Old 06-18-2008, 02:58 PM   #126
KNS Brakes
NASIOC Storefront Vendor
Member#: 125739
2015 WRB WRX
Need Brakes? 919.420.0021
The 316mm rotors are 30mm vs 24mm - so the caliper had to be re-tooled or spaced ala Wilwood (doubt that though)
I would also wonder how well it clears the rotor radius
And - it's a smallish narrow annulus pad compared to most BBK type offerings and the LGT pad.
KNS Brakes is offline   Reply With Quote
Old 06-18-2008, 03:02 PM   #127
BIGSKYWRX
Member#: 7958
09 GH B+
I missed the thickness difference I guess they can re-drilled to 5x100 however
find these things
Old 06-19-2008, 04:08 AM   #128
jamal
Member#: 71875
98 Legacy GT
my wheels fit
I want to see a picture of these things. Or see them.
jamal is offline   Reply With Quote
Old 06-19-2008, 09:01 AM   #129
BIGSKYWRX
Member#: 7958
09 GH B+
I'd like to see a picture of those 4 pots/316x30's on the front of my car
Old 06-28-2008, 02:57 PM   #130
BIGSKYWRX
Member#: 7958
09 GH B+
I've come to the conclusion that while the S-GT (WRX ) may get bigger brakes- they aren't opposed piston calipers
http://www.subaru.jp/impreza/impreza/safety/index.html
Old 06-29-2008, 11:52 PM   #131
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
Originally Posted by Frank A View Post
This reminds me, what do the Japanese teams bolt on to an STI for "group N" brakes? The caliper/rotor combo would have to clear 15" rally rims, but would have to bolt onto the 5x114.3 hub bodies.
Frank
To answer my own question, maybe they use these:
RST-H210G STi Front Gravel Brake Kit by AP Racing ('06 Homologation) $4,595.00
Which I found in this very cool file which I hope gets updated for more 08 parts soon:
http://www.rallispec.com/STi%20Catalog%2007.pdf
Edit: Apparently the caliper in this kit is almost the same or identical to a standard AP caliper from their racing catalog. Having almost owned a set of one of their race-only calipers, all I can say is, they are the shiz.
Frank
Frank A is offline   Reply With Quote
Old 09-23-2008, 06:00 PM   #132
ralli-tart
Member#: 106125
06 OZ aw wagon
this thread saved me from posting another useless noob thread on brake compatibility.
i was going to ask whether or not the rear calipers for my 06 2.5i are the same for the 02-05 wrxs, so i can install the H6 Rear Rotor and Bracket upgrade for brakes.
thanks again nasioc! :thumbsup:
ralli-tart is offline   Reply With Quote
Old 11-18-2008, 06:24 AM   #133
Buggn' Out
Member#: 173971
02 /05 WRX
Aspen White, facelifted
Great thread....subscribed!
Buggn' Out is offline   Reply With Quote
Old 12-25-2008, 10:56 AM   #134
Pawlwawl06
Member#: 180087
2006 Legacy 2.5i
Anyone know if the front 06/07 WRX left and right calipers are identical?
Pawlwawl06 is offline   Reply With Quote
Old 12-25-2008, 12:26 PM   #135
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
No, theyre mirror images of each other with the bleed screws on opposite ends.
ss
subysouth is offline   Reply With Quote
Old 12-25-2008, 01:45 PM   #136
Pawlwawl06
Member#: 180087
2006 Legacy 2.5i
ss
Cool thanks a lot, this is my first DIY brake job, just wasn't sure...so the bleeder screws are at the top. Thanks!
Old 12-25-2008, 04:26 PM   #137
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Yeppers.
ss
Old 02-03-2009, 02:45 AM   #138
stigc8
Member#: 32378
1993 WRX Type RA
Good info, maybe it would be more useful and conclusive for one to know which caliper is the same by taking the markings on the caliper?
Here is what my front right 2-pot caliper from JDM Version 1 WRX says:
AD60T
24-15
2308R
34R
For any who have detailed pics or have 2-pot Impreza RS and Legacy GT calipers, could someone verify if their caliper has similar markings?
I've heard the "2308R" is the "casting number".
Thanks for any help.
I'm trying to find if another caliper is the same as mine so I can be sure which North American rebuild kit will fit.
stigc8 is offline   Reply With Quote
Old 02-09-2009, 09:11 AM   #139
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
I have a 2001 Legacy GT caliper that has the following markings in the caliper body(not the caliper bracket.)
