Old 12-18-2001, 11:33 PM   #1
zmw
Member#: 13181
97 Supra
FAST
Default Factory Boost map?
Does anyone have a map of the factory boost pressures? - I am not seeing a single boost pressure higher than 14psi and more often than not between 7 and 11ish.
What i'd like to see is a graphical respresentation (from a dyno maybe?) of stock boost pressures.
and FYI i did try to search for this but because "stock" "boost" and "map" brought up about a jillion threads, made it a bit difficult.
Thanks - Z
zmw is offline   Reply With Quote
Old 12-19-2001, 01:00 AM   #2
zmw
Member#: 13181
97 Supra
FAST
bump bump...
Old 12-19-2001, 03:02 AM   #3
zmw
Member#: 13181
97 Supra
FAST
bump again will let it go after this.... anyone help?
-Z
Old 12-19-2001, 03:21 AM   #4
Fubaru
Member#: 6046
'08 Prius
this thread has some boost curves +/- mBC
http://www.i-club.com/forums/showthr...ighlight=boost
Fubaru is offline   Reply With Quote
Old 12-19-2001, 03:42 AM   #5
zmw
Member#: 13181
97 Supra
FAST
awesome thread, thanks.... - that's exactly what I was looking for and basically proves my car is running with very similar results (by just eyeing the boost gauge)
I would love to see datalogging through the 5th gear which is actually where i see the highest boost (remember no boost controller here) - just slightly over 15psi (well +1kpa, so 14.7)
-Zach
FS: FBC Factory Boost Controller / Boost Selenoid klie5111 Private 'For Sale' Classifieds 1 01-16-2006 04:32 PM
Manual Boost Controller - Factory Boost Selenoid vacuum line. skimobile Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-30-2005 10:51 PM
turbo timer boost gauge install w/ factory boost gauge Blakestyle521 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-21-2004 10:19 AM
XEDE Vishnu STi Stage 1 maps off Vishnu's website, boost map is wrong? STi City Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 02-03-2004 11:02 PM
Switched back to factory boost control & now severely over-boosting Fubaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 01-01-2003 07:32 PM
