Southern California Impreza Club
Go Back   NASIOC > NASIOC Chapters > Southern California Impreza Club Forum -- SCIC
Old 04-04-2011, 06:29 PM   #376
Zach04wrx
Member#: 222790
2004 Wrx
Java Black Pearl
So this is probably a dumb question but from what ive read i should be ok. All ive got is a Greddy Ti-c catback and Cobb V2 AP Stage 1 flash. Will i be alright? Thanks in advance
Zach04wrx is offline   Reply With Quote
Old 04-04-2011, 06:53 PM   #377
onefasazn
Member#: 45574
2003 NB2 E-Street
2004 GGA - Prodrive
If you have stock intake, stock downpipe, and stock BPV, you'll be fine.
onefasazn is offline   Reply With Quote
Old 04-06-2011, 03:46 AM   #378
Zach04wrx
Member#: 222790
2004 Wrx
Java Black Pearl
Yup all stock cept for the ap and cat back
Old 04-08-2011, 10:36 AM   #379
pimpUall
Member#: 55424
2005 380hp LGT Wagon
Anyone try to smog their car while runnng e85?
pimpUall is offline   Reply With Quote
Old 04-08-2011, 10:39 AM   #380
rockacello
Member#: 265282
2002 WRX Wagon
I tried running 4-5 gallons, it helped bring it down 7-9 pts on the HC but that was about it. It wasn't enough for me anyway...
rockacello is offline   Reply With Quote
Old 04-09-2011, 03:04 PM   #381
Frankenboost
Member#: 209766
2007 STI limited
UGM - 547WHP / 471TQ
I'm going to have fun when I need new tabs here huh? Oh boy. Might be PMing some of you for questions and help. My car is FAR from stock. And that's an understatement.
Frankenboost is offline   Reply With Quote
Old 04-09-2011, 03:12 PM   #382
EPlascencia60
Member#: 254170
1997 Legacy GT
GW- Socal F4 #46
If anyone has any questions on smog give me a haller... Smog Tech here...
EPlascencia60 is offline   Reply With Quote
Old 04-10-2011, 11:38 PM   #383
topguneagle1
Member#: 115620
2000 Impreza coupe
FALCON 9
does anyone know the laws on removing or tampering with abs? can i still be CARB approved if i remove it?
topguneagle1 is offline   Reply With Quote
Old 04-13-2011, 04:06 AM   #384
topguneagle1
Member#: 115620
2000 Impreza coupe
FALCON 9
bumpesrs
Old 04-13-2011, 12:46 PM   #385
onefasazn
Member#: 45574
2003 NB2 E-Street
2004 GGA - Prodrive
Removing the ABS has nothing to do with emissions, therefore you shouldn't have a problem.
Old 04-25-2011, 02:46 AM   #386
EPlascencia60
Member#: 254170
1997 Legacy GT
GW- Socal F4 #46
ABS and Air Bag faults will not cause your vehicle to fail.
Old 04-25-2011, 10:21 AM   #387
EDM
Member#: 82078
2015 VW GTI
Carbon Steel Grey
You'll be fine. Mine passed with AP stg 1 OTS map, STi uppipe and Prodrive axleback.
EDM is offline   Reply With Quote
Old 04-25-2011, 04:39 PM   #388
SubyFi
Member#: 68312
2005 Impreza WRX STi
OBP under a layer of dust
My 2005 STi just passed the smog test. I drove it a couple of miles before the test to heat up the catalytic converter.
  • BPM GT turbo back exhaust with one high flow cat in the mid-pipe and silencer installed.
  • Second O2 sensor with extended fitting after high flow cat.
  • Trimmed stock turbo heat shield to fit catless divorced downpipe.
  • Cobb Accessport Stage 2 Protune on 91 octane.
  • Mechanical boost and EGT gauges mounted in center of dash.
An older gentleman was running a test only shop behind a gas station. He offered a free retest within 30 days. The hood was opened and he pretty much looked around the driver's side only. He did not look under the car at all. A plug was connected into the OBDII port and the sniffer into the tailpipe.
Idle Emission Test Results
Test #1: 850 RPM
Test #2: 2650 RPM
HC (PPM)
#1: Max 100, Measured 70 - He says this number is high for a 2005 car.
#2: Max 130, Measured 17
CO (%)
#1: Max 1.00, Measured 0.13
#2: Max 1.00, Measured 0.63
CO2
#1: 13%
#2: 13%
O2
#1: 2.0%
#2: 0.7%
SubyFi is offline   Reply With Quote
Old 04-28-2011, 05:44 AM   #389
topguneagle1
Member#: 115620
2000 Impreza coupe
FALCON 9
thank you gentlemen.
Old 05-06-2011, 07:17 PM   #390
hamsup
Member#: 90100
2005 Saab 92-X
Default Failed Visual and MIL Check Engine Light Test, but passed emissions.
I went to a shop in Aliso Viejo, two guys working tag team on the job.
2005 Saab 92x
Cobb DP with High Flow Cat
Cobb TBE Exhaust
Stock Uppipe
V1 Access Port
The guys there looked at the diagram on the hood. They said I'm missing the catalytic converter, wiring to sensors, missing oxygen sensor.
I also failed the MIL/Check Engine Light Test due to failure to successfully compete OBD self tests. I'm going to put the stock DP and Exhaust back on, should I unmarry the AccessPort? Or is the MIL/Check Engine Light Test another issue? I also just had my 60k service done and spark plugs changed like 50-60 miles ago.
I just plugged in my PLX Kiwi Wifi ODBII scanner, it says I failed 2 of the 5 readiness monitors. Catalyst and Oxygen Sensor Monitoring. From what I read I need to drive the car some more?
