Member#: 114566
2005 STI
aspen white
morning bump
Old 05-16-2007, 09:22 AM   #3
RingU
Member Sales Rating: (9)
Member#: 137243
2004 2.5L WRX JPB
1999 Civic EX White
Default Fd
Hi, are you looking for a trade? I got a 2004 subaru wrx.
RingU is offline   Reply With Quote
Old 05-17-2007, 12:02 AM   #4
MRX WRX
Member#: 114566
2005 STI
aspen white
sorry, owner just wants to sell
Old 05-29-2007, 10:20 AM   #5
MRX WRX
Member#: 114566
2005 STI
aspen white
price has dropped to 12k OBO, owner wants to move it!
Old 05-30-2007, 05:50 PM   #6
runvusofme
Member Sales Rating: (58)
Member#: 73942
2004 WRX STi JBP
Back to mostly stock...
I read this whole post with utter joy until....
...so it needs a motor
You could have put that up top and saved me some time
runvusofme is offline   Reply With Quote
Old 05-31-2007, 12:00 AM   #7
MRX WRX
Member#: 114566
2005 STI
aspen white
they are pretty much disposable motors 2800 from the dealership with a warranty!!
Old 05-31-2007, 12:04 AM   #8
amukaoen
Member Sales Rating: (21)
Member#: 62595
04 WRX Cobb S2
World Rally Blue
no pictures?
amukaoen is offline   Reply With Quote
Old 05-31-2007, 12:00 PM   #10
bessie
Member Sales Rating: (4)
Member#: 76360
2008 FXT
I must be poor because 2800 is not disposable to me. I need a better job it seems...
bessie is offline   Reply With Quote
Old 05-31-2007, 12:04 PM   #11
amukaoen
Member#: 62595
04 WRX Cobb S2
World Rally Blue
2800 isn't that disposable when with just a little bad luck it could blow again.
IL: 93 fd rx7 twin turbo zandman Private Vehicle 'For Sale' Classifieds 4 05-17-2010 02:13 AM
The MAPerformance 4g64 Powered FD RX7 Project Overview maperformance Member's Car Gallery 40 10-04-2007 05:01 PM
FS/FT AR: 93 FD w/ LS1 swap Kendon Private Vehicle 'For Sale' Classifieds 54 02-11-2007 07:15 PM
Found some pics of my old FD RX7 + Rouges Brighton when new Beer:30 Off-Topic 8 01-04-2007 02:01 PM
FS/FT 93 Mazda RX7 R1 ****LOOK*** mkbvictory Private Vehicle 'For Sale' Classifieds 5 11-19-2005 03:00 AM
