Old 01-24-2008, 04:50 PM   #76
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Originally Posted by BIGSKYWRX View Post
did the GGB run Brembos front and FHI two pots rear or FHI 4/2 pots?
Red FHI 4/2pots. They were also running the narrower 17x7" gold wheels(we usually call them the UK WRX wheels.)
ss
subysouth is offline   Reply With Quote
Old 01-24-2008, 05:20 PM   #77
BIGSKYWRX
Member#: 7958
09 GH B+
thank you Sir
Old 01-25-2008, 03:21 PM   #78
drivingkingwrx
Member#: 76958
Default 03 WRX STi COnversion
OK, Other than the Calipers and rotors from an 05 Sti, what else do I need for the conversion? Thanks!
drivingkingwrx is offline   Reply With Quote
Old 01-25-2008, 03:24 PM   #79
drivingkingwrx
Member#: 76958
sorry, 04 rotors and 05 calipers, but what about the back, I've seen the swap before
Old 01-25-2008, 04:10 PM   #80
KNS Brakes
NASIOC Storefront Vendor
Member#: 125739
2015 WRB WRX
Need Brakes? 919.420.0021
Brackets to relocate the Brembo caliper
And either:
Oversize park brake pads or
DBA rotors made to fit the smaller park brake drum.
KNS Brakes is offline   Reply With Quote
Old 01-25-2008, 05:55 PM   #81
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Read the STi Brembo FAQ
http://forums.nasioc.com/forums/show....php?t=1432536
Old 01-29-2008, 06:10 AM   #82
DBAsteve
Member#: 16839
Originally Posted by dan_m View Post
Steve, if I understand correctly, in order to mount rear brembos on my 2005 USDM LGT I would need rotors #2657 ( post 38 ) plus those special kartboy brackets, is that correct?
Yep!
That's correct.
STi rotor dimensions with 170mm hand brake bore
DBAsteve is offline   Reply With Quote
Old 01-30-2008, 06:58 PM   #83
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Originally Posted by DBAsteve View Post
Yep!
That's correct.
Im sure youve heard it already, but thats a great product.
ss
Old 02-05-2008, 06:53 AM   #84
DBAsteve
Member#: 16839
Originally Posted by jamal View Post
Was looking back over this.
Anyone know anything about the RA-R, or 08 STi brakes? Oh and they have new group N rally brakes too, right?
Mr. DBASteve, would you happen to have a spec sheet for the 5x114.3 294x24mm rotor that's used for rally?
Also I think I'm missing some newer Legacy/Outback/08 Impreza pad shape information.
The RA-R is 294mm x 24mm with 114.3mm PCD
The 114.3mm PCD hub has a larger mounting face so the current stock rotor wont fit over the hub. We should have some more info soon. Sample's on a plane from Japan.
Old 02-05-2008, 06:54 AM   #85
DBAsteve
Member#: 16839
ss
Thank you.
Old 02-05-2008, 03:52 PM   #86
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
Originally Posted by xdrian View Post
the 2008 sti rotors and calipers are still the same i believe, just looked on their website.
Brake discs Front: 12.7 in./Rear: 12.3 in.
The front rotors of the '08 Sti have definitely increased in size. I've only seen the diameter (13.0") reported so far. I guess that would make them 330 mm, but 25.4 or what? Also, I don't know if this was a hub change or a caliper change, but I would bet hub change with the new car.
Frank
Frank A is offline   Reply With Quote
Old 02-05-2008, 04:43 PM   #87
jamal
Member#: 71875
98 2.5GT
my wheels fit
These:
Are only 294mm?
Frank
I've been hearing 12.7" quite a bit so far and Harman already put aftermarket rotors and pads on their car that I assume were meant for an 05-07. They'd also be at least sa thick as the old rotors which are 30mm.
jamal is offline   Reply With Quote
Old 02-05-2008, 06:49 PM   #88
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
Geez Subaru! The press seems to have received some bogus literature. Both here on Nasioc and in C&D and Motortrend, the new car has been reported with 13.0-f/12.6-r rotors. Now when I check the SOA site, they are listing the car with 12.7" rotors. I would have been happy with larger rotors- the EVO comes with 13.8" rotors for cripes sake!
