Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 05-17-2007, 05:54 PM   #1
volkl23
Member#: 39092
2004 WRX STi
Java Black Pearl
Default What should I get first? Springs or Swaybars?
After getting a TBE finally installed, my next goal is to make my car more competent in the handling department. I am getting more and more into AutoXing, but my car IS still a daily driver. Alas, I can't go insane with the setup.
I'm at a crossroads now on whether to install springs or swaybars first. For springs, I was thinking of going with the Prodrives and Sways, Whiteline 24-26mm fronts and 24 adjustable rears. What do you guys think I should do first? I've been reading and reading about how aggressive sways (I guess 24-26 isn't TOO aggressive) and stock springs don't mix well. But how sways is pretty much the best bang-for-your buck upgrade you can get. Will the my sway setup clash with my stock springs?
If the answer is yes, perhaps I should go with springs first then?
What do you guys all think?
volkl23 is offline   Reply With Quote
Old 05-17-2007, 08:10 PM   #2
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
i would say do sway bars first. that will help a lot with autox.
Shane
PARANOID56 is offline   Reply With Quote
Old 05-18-2007, 01:25 AM   #3
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
swaybars first. best bang for the buck performance improvement.
Arnie is offline   Reply With Quote
Old 05-18-2007, 03:11 AM   #4
WRXBob
Member#: 12455
02 WRX
spring first, sway bar for 'fine tune' later. The reason is you want to reduce the body roll first to improve the handling of the car instead of band aid over-steer with big rear sway bar. But then you will also need struts with the new spring.
WRXBob is offline   Reply With Quote
Old 05-18-2007, 03:37 AM   #5
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
There are a vast number of issues that arise when you replace springs. Swaybars give you better handling with almost no drawbacks.
nhluhr is offline   Reply With Quote
Old 05-18-2007, 08:47 AM   #6
MasterKwan
Member#: 98961
2003 WRX
Yeah, I'm doing sways first. Sways do far more to reduce roll than increasing the spring rate. I was actually thinking shocks, then sways, then springs.
Old 05-18-2007, 09:02 AM   #7
Pain++
Member#: 88289
2006 WRX: Stage 2
Urine-soaked Subway Car
+1 for sways: what a difference for ~$300. I have the same whiteline setup that you're considering. Go for it!
Pain++ is offline   Reply With Quote
Old 05-18-2007, 09:42 AM   #8
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Sway bars reduce body roll far more than any spring suitable for the stock strut will.
Sways should definitely be your first suspension mod.
Tony
Old 05-18-2007, 09:48 AM   #9
Mechie3
Member#: 120152
Get some whiteline sways and kartboy endlinks.
Mechie3 is offline   Reply With Quote
Old 05-18-2007, 09:54 AM   #10
Leadfoot77
Member#: 74268
2013 STi
I did everything at once (just recently). Whiteline adjustables front and rear with kartboy endlinks + kybagx and prodrives. Car handles awesome now - body roll is pretty much gone. I'm running the middle setting on the rear swaybar (think it's 24mm) and the soft setting on the front one plus setting #2 on the agx's. This is currently just for the street - looking forward to playing with these at autox.
nhulr what do you mean about "vast number of issues" from replacing springs? I'm assuming you mean when you JUST replace springs without changing the struts/etc?
Leadfoot77 is offline   Reply With Quote
Old 05-18-2007, 10:38 AM   #11
Turn in Concepts
Member#: 93646
Many Track Records
Nhluhr is talking more about the resultant suspension geometry changes.
Old 05-18-2007, 10:39 AM   #12
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
sway bar first
then...
tires...
then....
springs/struts
then.... alk / lower arm bars etc
one thing at a time so you can grasp the changes
and be certain you like em
Jamie
Old 05-18-2007, 11:24 AM   #13
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
and more
-puts you in a bad place on the camber curve so when you roll, the outer loaded tire goes too positive
-roll center gets pushed low which will likely increase roll in spite of higher springrates
-lowered front roll center means sluggish turn-in due to high yaw damping and also increased rear TLLTD
-struts run out of bump travel which will lead to difficult-to-diagnose and stubborn-to-tune-out understeer on hard turns
-different lowering front-to-rear (common to all aftermarket springs except STI) screws with the car's aerodynamics
Old 05-18-2007, 11:32 AM   #14
Turn in Concepts
Member#: 93646
Many Track Records
Originally Posted by nhluhr View Post
and more
I think you just confused 80% of the people in this thread.
Tony
Old 05-18-2007, 11:33 AM   #15
Leadfoot77
Member#: 74268
2013 STi
and more
I'll have to do some research to figure out what those things mean exactly... (edit: or to put it more plainly - what TIC said )
but it sounds like your recommending that we stick with the stock springs/struts? Also, I'm assuming that most of these effects are only significant mainly in a racing environment like autox or track? In which case the optimal solution is probably coilovers or something with a lot of built-in adjustability so you can fine tune the suspension?
Old 05-18-2007, 11:38 AM   #16
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
oh sorry: TLLTD stands for Tire Lateral Load Transfer Distribution as in, front to rear... so the rears bear more of the total weight transfer when the front rollcenter gets lowered more than the rear rollcenter.
Old 05-18-2007, 12:31 PM   #17
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Another reason to do sways first:
If you find yourself liking autox, you may end up ditching the springs to buy fancier stuff, but you can probably keep the sways no matter what you do.
john
Old 05-18-2007, 05:35 PM   #18
WRXBob
Member#: 12455
02 WRX
For + $300 you can buy a pair of sway bars.
How about buying take off springs from an STI for $75, $350 for AGX, sale the stock suspension for $100 for the cost of the group N top hat. Then later throw in the front sway bar. Pretty good set up for the money compared to the sway bars set up.
Old 05-18-2007, 06:54 PM   #19
steve1221
Member#: 113080
10 WRX
Have you ever even rode in a WRX with a sway bar upgrade? COBB sway bar kit was the best mod I ever did to my 02 WRX (RIP).
steve1221 is offline   Reply With Quote
Old 05-18-2007, 10:07 PM   #20
WRXBob
Member#: 12455
02 WRX
Cobb sway bars are best in my book, because I have them. I also have the AGX and the STI springs, and before that I have Cusco sway bars with stock springs and struts. The sway bars give you over steer, does not reduce body roll has much as one might think, and when the suspension compressed, the rear sway bar gives you snap oversteer while the front still slides. If I set the AGX to the lowest setting, set the rear sway bar to max or middle setting, the car will over steer, but road holding decreased. The most confident handling is when the strut is set to high, and the rear sway bar setting to low. The most handling change comes from adjusting the struts, sway bars are limited in size and adjustments.
I used to be in the sway bar camp too, but if I have to do it again, spring and struts first, my 02.
what should i get first? bugeye-joemomma Brakes, Steering & Suspension 17 01-17-2009 03:59 PM
what should i get first for PS3??? ODiz413 Off-Topic 35 10-11-2007 02:05 AM
what should i get first, gauges or AP? jojotherider AccessPort 10 07-30-2006 10:16 AM
What should I get first, tuna or UTEC? hernan Engine Management & Tuning 8 11-06-2004 02:22 PM
What should I do first? Turbo, or FMIC setup? GMTarkin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-22-2004 11:29 AM
