Old 05-20-2009, 09:22 PM   #151
Bonzo
Member#: 2307
2009 530EXCRF1000D
Orange
Please clarify for my 3rd grade brain.
Years ago I bought a complete set of pads for my 2000 LGT wagon.
I now have an 05 Legacy OB wagon.
Dumb question.
Will the pads interchange?
common sense says no.
I should note that the caliper bracket, and not the caliper, is what determines pad shape. So while there are a few different pads, in some cases the calipers are the same.
1996-2002 Legacy: D721
2002-2008 Legacy: D929
Bonzo is online now   Reply With Quote
Old 07-17-2009, 10:57 PM   #152
012.5RS
Member#: 95051
02 WRX Wagon
World Rally Blue
ok figured id make things even more complicated. im looking to find info on the weight of rotors and calipers... If anyone knows that would be great.
Trying to see if anyone knows the weight of the following
USDM 02+ WRX
Front
Rotor(294mmx24mm)
Caliper
Rear
Rotor(266mmx10mm)
Caliper
JDM WRX
Front 4 Pot
Rotor(295mm x 25.4mm)
Caliper
Rear 2 Pot
Rotor(290mm x 18mm)
Caliper
012.5RS is offline   Reply With Quote
Old 07-17-2009, 11:10 PM   #153
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
iirc BIGSKYWRX posted many of those way back - some are here: Comprehensive Component Weight table
UkNuck is offline   Reply With Quote
Old 07-17-2009, 11:45 PM   #154
BIGSKYWRX
Member#: 7958
09 GH B+
yup- they should all be there
Old 09-20-2009, 06:45 PM   #155
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG, BW S256
subscribed
emsmap is offline   Reply With Quote
Old 10-15-2009, 04:21 PM   #156
3k1n
Member#: 83043
05 sti
Quick question guys, does the 60-07 wrx front 4 pot and rear 2 pot calipers fit on the 03 wrx rotors? would i need any additional brackets for the front or rear? any other hardware?
3k1n is offline   Reply With Quote
Old 10-16-2009, 11:57 AM   #157
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
The front rotors will work with the 4pots but the rear rotor is entirely different. The 03 WRX uses a 266x10mm rear rotor and the 2pot rear needs the 290x18mm rotor. No other brackets for the front, the rear on the other hand requires either swapping over the rear backing plate off the newer car(pretty big job) or a 1pot to 2pot adapter correctly locating the the 2pot caliper in space over the rotor and changing the caliper bolt spacing.
ss
subysouth is offline   Reply With Quote
Old 10-30-2009, 09:51 AM   #158
02vtecsir
Member#: 214457
looking to find replacement rotors and brakes (upgraded)for a 2001 b4 RSK (JDM TURBO)i am in japan, looking to purchase through the states.. anybody have any help on where i need to buy from and what model
02vtecsir is offline   Reply With Quote
Old 11-07-2009, 01:22 AM   #159
Speedster329
Member#: 214652
2004 STI !
JBP !
ok after reading this im more informed now on the brakes its been a big help but i jus want to make sure about this..Has any 1 with a 02 wrx swaped there stocks callipers and rotors to a 04 BREMBO set up? if so what exactly do i need to make this work like do i need the STI calliper bolts or can i use the stock 1s and do i need new brake lines or anything??
Speedster329 is offline   Reply With Quote
Old 11-07-2009, 05:23 PM   #160
KNS Brakes
NASIOC Storefront Vendor
Member#: 125739
2015 WRB WRX
Need Brakes? 919.420.0021
The Brembo's have a different thread - so you need them
I am pretty sure the banjo bolts are a differnt length - the lines are basically the same.
KNS Brakes is offline   Reply With Quote
Old 11-07-2009, 06:05 PM   #161
Badmunky
Member#: 143391
2007 WRX TR
R.I.P Paul! :(
You guys all get so hung up on the calipers, rotors, and pads. I want info on the power brake booster. THAT is where most of my problem is. Mushy peddle with poor feedback.
I want to change the Brake booster to one that will not have so much boost to it and so much give. I think the stocker is a 2 stage and I want to go to a single stage like most other cars have.
Dos any one have any info on this?
Badmunky is offline   Reply With Quote
Old 11-07-2009, 06:28 PM   #162
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
Old 03-24-2010, 12:51 AM   #163
Hareball
Member#: 165025
Originally Posted by jamal View Post
294x24mm
295x25.4mm
This is the WRX front rotor. It uses a two piston sliding front caliper or the Subaru fixed 4-pot. The sliding caliper, bracket, and pad were changed in 03 and that's something you need to be aware of when upgrading from RS brakes or purchasing pads. The 4-pots are only on the 06-07 WRX in the US, though they were on many older non-US STis and WRXes (the black calipers with Subaru across them). Generally 16" wheels are required with these brakes but there are some 15" wheels out there that work. Also 16x6.5 Subaru wheels do not clear 4-pots.
