Old 12-18-2001, 07:42 PM   #1
WFO
Member#: 13041
2002 WRX Wagon
Default wrx wagon rear pass window not working
Just got my wagon back from the dealer after having the fake carbon trim put on.
Now the passenger rear window doesn't work...maybe a coincidence, but?
Seemed like the switch was kind of bound up in either the up or down
position. If a window switch was stuck in the up or down position....could
that burn out the motor? I took the carbon plate (which house's the switch)
off. The carbon piece holds the switch and simply pops out of the door.
Doesn't look like you could screw up installing this carbon piece if you
tried....but somehow, like I mentioned the up/down switch was kind of
stuck......feel's fine now that I popped it out and reinstalled, but the
window doesn't work.......back to the dealer I guess, Damn that sucks.
WFO is offline   Reply With Quote
Old 12-18-2001, 08:29 PM   #2
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
Does the window work from the master driver's control?? And is the switch that turns off the passenger window controls set to ON??
Alan is offline   Reply With Quote
Old 12-19-2001, 01:26 PM   #3
WFO
Member#: 13041
2002 WRX Wagon
Angry
Sorry, probably should have mentioned that. No, the master switch won't operate it either.....and the "lock out" button was the first thing I checked.....that's not it either.
Old 12-19-2001, 01:38 PM   #4
SubEd
Member#: 717
He probably unplugged the wires from the switch on the door and forgot to plug them back in. Easy for you to fix (remove trim and check), or you could bring it back.
Ed
SubEd is offline   Reply With Quote
Rear Power Windows Not Working? weiders Electrical & Lighting 1 05-26-2007 10:30 AM
FS: Prodrive Headlights & '03 WRX Wagon Rear Pass Door AdamRX Tri-State Area Private Classifieds 15 03-06-2007 01:23 PM
wrx wagon rear window spritzer jarnold Service & Maintenance 4 01-06-2003 03:29 PM
Power windows not working! BlueScooby General Forum Archive 8 03-27-2001 12:36 AM
power windows not working!! BlueScooby New England Impreza Club Forum -- NESIC 4 03-25-2001 05:38 PM
