Old 05-17-2007, 12:08 PM   #1
angel2167882
Member#: 145363
2007 2.5i Wagon
Newport Blue Pearl
Default Short-Ram Intake on my 2007 Impreza 2.5i
So here it is, I've purchased and installed my Cosmo Racing Short-RAM intake (SRI) on my 2007 Impreza 2.5i.
http://www.cosmoracing.com/productin...d=226&pid=1498
Because Cosmo Racing is based in Montreal, Qc, I did arrange a local pickup and paid $100 CND cash. I did also requested with polished piping and with blue coupling and filter if possible, which happens to be. Really good price and service.
I choose an SRI (vs CAI) because:
-cheaper
-easier to clean the filter
-Less car resonance because it reside in a wide area (engine bay) instead of the little fender
-I'm not really doing traffic stop-and-go so hot air don't really built up under the hood
-Less risk of water, snow, slush or dirt penetration
Everything went great, about 2h install alone. The product unfortunatly don't come with instructions but someone who did already install an intake should be able to.
It took me some time to dismantle the white fender resonator but it pass without removing the wheel (and I have large 225mm tires). Just turn the steering to the max left, remove the under splash-guard, bend it and pass the resonator by the bottom. While optional, removing the resonator will free up 2 big holes from the fender that will help bring some fresh air inside the engine bay.
No need also to disconnect the battery but do NOT disconnect the MAF/MAP/TEMP, or at least do not start the car with one of thoses sensors unpluged or it will trip the CEL.
Also, plan to have an extra feet of hose to reach one of the vacuum line to the SRI piping. Got from Napa auto parts (3ft of 5/8 hose, 2 x ½ joints and clamps) for a big 6$. Big thanks to jezzy for the recommandation.
Some clamps were thighten in angle to better follow the piping curve, specially the TB end that take 130-140° curving. Fitting is pretty good, you just need to tight the "good" clamp in the "good" order. The MAF is near 2 brake lines but OEM setup is like that too.
Finally, it took me some time to figure out how to bend and attached the 2 provided bracket to stabilize the fragile and expensive MAF. It's pretty well done, it hold firmly in place and won't knock or excessively vibrate. See the details below with the pictures.
Now for performance and sound... Lots of debate around the SRI/CAI need on the EJ25, even some think you will loose some. But don't forget the 06-07 EJ25 has i-AVLS, a variable lift on 1 intake valve per cylinder, à la Honda VTEC. More infos here:
http://www.drivesubaru.com/Spring07_whatmakes.htm
http://community.webshots.com/album/384399999ynOfJe
Even this guy got near 15WHP -12TQ dyno proven, with an eBay custom built SRI:
http://forums.nasioc.com/forums/show....php?t=1156560
So for myself, my butt dyno saw immediatly a difference. For the one who think you'll loose some low-end torque, well it's totally the opposite. I have the bad habbit to start from a stop in 2nd gear (unless totally stop) and wow, no more "lag", response is clearly better, thanks to i-AVLS.
In the mid-high rev, the gain is good too, I would maybe not say loud 15HP but something like 7-8HP would sound me good, and 10HP when the i-AVLS kicks in because of the sound!
Talking about sound, it's completly crazy around 5500-6000RPM at WOT! But the beauty of it is that in normal driving, you just don't ear it. Unless you floor it (maybe under 50% throttle), it's totally sleeper, brilliant for long driving and to not disturb the nerborhood.
So here's the pics:
OEM intake in the engine bay
OEM intake on the floor (white box is the fender resonator, also called the portable toilet)
Vacuum line that need to be extended with the joint and an extra feet of hose
MAP sensor on the OEM U style fitting... it will slightly touch on the hood
Last vacuum line to connect under the piping
First bracket that hold from the suspension tower bolt to the MAF plate.
Second bracket fixed lower, screw with a spare provided bolt into body pre-holed and bracket end rest on the filter coupling, retain under the clamp
Final pics in second post below
angel2167882 is offline   Reply With Quote
Old 05-17-2007, 12:09 PM   #2
angel2167882
Member#: 145363
2007 2.5i Wagon
Newport Blue Pearl
Install done!
Here's a little vid also here:
http://video.google.ca/videoplay?doc...68787931799987
It's a 80km/h to 120km/h in 3nd gear, inside car and window closed. Give's a idea of performance and sound but quality is poor, sorry.
Final word, it's a must for the price!
