![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#1 |
Member#: 107389
Vehicle:2005 STI Aspen White |
I made a spring frequency calculator in Excel. Unlike anything else I've seen out there, this automatically selects a rear spring rate so that the spring frequency in the rear is appropriately higher based on the vehicle speed you want to optimize for. From there, one would dial in over or understeer using sway bars as needed.
You pick the front spring rate according to the ride comfort you would like- use the calculated spring frequency as a guideline here. Generally speaking, you'll want the front spring frequency to be around 1.0-1.2 for a family sedan, 1.5-1.7 for a sports car, and 2.0-2.2 for a race car. Download the spreadsheet: http://putstuff.putfile.com/79647/6261372 For more reading on spring frequency selection, I recommend this: http://www.optimumg.com/techtips/Spr...Tech_Tip_1.pdf Another good link: http://www.wincom.net/trog/autocross_secrets5.html Yet another: http://www.smithees-racetech.com.au/...cefactors.html I'm not suggesting this calculation is smarter than human trial and error since it certainly cannot account for other limitations or circumstances on the car. It just follows the guidelines taught at the above links, so read them to understand this calculation. The default values in the spreadsheet are for an STI; we see the rear spring rate is optimized for a "flat" ride at 70mph. Anyway, let me know what you think! The subject of spring frequencies is certainly one that is wide open for discussion.
#2 |
Member#: 111067
Vehicle:_ Power through Suspension |
So what about choosing which speed you want to maximize for ?
for autoX speeds: ? for DD-occasional Auto-X speeds: ? Which do you choose ? |
#3 |
Member#: 107389
I'd really like to defer your questions to someone else- I made the spreadsheet to learn about spring frequencies, not to share what I've already learned. So really, I'm not an expert. However, since nobody else is chiming in, I'll take a stab.
Optimizing for really low speeds is nearly impossible because by the time a bump reaches your rear tires, the front tires will have already settled. This is expecially true when running high spring frequencies- since at 2hz the front of the car will have fully oscillated in only half a second, the rear doesn't have much opportunity to catch up. This would mean running much, much higher spring frequencies in the rear (as the spreadsheet shows). Maybe that would work very well, but I doubt it. So, depending on your chosen spring rates, I don't think it'd make sense to optimize for under 60mph. You want to optimize for the average speed you find yourself driving at, so if you optimize for 70mph, both 60mph and 85mph will still feel pretty good. Maybe road race cars would optimize for a slightly higher speed, but 60-80mph is a pretty typical speed for hitting rumble strips, right? That's about what Subaru optimized for in the STI (and even the JDM Pink springs): 70-80mph. I've read the generalized rule-of-thumb for street and race cars alike is to make the rear 0.1 to 0.3 Hz higher than the front, and again, both the USDM and JDM STI spring rates follow this guideline. |
| Thread Tools | |
| Display Modes | |
| Any DIY on how to make your own speaker spacers?? | Alan l. | Car Audio, Video & Security | 7 | 05-12-2006 12:17 PM |
| How to make your own jet bike | CSULBwagon | Off-Topic | 7 | 10-28-2005 05:21 PM |
| How to build your own $1199 contemporary bed | ockS | Off-Topic | 25 | 09-14-2005 06:35 PM |
| how to make your own axle-back | iloveturbos | Factory 2.0L Turbo Powertrain | 4 | 01-17-2003 03:17 AM |
| How to do your own Blue or Red Lights Free! | Reiflex | Interior & Exterior Modification | 28 | 12-12-2000 09:58 PM |