T (boomerang looking swoosh on a negative circle) 7
AD43T
4317
3 Inverted triangles in an inverted triangle pattern followed by 226
Oh and there are 2 flattened portions of the casting for the bleeder screws marked L an R. If its the right caliper it has a bleeder screw at R etc. It would appear the bleeder screws are tapped after the casting is made.
In the US market the front 2pot caliper bodies were effectively interchangeable from about 1997 to 2002. What year JDM Impreza was the 2pot sourced from?
HTH
ss
Old 02-13-2009, 07:05 PM   #140
stigc8
Member#: 32378
1993 WRX Type RA
Hi subysouth
Car is 1993 Version 1 WRX
This weekend I'll know if 2.5 RS calipers can be used as replacements and also if my stock bracket or RS caliper brackets make 2002 GDA WRX front calipers fit.
Old 02-15-2009, 10:17 AM   #141
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
I think that may well be a no but let us know. I think the set you are using may be from the earlier Subaru brake castings like those used on the early 1990s US Legacy Turbos. But please let us know.
ss
Old 02-16-2009, 12:22 AM   #142
Quadsbc
Member#: 170415
2002 Hardware store
bumper clips, that is all
I'm swapping my wrx brakes to 2007 legacy GT brakes, If I'm reading this correctly the rear calipers and rotors will fit, But the brake lines need modification. Does that mean that I need to run wrx rear lines or LGT? yes i know the stockers wont fit over the brakes
This is a great wright up
Thanks
Quadsbc is offline   Reply With Quote
Old 02-16-2009, 09:55 PM   #143
Quadsbc
Member#: 170415
2002 Hardware store
bump for some info...
Old 05-10-2009, 07:30 PM   #144
Kerem
Member#: 204383
06 Impreza 2.0R
I have 05 usdm wrx front brake calipers w/ mount brackets and brake houses. I want to use them on my 06 2.0R which, I think, uses same front brakes with 06 2.5i. I also bought suitable pads.
My question is are these calipers use the same rotors with 4-pots (red ones)? What I understand from this thread, It is not possible cause 4-pots use 4000 and 2-pots 4650. Am I right? I hope I am not because in turkey only the 4/2 brake system (red ones with white subaru logo on) is available and I am sure that I am not gonna be able to find the appropriate rotors if they are different.
Kerem is offline   Reply With Quote
Old 05-12-2009, 12:15 PM   #145
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Kerem, yes the rotors are the same - they are 294x24mm with a 5x100 bolt pattern.
I think the numbers you are using are DBA part numbers and thats the source of the confusion.
4000 is series(there is a 5000 series as well) of brake discs that DBA produces with upgraded features. The specific 4000 series front rotor for that application is the 4650. The "standard" DBA rotor is the 650. So the 4650 and 650 are identical in size but differ in performance features.
So in DBA rotors, you have the 650, 4650, and 5650 as options, all virtually the same size and all will fit your application.
ss
Old 05-12-2009, 12:21 PM   #146
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Thanks
You can use the WRX lines but IIRC they are a little short and you may need to zip tie them instead of using the standard tie down. The Legacy GT itself uses an entirely different style of rear suspension so the lines from that application are basically useless on the WRX. I personally used StopTech braided lines that are a bit longer than the stock lines and have a sliding mount ferrule so it worked fine.
ss
Old 05-15-2009, 09:01 PM   #147
Kerem
Member#: 204383
06 Impreza 2.0R
ss
Thanks a lot for your answer. I just thought that these were oem part numbers. So I will buy my rotors from Turkey.
Old 05-17-2009, 04:54 PM   #148
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Just an FYI, the 2008+ WRX front rotors are the same width/etc. as the 02-07 Rotors, HOWEVER the thickness of the "vent" on the sides of the rotors has changed dramatically.
The rotors are indeed a new part number as well. I'm curious if this change was to prevent warping...
Old 05-17-2009, 05:29 PM   #149
BIGSKYWRX
Member#: 7958
09 GH B+
comparo pic I'm guessing the 08/09 rotors are heavier then (thicker veins) as well
Old 05-17-2009, 06:35 PM   #150
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Yea, I'd be curious to see that too.
ss
Tribeca Brake/Suspension technical information THAWA Tribeca Forum 5 03-31-2006 10:07 PM
Looking for thread that contains information on Clearence of Stop Tech Big Brake kit MooseWRX Brakes, Steering & Suspension 4 02-22-2004 04:24 PM
brake upgrade information STEALTH-WRX Brakes, Steering & Suspension 43 03-11-2003 01:31 PM
Outback owners: brake information needed! bagio Legacy Forum 1 08-02-2002 03:47 PM
Outback owners: brake information needed! bagio Brakes, Steering & Suspension 1 08-01-2002 05:24 PM
