Old 05-17-2007, 08:53 PM   #1
glhs377
Member#: 125388
97 240hp NA GF6
giant Carbotron wing
Default 04 STi modified AVCS map for download
Hi all. I've been working on this for a while now. since october 06. I'm going to be changing things up a bit with a custom all carbon ram airbox/ turbo inlet(from my company kradcarbon.com), and a lot more hopefully. So this is probably the last iteration that would be applicable to anyone else. time to share! so this is a damned good map for my current engine setup which is:
04 STi ~27k miles
BPM catless TBE(divorced wg tube)
APEXi short ram
greddy catch can
and i monitor it with:
ZT2 wideband(into the ecu's fuel level sender for logging)
greddy DG gauges
i'm pleased to share it in the interest of the group overall.
any criticism and help is appreciated and welcomed, and i'm open to discuss most aspects of the tune. i've been datalogging and comparing more than just WOT, so it's very drivable, this avcs map gives the best response, spoolup and topend with no negative KC. i run AFRs of ~12-12.5:1 which some people will tell you will blow the hell up. no. if you're worried, go thru the fuel map, it's 11.5:1 at higher loads. it should be fine and run those AFRs with a stock housing. my MAF scalar is set to run a little leaner than that. i doubt anyone else will use this one. also it's scaled out to 3 g/rev, cause well, i needed it. my injectors are pretty maxed out ~95% and i need to work on the boost tables more, but all in all a good map for now. i was foccusing my efforts on the avcs portion of it.
if you like em, tell me about it!
if you dyno with them, tell me about it!
so, just save these as:
APEXI SHORT RAM large MAF HOUSING
STOCK MAF SCALED
i'll post them on my site with a specific STi page soon enough.
good luck!
disclaimer: if you blow your car up, don't cry to me or expect me to pay for a new engine or even new sparkplugs. you're on your own. you're a big boy, grow a pair. in the spirit of free software I'd like to point out that these maps are my intellectual property and you can use them all you want as an individual, but they are not to be sold or purchased! i won't be selling them, so why should you?
glhs377 is offline   Reply With Quote
Old 05-18-2007, 12:59 AM   #2
dmross
Member#: 2818
2000 2.5RS
Halp i tride to put this on my accesport but it says com1 intrface not repsonding do i need a cobb intake for it and will it work with my mbc sorry to asak so many questions i jjust dont wan my car to go slow becaue my frineds specv is gona race me tomorrow and i have to show him subarus ar the best!!!11
dmross is offline   Reply With Quote
Old 05-18-2007, 01:19 AM   #3
glhs377
Member#: 125388
97 240hp NA GF6
oh! dude! i'm so sorry! i'll be right over to sort that out! like, totally, i'll put bubblegum on your MBC for max boost from that 30R and then we can do a 3 wide ZOMG! that specV is SO in for it! we'll sho it it's teh slowwwarrr!
oh. wait. dude, you sold your accesport last week. and your ej257 isn't close to stock and is in a GC with powerFC... i want REAL feedback! REAL! thanks for getting my hopes up somebody tried it...
Old 05-18-2007, 02:23 PM   #4
Nuke209
Member#: 108089
2003 WRX
NF Performance
WHAT????
Nuke209 is offline   Reply With Quote
Old 05-18-2007, 03:28 PM   #5
glhs377
Member#: 125388
97 240hp NA GF6
he's a friend, he's giving me crap by imitating a n00b..
Old 05-18-2007, 03:35 PM   #6
Nuke209
Member#: 108089
2003 WRX
NF Performance
Oh, ok
just wondering, still on stock boost solenoid right?
you have any logs from your car on this map?
both stock maf and big maf?
Old 05-18-2007, 04:12 PM   #7
glhs377
Member#: 125388
97 240hp NA GF6
my car never came with a stock MAF, i have tons of logs, it's starting to get nice and hot here, and i don't have any really recent ones, but the rest of the map isn't much different from stock. i've been on this particular map for ~2 weeks now. it's really nice, and that was just homing in on my MAF scaling. last i logged i got no knock, and still a bunch of +KC.. but what did you want to see? the avcs portion of the map is probably what you're interested in. try it out! just copy the AVCS maps to your cells and give it a shot. you won't need any timing or fuel changes, but you'll want to at least set your KC to have more allowance to find your own timing maps. use it as a base to your own tuning on. it wouldn't work well for you as you have different top feed injectors anyway. yes, stock boost solenoid.
Old 05-18-2007, 04:42 PM   #8
Nuke209
Member#: 108089
2003 WRX
NF Performance
Oh, I'm sorry
My friend has an 04 sti
this isn't for my car lol
I'll try the AVCS on his map and see how it runs
Old 05-18-2007, 07:09 PM   #9
glhs377
Member#: 125388
97 240hp NA GF6
should be a blast! dont' forget to datalog!
Old 05-18-2007, 11:42 PM   #10
Kjott21
Member#: 116937
2011 WRX DGM
forums.pghsubarus.com
Can this be used on an 05 STi as well? I have an acquaintance and I am not sure if he has a 04 or 05 yet but he is looking to do a TBE and reflash of some sort.
Kjott21 is offline   Reply With Quote
Old 05-19-2007, 08:57 AM   #11
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Why do you pull timing down so sharply in the higher rpms at the low load points? Why at the same time do you richen the fuel map into the 10s in the same area? What Octane was this tuned on?
Old 05-19-2007, 11:22 AM   #12
glhs377
Member#: 125388
97 240hp NA GF6
lol, that's just for a little bit of safe anit-lag/fireball shooting action. you can copy the factory maps into those areas if you like.
for use on an 05, i'd start with an 05 base map and copy over the tables..
93 octane.
Old 05-20-2007, 12:25 PM   #13
glhs377
Member#: 125388
97 240hp NA GF6
so how'd it go? i just went thru and looked at your avcs maps from the "AVCS anyone?" thread, have to say i hadn't been keeping up. your maps are vastly different than mine. interesting to see what someone else who's tried otherwise has to say about them.
Old 05-27-2007, 01:00 PM   #14
glhs377
Member#: 125388
97 240hp NA GF6
went thru evolution stage1 yesterday, both instructors that drove the car were very impressed with the boost response, first one actually took it around for a couple joy rides, loving it, and the second one liked the sideways action and actually said i should probably tune it down a bit, as in the slalom the boost came on a bit too fast and hard to control easily. i got thru that tho, very delicate footwork hah! i'll work on it too, as i've only changed the full throttle WGDC maps. but these guys drive stis and evos and stuff all the time. so that was good news! suffice to say the avcs maps rock! i want to work on the topend a bit more, i've been creeping up on the maps i have now. my injectors are ~93% duty cycle with this map at 1 bar boost @6500rpm, 12:1 AF on the nose with 2.6G/rev loading. also did the changes to the WG maps running 95% WGDC there, so i think i'll be doing some bigger injectors, or bumping the fuel pressure and maybe EWG or BCS.. need to look into that.
UTEC Tuner or maps for download TheReaper UTEC 10 08-01-2006 05:00 PM
FS 04 STI UTEC w/ map selector or trade for defi gauges waploom Private 'For Sale' Classifieds 9 04-24-2006 05:29 PM
04 STi utec economy map intpostman23 Engine Management & Tuning 10 09-07-2005 10:17 PM
SoCal 04 STI Utec w/map selector $750 timaps714 Private 'For Sale' Classifieds 0 03-14-2005 12:37 PM
MY03 STi & WRX Video for Download fatcatwrx General Community 7 09-30-2002 04:50 AM