Applications:
01 Legacy GT LTD?
02-04 Legacy GT
05-09 Legacy non-gt
01-09 Outback
02+ Impreza WRX (including 08, which uses 2-pots)
03+ Forester
Baja
I have a 98 STI Type R (JDM). It has the black calipers with "Subaru" on them, leading me to believe it has 4pot fronts and 2pot rears... but it has 16x6.5 in wheels (granted the spacing for the front wheels and the calipers is only about 1/8 to 1/4 of an inch).
What I really want to know is will brake pads for an 02-03 WRX work?
Hareball is offline   Reply With Quote
Old 03-24-2010, 12:55 AM   #164
KNS Brakes
Member#: 125739
2015 WRB WRX
no - you'd need USDM 06/07 pads
Old 03-24-2010, 01:00 AM   #165
Hareball
Member#: 165025
Doh, missread the part I quoted. Awesome, 06/07 front/rear pads will work. Thank you for the clarification.
Old 03-29-2010, 09:59 AM   #166
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Tongue I am curious what the make and offset is of these wheels if you can post it up.
ss
Old 08-11-2010, 02:06 AM   #167
Stealth1
Member#: 164358
Anyone have an update for 2008-2010 WRX upgrade to 06-07 WRX Rear 2-pots?
Looking just at dimensions and info the 2008-2010 WRX doesn't have a backing plate so would you need or be able to use the 2-pot kartboy rear adapter to fit the calipers? For the rotors it looks like we would need the 2001 STi JDM rotors at 290mmx18mm with 190mm parking brake. Has anyone tried this or have any further info?
Stealth1 is offline   Reply With Quote
Old 08-11-2010, 08:00 AM   #168
KNS Brakes
Member#: 125739
2015 WRB WRX
The 190 mm gravel rotor might work but the height of the drum might be a problem. I know the height of the 08 STi rear drum = different than the earlier one.
Old 08-12-2010, 01:55 AM   #169
Stealth1
Member#: 164358
08-10 STi rears fit on the 08 wrx or need a full hub swap?
Old 08-12-2010, 07:27 AM   #170
KNS Brakes
Member#: 125739
2015 WRB WRX
It should be bolt on if you use a redrilled 08 STi rear rotor.
Old 08-12-2010, 11:21 AM   #171
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
I haven't tried this but I think you are on the right track. If it helps, the 290x18mm rotor with 170mm parking brake for the 06-07 is shared with the Legacy GT 05-09 rear brakes, though those use single piston sliders. By extension the 08+ WRX rear brakes share caliper and bracket with the 05-09 Legacy 2.5i. I think that translates to the Gravel rotor being the one to work. But it might need a custom adapter for the 2-pot caliper.
I've also noticed that the '10 LGT appears it may have the gravel rotor stock, there is a Brembo swap in a thread over on Legacygt.com and you can see the stock vented rear rotor has 190mm parking brake hat like the 08+ WRX. It might be 290x18 but not sure yet since the usual parts databases aren't up to date for that new application yet. That might bring the cost of sourcing rotors down if it is true.
I am thinking of doing the gravel rotor(maybe '10 LGT rotor) and LGT rear calipers when I use up my extra rotors and pads at some point in the future, since I already have LGT fronts.
Power6 is offline   Reply With Quote
Old 08-15-2010, 02:05 AM   #172
Stealth1
Member#: 164358
Great info coming in on this, if the rear 2010 LGT is the same as the 08 WRX then it should be the same situation for the brembo's fitting. Would be nice to find a solution for the 2-pot rears from the 06-07 WRX though.
Old 09-30-2010, 03:26 PM   #173
dpt6410
Member#: 258629
2007 2.5i
Satin White Pearl
Got a question for you about hub sizes for 07 Impreza 2.5i. needed to know what size the stock hub is for upgrading brakes and rims i can use.
dpt6410 is offline   Reply With Quote
Old 10-21-2010, 11:45 PM   #174
k3nj11
Member#: 146718
'06 OBP STi
'07 CGM Forester XT Ltd.
Hmm, I'm possibly looking to swap my '06 STi Brembo's out for a set of '08+ STi Brembo's, is this even possible?
k3nj11 is offline   Reply With Quote
Old 10-22-2010, 11:39 AM   #175
Chris_B
Member#: 244701
Front - yes.
Rear - no.
Chris_B is offline   Reply With Quote
Tribeca Brake/Suspension technical information THAWA Tribeca Forum 5 03-31-2006 10:07 PM
Looking for thread that contains information on Clearence of Stop Tech Big Brake kit MooseWRX Brakes, Steering & Suspension 4 02-22-2004 04:24 PM
brake upgrade information STEALTH-WRX Brakes, Steering & Suspension 43 03-11-2003 01:31 PM
Outback owners: brake information needed! bagio Legacy Forum 1 08-02-2002 03:47 PM
Outback owners: brake information needed! bagio Brakes, Steering & Suspension 1 08-01-2002 05:24 PM