For frenchies, you can find a french version of this thread on my local club here:
http://www.montreal-subaru-club.com/...ic.php?t=48592
Old 05-17-2007, 12:23 PM   #3
blackbox1
Member#: 97280
Default maybe a turbo?
looks great my friend has a 2007 2.5i and we were wondering if the turbo stuff that will fit the wrx or sti will fit his 2.5i?
blackbox1 is offline   Reply With Quote
Old 05-17-2007, 01:02 PM   #4
subiesurfer
Member#: 121330
06 impreza
SGM
no will not work.
on the other hand, nice post very detailted, any video?
subiesurfer is offline   Reply With Quote
Old 05-17-2007, 01:27 PM   #5
angel2167882
Member#: 145363
2007 2.5i Wagon
Newport Blue Pearl
Yeah, I've made a 80km/h to 120km/h in 3nd gear, inside car and window closed.
It make 3.8MB but I don't have a place to host it... any volunteer?
Old 05-17-2007, 02:20 PM   #6
Sir-Knight
Member#: 73636
2007 Impreza 2.5i SE
newport blue pearl
youtube or google video.
Sir-Knight is offline   Reply With Quote
Old 05-17-2007, 02:32 PM   #7
doubledribble
Member#: 42912
2003 Outback Sport
bird **** & door dings
i'd remove the stock airbox mount. i left mine on when i put in the COBB cai and after a few month of driving, vibration and what not weakened the base and it broke off. luckily i was under the hood and caught it before it caused any damage.
doubledribble is offline   Reply With Quote
Old 05-17-2007, 02:51 PM   #8
angel2167882
Member#: 145363
2007 2.5i Wagon
Newport Blue Pearl
I guess you are talking about the 2 poles that hold the "torque box"? Yeah, I tought about removing them too (specially the driver side one) but I figured out they were not disturbing anything and would be easier to put back the stock intake just in case.
But if you said they could break so easy, well I will remove at least the driver's side one. The other one kinda hold the MAP sensor throught, should I removed it too?
Old 05-17-2007, 03:29 PM   #9
cmiovino
Member#: 134005
2004 WRX Premium
Ah, good to see someone had luck with the Cosmo. A video would be great though :P
Tell us how much of a difference you get with gas mileage!
Old 05-17-2007, 07:24 PM   #10
Foresternation
Member#: 126341
2007 Forester X Prem
Urban Grey Metallic
My question is whats the difference between this short ram intake and the cosmo Cold air intake that goes into the fender?? Is it a loss of power issue or just a noise and safety, concerning the air being pulled from the fender?
Foresternation is offline   Reply With Quote
Old 05-17-2007, 08:57 PM   #11
zavier
Member#: 141189
2007 2.5i (NBP)
2014 BRZ (DGM)
SRI's pull in the air in the engine bay which tends to be warmer then the outside air...the CAI sits in the fender down near the base and pulls in cooler air...that's about it
zavier is offline   Reply With Quote
Old 05-18-2007, 08:30 AM   #12
angel2167882
Member#: 145363
2007 2.5i Wagon
Newport Blue Pearl
Here's the vid:
Sorry, quality it not too good, it's comming from my digital photo cam in vid mode. Car windows are closed too to prevent wind noise into the vid... thurst me, vid sound does not render the real thing!!!
About Fuel Economy, well it's too new to tell plus, summer comming so my fuel mileage will increase anyway. And I've just switch to synthetic oil also which gonna help too.
But in theory, it should be better a little because air flow better and help burn gas more. But it's also the opposite because with the SRI, you tend more often to floor it and so, it will burn more gas
Old 05-21-2007, 02:24 AM   #13
Firewire
Member#: 3430
2007 2.5i Wagon
Garnet Red
I really wish they'd supply a proper mounting bracket and the necessary hose extensions. It just seems ghetto having to bend things and buy extra parts for a product that is supposed to be ready for retail and built for our cars.
Firewire is offline   Reply With Quote
Old 05-22-2007, 09:38 AM   #14
angel2167882
Member#: 145363
2007 2.5i Wagon
Newport Blue Pearl
Yeah I know but if for 100$ I have to buy some extra stuff for less than 10$, it does not bug me that much!