Frank
Old 02-05-2008, 08:13 PM   #89
rougeben83
Member#: 115154
2005 Outback XT
White on grey
The EVO X also weighs 3500lbs... maybe there's a reason it needs that extra rotor material...
rougeben83 is offline   Reply With Quote
Old 02-05-2008, 09:02 PM   #90
BIGSKYWRX
Member#: 7958
09 GH B+
These:
Are only 294mm?
No he's talking about the spec C gravel package- think Group N car
Old 02-05-2008, 11:35 PM   #91
jamal
Member#: 71875
98 2.5GT
my wheels fit
Oh, I was asking about the brakes in the picture.
Old 02-06-2008, 12:06 AM   #92
BIGSKYWRX
Member#: 7958
09 GH B+
this is what he was probably answering
Old 02-27-2008, 12:44 PM   #93
stoke
Member#: 164513
2001 2.5RS+EJ20+VF34
'13 WRX Special Ed
Just to clarify, for the '06/'07 WRX with 2-pot rears used the 170mm parking brake, correct? So the '06 backing plates will work with the stock 170mm brake on my '01 2.5RS, and I can bolt the 2-pots right on with working parking brakes?
Thanks!
stoke
stoke is offline   Reply With Quote
Old 02-27-2008, 02:02 PM   #94
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Thanks!
stoke
Well you can bolt the 2pots onto the 06-07 rear backing plates if youve installed those plates onto your car, including transferring your rear parking brake internals to the new plates. Getting the 06-07 backing plates onto your car is a whole separate operation and not easy. Thats why companies like Kartboy fabricated adapter brackets to bolt onto your stock rear backing plates to which you bolt the 2pot calipers.
ss
Old 02-27-2008, 04:44 PM   #95
stoke
Member#: 164513
'13 WRX Special Ed
ss
Thanks! I also just got confirmation from the guys at Rallispec that this is the case- the 170mm parking brake does fit the '06-'07 brake setup. You're also right that the backing plate swap isn't easy, but I'm having a shop replace my wheel bearings so it makes sense to have them install the new rear brake setup as long as the rear hub and knuckle assembly is torn apart.
Thanks to everybody for a great, informative thread.
stoke
Old 05-03-2008, 12:32 AM   #96
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
was part of the 02-to-03 WRX brake change a change in the bracket bolt thread pitch? In other words, on my early '02 car the 17mm bolts that hold the front caliper bracket onto the hub housing are 12x1.25 pitch. Did subaru change to a 12x1.5 pitch for the '03 and up?
Frank
Old 05-03-2008, 12:40 AM   #97
BIGSKYWRX
Member#: 7958
09 GH B+
I highly doubt it, FHI bolts are typically JIS and for 12mm this means 12x1.25
Old 05-03-2008, 12:48 AM   #98
jamal
Member#: 71875
98 2.5GT
my wheels fit
I think the brembos and possibly 4-pots have a different pitch but I'd assume all the sliders are the same.
Old 05-10-2008, 04:00 AM   #99
WRXEcho
Member#: 96372
2002 WRX Wagon 4EAT
So from what I gathered from reading the entire thread, and just for clarification...
To swap (06-07) 2-pot rears onto an 02 wrx wagon, I would need the (06-07) 2-pots, Kartboy brackets, (06-07) rotors, and compatible pads? That's it?
I wouldn't need the (06-07) backing plates if I had the Kartboy brackets? Therefore I wouldn't need bearings and all that extra jazz that I really don't feel like trying to attempt?
Correct?
Thanks a mil, this thread is exactly what I was looking for!!!
WRXEcho is offline   Reply With Quote
Old 05-10-2008, 05:15 AM   #100
jamal
Member#: 71875
98 2.5GT
my wheels fit
yes, exactly.
Tribeca Brake/Suspension technical information THAWA Tribeca Forum 5 03-31-2006 11:07 PM
Looking for thread that contains information on Clearence of Stop Tech Big Brake kit MooseWRX Brakes, Steering & Suspension 4 02-22-2004 05:24 PM
brake upgrade information STEALTH-WRX Brakes, Steering & Suspension 43 03-11-2003 02:31 PM
Outback owners: brake information needed! bagio Legacy Forum 1 08-02-2002 04:47 PM
Outback owners: brake information needed! bagio Brakes, Steering & Suspension 1 08-01-2002 06:24 PM
