Old 05-18-2007, 01:00 AM   #1
StiNV76
Member#: 148633
2002 Impreza WRX
Question Spark Plug Recommendations...?
I own a 02 wrx that I will soon install Borla headers, and catless up and down pipe. I figured I might as well change the spark plugs while I have that much of the motor taken apart. I was going to buy the stock NGK's, but was wondering if there might be a preferred spark plug out there, especially for the increased hp.
StiNV76 is offline   Reply With Quote
Old 05-18-2007, 01:47 AM   #2
bdpAKAknox
Member#: 121248
keep them stock and dont use the headers and you should be good to go.
bdpAKAknox is offline   Reply With Quote
Old 05-18-2007, 02:25 AM   #3
HemiKLR
Member#: 80625
VIII Evolution
Change it Platnum Iridiums.... A step colder isn't a bad way to go. As for the headers... send them back.. your money could be better spent in a number of ways. You won't see the gains your looking for. Search it if you don't believe me, this has been covered time and time again. Best of luck
HemiKLR is offline   Reply With Quote
Old 05-18-2007, 02:02 PM   #4
Samurai Jack
Member#: 21145
2002 Enemy of Aku
You are not doing anything that requires a change in spark plug heat range. Stick with the stock heat range.
If you install headers, you will pick up some power on the top end, but you will be giving away torque on the bottom end. More torque = better acceleration.
Samurai Jack is offline   Reply With Quote
Old 05-18-2007, 02:18 PM   #5
fino22
Member#: 118868
2003 WRX
MBP
dont get the headers or sparkplugs and use that money towards engine management...imo
fino22 is offline   Reply With Quote
Old 05-18-2007, 05:37 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
ngk bkr6E at .028" - .030" and done
Spark plug recommendations? Mobius118 Newbies & FAQs 3 10-08-2008 06:47 AM
Spark plug recommendations STL WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-09-2008 01:54 PM
spark plug recommendation attitude Service & Maintenance 8 01-12-2005 09:23 PM
Spark Plug recommendations for running N20?? AustinSTi Normally Aspirated Powertrain 14 03-01-2003 03:54 PM
What spark plug do you recommend for 2000 RS? Longitude Service & Maintenance 4 04-23-2002 10:04 PM
