Welcome to the North American Subaru Impreza Owners Club Saturday July 26, 2014
Old 05-17-2007, 11:56 PM   #1
pulser9
Member#: 143202
2003 wrx
black
Default to build up my 2.0 or to build a 2.5
Ok so im thinking about doing engine work right now.
Right now i just have a vf30, sti injectors, greddy front mount, utec ecu, greddy turbo back exhaust.
So what i was thinking is to build my 2.0 with new internals and run a 20g or somthing just a little bigger and try to push 350hp
Or to build a hybrid
get like a stage 2 block and use my wrx heads and run a gt30r and try to push the 430 range
What do you guys think i should do
O yea a jdm 6speed or ppg gearsets are going in very soon so the trans isnt an issue
pulser9 is offline   Reply With Quote
Old 05-18-2007, 12:07 AM   #2
wilrock
Member#: 121960
Default 2,5
2.5l +ppg + 20g or bigger= satisfaction.
wilrock is offline   Reply With Quote
Old 05-18-2007, 12:08 AM   #3
rexworx
Member#: 103232
MY05 GDA,MY04FXT6spd
2.5ltr,PPG,Front LSD,4.44
IMO get the 2.5 You can make horsepower, but you cant make torque, all you can do is enhance what you already have. it will cost more but id rather have the 2.5, much more drivable.
Someone once told me " Horsepower sells cars, Torque wins races".
rexworx is offline   Reply With Quote
Old 05-18-2007, 12:20 AM   #4
4wdwrx
Member#: 72042
2002 WRX impreza
WRB "Blue Mammoth"
ya you are right about the 2.5 more drivable. but the quote is not entirely correct . well besides the quarter mile anyways.
4wdwrx is offline   Reply With Quote
Old 05-18-2007, 12:35 AM   #5
rexworx
Member#: 103232
I understand what you mean.
I guess what im trying to say is if you have a broader flatter torque curve the car will have more get up and go. the less torque and more peaky power band the more you will have to beat the hell out of the car to have any fun.
Im just a sucker for 2.5 swaps
Old 05-18-2007, 05:04 AM   #6
poormansporsche
Member#: 79798
I think 2.0's have a lot of potential. You should see what the boys across the pond are doing with them. But whatever floats your boat. I like the 2.slow's.
cheers
garrett
poormansporsche is offline   Reply With Quote
Old 05-18-2007, 09:43 AM   #7
JMK508
Member#: 115420
Its like a STI.....
but it doesn't break
The 2.5 is alot more Daily driver friendly. Your off boost power will be night and day.
JMK508 is offline   Reply With Quote
Old 05-18-2007, 03:04 PM   #8
WRXDriftR
Member#: 65065
04 WRX/ STi Hybrid
6MT, VF43
if you build a 2.0, YOU WILL ONLY BE WISHING YOU HAD A 2.5
Do it right the first time around and youll save money in the long run!
WRXDriftR is offline   Reply With Quote
Old 05-18-2007, 03:08 PM   #9
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Open < Semi-closed. Go for the 2.5L. You would be surprised at the cost. The 2.0L will cost just as much as a stock 2.5L which will hold 500 hp reliably all day....no point in building it.
CoolRex is offline   Reply With Quote
Old 05-18-2007, 03:19 PM   #10
AWDWRXLOVER
Member#: 50267
02 built hybrid
sr55/meth/sick speed
dont forget about cams if you want power up top. you be limited in the upper rpm range if you leave it stock.
AWDWRXLOVER is offline   Reply With Quote
Old 05-18-2007, 05:40 PM   #11
japslapr
Member#: 100150
02 V9 STi 6spd
HTA Green, Built EJ205
I had your question about 5 months ago. I'm in the process of building my 2.0l. It is WAY more expensive to build the 2.0 vs buying a 2.5 shortblock and calling it a day. Just my machine shop bill is 2k.... the shortblock alone is cheaper than that, never mind pistons, rods, cams, etc... I can tell you that the 430awhp you want out of the 2.5 I WILL make on my 2.0l. NOt even really hard to do, you just have to be willing to sacrafice a little. I didn't go with the 2.5 because everyone has one. That is beyond common these days. That for me is boring.
And... my 205 is now semi closed.
Don't think the 205 isn't capable... just becasue everyone takes the easy route doesn't mean it can't be done. I'm looking to run 10.'s with my ej205.
japslapr is offline   Reply With Quote
Old 05-18-2007, 05:46 PM   #12
flukewrx
Member#: 75081
2003 WRX
cheers
garrett
True, but the 2.0's across the pond are running the EJ207 not the EJ205 (or at least I think that is the motor you are talking about). EJ207 is definitely superior to the EJ205 motor.
If you really want the TQ, why not go EZ30 or EZ30R?
flukewrx is offline   Reply With Quote
Old 05-18-2007, 10:20 PM   #13
poormansporsche
Member#: 79798
The 207 is a great motor. I think the EJ20G shortblock is the money tho. And nothing wrong with the 205 if it's built. It's pretty similar to the STI Version 3 motor only better in that it's end thrust bearing'd. The heads on the 205 are supposed to be similar to the casting of the EJ20G heads. Not too bad. They have room to be messed with at least.
cheers
garrett
Old 05-19-2007, 08:13 PM   #14
Works
Member#: 32339
02 WRX
325whp / 300wtq
2.5 build up is where it's at, but you need to be worrying about that tranny and all that power she's going to need to be able to handle...
Works is offline   Reply With Quote
04 Shell with JDM STi 5 spd, Stock 2.0 or STi 2.5? iRide Subaru Conversions 5 03-24-2009 10:59 AM
wtb 2.0 or 2.5 block or full motor addiction AKIC Private Classifieds 8 03-22-2009 04:18 PM
Is it worth building out a 2.0 or just swap to a 2.5 birdman.1 Subaru Conversions 2 02-23-2009 11:42 AM
2.0 or 2.5 build sammyswrxsti Built Motor Discussion 3 09-27-2008 12:03 PM
2.0 wrx to 2.5 sti full swap - what should be on my shopping list? hybrid gti 2 Subaru Conversions 6 03-04-2008 01:12 AM