I got one free retest so I need to make sure I get it right.
I passed the Idle Emissions
Test #1 718 RPM
Test #2 2544 RPM
%CO2
#1 14.4
#2 14.5
%O2
#1 0.4
#2 0.1
HC (PPM)
#1 meas 62
#2 meas 25
CO%
#1 0.07
#2 0.30
Last edited by hamsup; 05-06-2011 at 08:14 PM. Reason: comment about free retest and readiness monitor.
hamsup is offline   Reply With Quote
Old 05-07-2011, 02:19 AM   #391
onefasazn
Member#: 45574
2003 NB2 E-Street
2004 GGA - Prodrive
2005 Saab 92x
Cobb TBE Exhaust
Stock Uppipe
V1 Access Port
Test #1 718 RPM
Test #2 2544 RPM
%CO2
#1 14.4
#2 14.5
%O2
#1 0.4
#2 0.1
HC (PPM)
#1 meas 62
#2 meas 25
CO%
#1 0.07
#2 0.30
Drive your car for a bit and go to another shop. The guys at the shop you went to were doing a good and full inspection and were right to fail you. The monitors should reset after a good session of mixed driving on the street and freeway. If you go to another more lenient shop, you should be able to pass with your setup. You just need to make sure your monitors are set.
You can get almost any smog shop to check your readiness monitors for you before a test. If you don't pass those, the rest of the test will be a waste of time anyway.
Old 05-08-2011, 02:28 PM   #392
EPlascencia60
Member#: 254170
1997 Legacy GT
GW- Socal F4 #46
^Agree!
The reason for failing OBD Self-test is because either a check engine light (MIL) was removed/serviced and/or battery disconnection/voltage loss to the vehicle PCM. I recommend driving the vehicle 60-100 miles on fwy after performing any of the above. Most smog, repair shops or even auto parts stores can check monitors at no charge if you ask nicely
KEEP IN MIND!!!!!!!!!!!!: For vehicles model year '96-'00 you can have 2 monitors "Not Ready" and still pass, HOWEVER on '01-newer you may only have 1 "Not Ready" in order to pass.
Old 05-08-2011, 11:06 PM   #393
hamsup
Member#: 90100
2005 Saab 92-X
^Agree!
Its been about 300 miles, my scanner now reads 5 of 6 readiness monitors good, only one being stubborn is Oxygen Sensor monitor. So technically I can pass with 1 "not ready". Thanks for the info.
Old 05-09-2011, 01:40 AM   #394
pimpUall
Member#: 55424
What would happen if you got a smog check running e85?
Old 05-11-2011, 02:44 PM   #395
EPlascencia60
Member#: 254170
1997 Legacy GT
GW- Socal F4 #46
Hamsup: That is correct! No Problem PM if any questions...
You would lower HC & CO slightly but not enough to make a huge difference.
Old 05-13-2011, 04:12 PM   #396
schwett
Member#: 282656
2011 WRX Limited
Question 2011 wrx from oregon - why do i need a smog test??!
hi all - new to the forum and subaru here.
picked up a 2011 wrx limited wagon at a dealer in oregon a few weeks ago. couldn't find any in cali in the color / options i wanted. was assured by the dealer that the car is 50 state emissions certified (the hood says so also), but the DMV here in CA is insisting that i need a smog check.
dealer claims they've sold 100s of cars to people in CA... but the DMV did not seem at all interested or impressed by the emissions certifications the car came with or that were mailed to the DMV directly from the dealer.
anyone have experience with this? we all know that the exact same car could have been sold in california, but at this point it seems to be a procedural matter.
thanks in advance for any advice! loving the car so far - it's a big change from my s2000... and it has a back seat for a car seat, which i'll need in about 6 weeks.
schwett is offline   Reply With Quote
Old 05-14-2011, 04:42 AM   #397
pimpUall
Member#: 55424
From what I understand all cars coming into CA from out of state have to be smoged within like 30 days. I can check with my wife in the morning when she gets up. She work for the DMV.
Old 05-15-2011, 03:48 AM   #398
EPlascencia60
Member#: 254170
1997 Legacy GT
GW- Socal F4 #46
True^ ANY vehicle from out of state is required to do a smog inspection in california in order to register as a california car. The reason that they don't care much for other state's emission inspectiong is because here in ca, the state is far more strict.
Old 05-22-2011, 08:32 PM   #399
Porsche914boxer4
Member#: 4692
2005 Merc E55 AMG
www.tommygunrally.com
Hi I need a smog hookup for a catless 1983 VW race car in San Diego. PM me if you know of any.
Porsche914boxer4 is offline   Reply With Quote
Old 05-23-2011, 11:50 AM   #400
stispice
Member#: 206641
2005 STI
Default OC smog friendly shop?
Anyone know of a smog friendly shop in the Orange County area?
I just moved back to SoCal after living in South Carolina where I bought my 05 STi. I need to get new CA registration this week and I'm looking for a shop that might be less strict on the visual inspection.
PM me if you have any recommendations. Thanks.
stispice is offline   Reply With Quote
P0171 CEL Thread - Everything you ever wanted to know? CirrusWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 615 09-08-2016 09:33 AM
Everything you ever wanted to know about anything ever made......ever Hester Prynne Off-Topic 12 11-05-2008 06:57 PM
Everything you ever wanted to know about exaust systems Back Road Runner Normally Aspirated Powertrain 9 10-24-2006 10:59 PM
('93-'01) Everything you ever wanted to know about Subarus... Porsche914boxer4 Impreza Forum 15 07-23-2001 10:17 PM
Everything you ever wanted to know about WRX exhauasts (old model) --> rao Normally Aspirated Powertrain 5 02-12-2001 09:56 PM
