Old 05-10-2008, 11:02 AM   #101
BIGSKYWRX
Member#: 7958
09 GH B+
I'll add that you will remove your existing dust cover that is riveted to your current backing plate- simply drill the rivets out, pop it off and spray a little paint where you drilled to insure no rusting
Old 05-20-2008, 02:05 PM   #102
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Old 05-20-2008, 05:29 PM   #103
jamal
Member#: 71875
98 Legacy GT
my wheels fit
Oh yeah, I noticed that the 08 has the same front pads as 03-05 the other day.
Rear rotors, according to my info, are 286x10.
That 274mm rotor seems to be on all 05+ non-GT Legacys/Outbacks.
I wonder what the regular 08 impreza has. Or is it only available with drums?
Here's a handy brake pad shape spreadsheet I got from EBC:
http://jamalb.net/stuff/Subaru%20dplates.xls
jamal is offline   Reply With Quote
Old 05-31-2008, 10:47 PM   #104
el tekk-O
Visiting NASIOC Timeout
Member#: 65223
2002 WRX-6 speed
130000 miles
are all rear 04 sti rotors teh same? i went to a dealership to buy rear rotors and they said they needed a vin. i dont have a vin because i just bought the 04 sti tranny and rear end from someone. i know the bolt pattern is 5x100...
el tekk-O is offline   Reply With Quote
Old 06-01-2008, 02:24 AM   #105
jamal
Member#: 71875
98 Legacy GT
my wheels fit
no they are all the same. Some parts counter guys will just refuse to do anything without a vin mostly because they're lazy.
Old 06-01-2008, 05:58 AM   #106
Butt Dyno
Member#: 17301
is the "dark side"
What's up with Dealer Parts Dept needs VIN?
http://forums.nasioc.com/forums/show...&highlight=vin
Old 06-02-2008, 03:35 PM   #107
el tekk-O
Member#: 65223
2002 WRX-6 speed
130000 miles
oh no wonder, it was a woman
Old 06-08-2008, 07:09 PM   #108
DAV3_02
Member#: 170269
IS CAR-LESS
RIGHT NOW!
im hoping someone can help me out here, are 02 wrx rear calipers the same left to right? meaning i could swap them and there would be no fitment problems.
DAV3_02 is offline   Reply With Quote
Old 06-08-2008, 08:56 PM   #109
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
No the bleeder screws have to be located up so the sides are directional.
ss
subysouth is offline   Reply With Quote
Old 06-08-2008, 09:08 PM   #110
DAV3_02
Member#: 170269
IS CAR-LESS
RIGHT NOW!
thank you!
Old 06-12-2008, 07:28 AM   #111
DBAsteve
Member#: 16839
Hot off the press!
Sorry guy's!
I think our catalogue dude has been smokin the gunji weed.
I will post the correct data as soon as it has been verified.
DBAsteve is offline   Reply With Quote
Old 06-12-2008, 09:31 AM   #112
BIGSKYWRX
Member#: 7958
09 GH B+
Hi Steve
What market gets 316 mm, four pots on the WRX? damn
Old 06-12-2008, 09:33 AM   #113
KNS Brakes
NASIOC Storefront Vendor
Member#: 125739
2015 WRB WRX
Need Brakes? 919.420.0021
Originally Posted by BIGSKYWRX View Post
Hi Steve
My question as well
KNS Brakes is offline   Reply With Quote
Old 06-12-2008, 02:27 PM   #114
iluvdrt
Member#: 46248
82 Brat
Tan
Will the 4 pots fit on under the Legacy GT (98) stock 16" wheels? I have a good chance to get some for free, with rotors, and brackets. in exchange for my 2 pots.
Also what about the rears?
iluvdrt is offline   Reply With Quote
Old 06-12-2008, 06:57 PM   #115
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
95 impreza FWD base model for the win. 1pot fronts w/smallest rotor and drums in the back. eventually ill have subaru 4/2 pots... when i convert to awd
great thread, i'm sure ill reference it plenty
elislider is offline   Reply With Quote
Old 06-13-2008, 05:13 AM   #116
jamal
Member#: 71875
98 Legacy GT
my wheels fit
Thanks a lot for the info Steve. But yeah what's up with the 316mm rotors?
Old 06-13-2008, 09:31 AM   #117
BIGSKYWRX
Member#: 7958
09 GH B+
316x30 is the LGT rotor size, but it says four piston on the chart
Old 06-16-2008, 06:09 PM   #118
Wannabe WRX
Member#: 130623
1998 Legacy L
Green
I just wanted to add a few pennies here, although this may have already been covered elsewhere (although it is not listed in the FAQ).
There are FWD Imprezas, mostly the LS and some LX models, that come with rear discs, both in ABS and non-ABS models. Incidentally, the Rear Discs for the FWD Imprezas also come in 4x100 and 5x100 patterns (some of the first generation Imprezas came in 4 or 5-bolt). If one can source a rear-disc equipped FWD Impreza, they may get an RSB out of the deal, too. But the drum-to-disc requirements still stand, it's just that the source pool is a little larger.
Hope this is of some use.
Wannabe WRX is offline   Reply With Quote
Old 06-18-2008, 07:46 AM   #119
DBAsteve
Member#: 16839
Hi Steve
2008 Jap Spec WRX comes standard with 316mm front rotors now.
These are the same discs that have been on the Liberty (Legacy) GT since 2005. The Liberty had twin piston calipers though.
Umm! How many years did it take for the USA to get the four pot calipers...
114.3mm PCD by the way.
Old 06-18-2008, 08:39 AM   #120
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
Woah, so is the casting for the JDM four-pots different now, or is it the hub bodies that move the caliper further out to match the 316mm rotor? I can foresee some US WRX owners converting to JDM front hubs...
Frank
Frank A is offline   Reply With Quote
Old 06-18-2008, 10:31 AM   #121
BIGSKYWRX
Member#: 7958
09 GH B+
wow- didn't know that
Old 06-18-2008, 12:13 PM   #122
Butt Dyno
Member#: 17301
is the "dark side"
Wait, what? the 2008 JDM WRX is 5x114.3? It uses the good hubs?
Old 06-18-2008, 12:18 PM   #123
KNS Brakes
Member#: 125739
2015 WRB WRX
JDM has regained the position of being 'mad-tyte yo' ..
Must find out about those calipers......
Old 06-18-2008, 12:22 PM   #124
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
This reminds me, what do the Japanese teams bolt on to an STI for "group N" brakes? The caliper/rotor combo would have to clear 15" rally rims, but would have to bolt onto the 5x114.3 hub bodies.
Frank
Old 06-18-2008, 02:51 PM   #125
BIGSKYWRX
Member#: 7958
09 GH B+
please do we can source 316 5x100 rotors
^ they use the FHI 4/2 pots, they have "special" rotors- they're listed by part # on the STi Grp N site
Tribeca Brake/Suspension technical information THAWA Tribeca Forum 5 03-31-2006 10:07 PM
Looking for thread that contains information on Clearence of Stop Tech Big Brake kit MooseWRX Brakes, Steering & Suspension 4 02-22-2004 04:24 PM
brake upgrade information STEALTH-WRX Brakes, Steering & Suspension 43 03-11-2003 01:31 PM
Outback owners: brake information needed! bagio Legacy Forum 1 08-02-2002 03:47 PM
Outback owners: brake information needed! bagio Brakes, Steering & Suspension 1 08-01-2002 05:24 PM