As for the brackets, I think that even being "generic" brackets, they hold very well when properlly installed like I've done
Old 05-22-2007, 10:30 AM   #15
SiFuSpEc
Top Scoob 008
Member#: 77299
'05 2.5RS
#78 ST, MAXIMUM ATTACK!
oddly enough, intakes like this with the exact welding location can be found on ebay for ~20 bucks, and the adapter for the MAF can be found ~10, so 30 bucks shipped you can have your own COSMO racing intake..
and oddly enough people still buy the COSMO..
SiFuSpEc is offline   Reply With Quote
Old 05-22-2007, 11:34 AM   #16
tlip1119
Member#: 121491
2006 2.5i
Any links??
tlip1119 is offline   Reply With Quote
Old 05-22-2007, 11:58 AM   #17
angel2167882
Member#: 145363
2007 2.5i Wagon
Newport Blue Pearl
SiFuSpEc: oddly enough, Injen make an SRI with slightly better coupling/filter quality but without the 3nd vacuum hole for 4 times the price
Don't forget I'm in Canada and Cosmo Racing is in Canada... I'll paid 100$ CDN cash all-included with a local pickup (no shipping).
But for me getting anything on eBay cost me hard on shipping, not talking about the custom fee if sent by UPS.
For me, getting the Cosmo intake was the easiest and the cheapest way
Old 05-22-2007, 12:02 PM   #18
SiFuSpEc
Top Scoob 008
Member#: 77299
'05 2.5RS
Ah, Canada, that explains it... lol
Well, i was a couple dollars off, but..
http://cgi.ebay.com/ebaymotors/95-96...QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/93-05...10396953QQrdZ1
either of the filters will work, and it will work on most any car, hell, i have a 02 intake on my 05 and the same manifold as the 06/07..
Old 05-22-2007, 10:57 PM   #19
BoozeRS05
Member#: 137797
'05 LegacyGT
wagon, 5mt
I would buy a K&N or HKS cone. I wouldn't use some filter that can with an $8-$50 kit. That Cosmo filter seems sketchy to me.
BoozeRS05 is offline   Reply With Quote
Old 05-22-2007, 11:08 PM   #20
StE823
Member#: 78673
2005 Impreza 2.5RS
www.shutterlit.com
i heard HKS filters are crap from a review comparing a bunch of filters...
StE823 is offline   Reply With Quote
Old 05-22-2007, 11:29 PM   #21
BoozeRS05
Member#: 137797
'05 LegacyGT
wagon, 5mt
Well same point... Don't use a crap filter.
I've always used K&N, no problems.
Old 05-23-2007, 08:37 AM   #22
angel2167882
Member#: 145363
2007 2.5i Wagon
Newport Blue Pearl
I will let this filter on for the season (until dirty) and switch for a K&N for sure after.
But it's not a bad filter, I did check it throught sunlight from inside and the fabric (maybe not cotton but some sort of fabric) is pretty tight, except maybe the top-end "velocity stack" filter but the screen wires are much more near together at this end vs the screen around.
And it look washable and oilable too.
Old 05-23-2007, 12:35 PM   #23
Bondy007
Member#: 120301
2010 Honda Civic EXL
Polished Metal Metallic
I run an AEM short ram intake. K&N filters are the way to go. Mine was a bit older, so the next time I 'clean' it, I'll just get a new one.
Nice video too!
Bondy007 is offline   Reply With Quote
Old 05-24-2007, 02:58 AM   #24
xkrnxjonxx
Member#: 129274
2006 2.5i *RIP
Urban Grey
quick question
ppl been sayin that u needa easy mod for the injen intake...
wat kinda mod is it??
xkrnxjonxx is offline   Reply With Quote
Old 09-30-2007, 11:09 PM   #25
got0azn0rice
Member#: 151097
Does anyone know if an 04-05 2.5rs short ram from Injen would fit an 06-07 2.5i?
got0azn0rice is offline   Reply With Quote
FS: 2007 Impreza 2.5i PARTOUT..exhaust,springs & intake zohh_amaze Engine/Power/Exhaust 1 08-06-2009 10:00 PM
Just intalled weapon r short ram intake on my 05 wrx Hennessc Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-17-2008 12:53 AM
Audio upgrade on my 2007 Impreza Wagon 2.5i angel2167882 Car Audio, Video & Security 12 08-23-2007 10:14 AM
Should I get a 2007 Impreza 2.5i for my next car? djkaye22 Impreza Forum 59 08-01-2007 12:25 AM
Newbie question....Can anyone help me install a short ram intake on my 2000 impreza? slp0313 Impreza Forum 0 07-21-2006 08:59 AM
