Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 05-18-2007, 01:26 AM   #1
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
Default 02 WRX Bug Eye with FP Green, etc
This sheet is interesting
This is the car with the stock turbo
Vs.
adding the FP green at 21 psi pump gas tuned
Car has a built bottom end and cams and valve springs hence the nigh rev limit
Basic Stage II - IV mods - TMIC - ecutek reflash - etc
Should be interesting on higher boost - the customer ran out of maf so I am suggesting a UTEC or Hydra
Al
Dyno Flash is offline   Reply With Quote
Old 05-18-2007, 01:32 AM   #2
kcook
Member#: 78074
2005 STi
so he has no injectors or fp or EM?
kcook is offline   Reply With Quote
Old 05-18-2007, 01:41 AM   #3
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
Yes 750 DW injectors and the ecutek flash I mentioned above
Old 05-18-2007, 01:42 AM   #4
GC8drifter86
Member#: 57896
im pretty sure it does, cause he said basic stage II to stage IV mods. (ie injectors, fuel pump, etc....)
GC8drifter86 is offline   Reply With Quote
Old 05-18-2007, 01:46 AM   #5
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
Yes thanks for pointing that out
Walbro pump - fuel rails - fpr
It had a top mount
Almost a Stage IV
Old 05-18-2007, 01:50 AM   #6
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
id rather the curve of the race gas'd vf34 you posted.......fwiw
bren wrx is offline   Reply With Quote
Old 05-18-2007, 07:42 AM   #7
TAPOUT
Member#: 127670
2007 HTA GT3794
Darton Sleeved
Is it just me, or does the powerband really come on late? Not much spool until 5500-6000. While I appreciate the fact that it is built to run to 8000, I think for the daily driving, that is a bit high to get into the poewr band.
TAPOUT is offline   Reply With Quote
Old 05-18-2007, 08:10 AM   #8
WRenXhaven
Member#: 43905
02 WRXBastardchild
guessing its still a 2.0, big cams and Green would definitely push the power band out.
WRenXhaven is offline   Reply With Quote
Old 05-18-2007, 10:24 AM   #9
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
A green should hit full boost by ATLEAST 4700rpm on a 2.0
I wonder if his scaling on the dyno sheet is wrong.
akira02rex is offline   Reply With Quote
Old 05-18-2007, 10:28 AM   #10
kcook
Member#: 78074
2005 STi
if he has all supporting mods .. 300 seems a little low WITH a built bottom end
Old 05-18-2007, 10:44 AM   #11
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
Yeah, and look at the torque. Looks like he's running really low boost to me.
Old 05-18-2007, 12:34 PM   #12
gotti
Member#: 62956
06 sti rally car
gottiracing
why does the graph start at 4k?
gotti is offline   Reply With Quote
Old 05-18-2007, 01:41 PM   #13
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
Yes the car was at low boost as the maf was exceeded at this point
The customer needs to add UTEC and SD or a Hyrdra
A big MAf was not suggested as with his lopy cams I dount the idel and driveability would be tolerable
Old 05-18-2007, 02:36 PM   #14
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
its his heads that are helping him make power at high rpms, not nesc. the built bottom end.
this car will be really fast at the track I bet
PaulRex is offline   Reply With Quote
Old 05-18-2007, 02:47 PM   #15
McBain_TP
Member#: 43986
2002 WRX wagon RIP
2003 330ci black/tan
Originally Posted by Dyno Flash View Post
A big MAf was not suggested as with his lopy cams I doubt the idle and driveability would be tolerable
My car has 264 cams, a bigMAF, ECUtek, and a poor idle. It stalls if it isn't idling at 1100-1200 rpm, and frequently drops to 600-700 rpm. So the cause may be the intake? My regular Perrin short ram maxxed out at around 305 whp, and we picked up a bunch of power by switching to the bigMAF, apparently at the expense of driveability.
McBain_TP is offline   Reply With Quote
02 WRX bug eye wagon [email protected] Private Vehicle 'For Sale' Classifieds 8 04-03-2009 09:25 AM
WTT:NY Crazy trade, Axis block with FP Green, etc for stock STi singincanary Tri-State Area Private Classifieds 25 08-05-2007 04:22 PM
05 STI with FP Green, fmic, Ecutek etc Dyno Flash Proven Power Bragging 13 07-07-2007 06:27 PM
FS tein sprints 02 wrx bug eye lj76 TXIC Private Classifieds 0 04-09-2007 07:25 PM
Dyno Flash Pro Tune - 02 bug eye with VF22, etc Dyno Flash Proven Power Bragging 35 10-26-2006 01:09 PM
