Old 05-17-2007, 09:44 PM   #1
RS2001
Member#: 3210
01 RS Coupe
05 WRX Wagon
Default P0483 Cooling Fan Rationality Check Malfunction
What the hell is this? I have a 2001 RS (as made obvious by my name) with 95000 miles on it and it just threw this code. My cooling fan seems to be working fine, so I can't really imagine what the problem is? As luck would have it, I need to get my car smogged too, so I need this fixed a.s.a.p. Is anyone familiar with this?
-Dan
RS2001 is offline   Reply With Quote
Old 05-17-2007, 10:40 PM   #2
nast
Member#: 124325
98 Forester S
Someone correct me if I'm wrong... but I think it is when the coolant fan circuit is on for a certain amount of time but the water temperature doesn't decrease a reasonable amount. Possibly because of insufficient coolant or coolant flow, busted radiator fan, poor air flow....
I may be thinking of a different code...
If you aren't having any overheating issues maybe the code is just a fluke occurrence. Check your coolant level and clear the code... maybe it won't come back.
nast is offline   Reply With Quote
Old 05-17-2007, 11:11 PM   #3
Jon [in CT]
Member#: 2992
02 WRX Sedan
I think this code is set when the Engine Coolant Temperature (ECT) sensor signal fails to rise above 15 mV (~1°F) after 2.5 minutes of operation.
You probably need a new ECT sensor.
Jon [in CT] is offline   Reply With Quote
Old 05-22-2007, 03:23 PM   #4
RS2001
Member#: 3210
01 RS Coupe
05 WRX Wagon
I'll check the coolant level this afternoon.
New ECT sensor? Great, how much is the dealer gonna rape me for that?
-Dan
Old 07-14-2007, 02:48 AM   #5
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
I'm pretty sure I'm going to need one myself:
http://www.auto-parts-wholesale.com/...EmbWRpZD0xMTMx
I just don't know where the hell this part is located.. Can anyone help?
-Ellz
ejicon is offline   Reply With Quote
Old 09-10-2009, 06:25 PM   #6
sick1.8t
Member#: 22345
2003 RSX
black
i know this is an old thread but just for anyone else looking, the coolant sensor (ect) is on the coolant crosspipe under the intake manifold. have fun getting at it. its got a one wire connector i believe.
i've also read this could be because of a clogged or poor flowing radiator or a bad thermostat not allowing the coolant to move around and cool enough.
sick1.8t is offline   Reply With Quote
Old 09-10-2009, 09:29 PM   #7
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
good to know
CEL P0483 Cooling fan rationality check malfunction Loki Service & Maintenance 13 10-31-2012 03:46 PM
Cooling fan rationality check? crpwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-18-2010 01:08 AM
P0483 Control Fan Rationality Check Malfunction Sudaka Service & Maintenance 7 03-25-2009 01:40 AM
cooling/radiator fan rationality check? boshot427 Normally Aspirated Powertrain 0 03-22-2007 08:22 PM
p0483- cooling fan rational Rubasu Normally Aspirated Powertrain 2 11-12-2003 09:47 AM
