Old 05-19-2007, 03:56 PM   #1
need2boost
Member#: 118163
2006 EWG vf39 WRX
RA TRANNY
Default just got back from the track with my2006 TR
UPDATE!!!
the other night i ran at the track and was alot more happy with my results, I ran a [email protected] with a 1.89 60'
I used a little better launch by slipping until all the slack was out of the drivetrain then letting out on the clutch, not quite a drop.
My mods are
2006 Subaru TR
weighs in @3240 with me and a half tank of gas
vf39 turbo ported EWG with Tial 38mm and dump tube
XS power TMIC
Tsudo downpipe
HKS Hi-power Exhaust
APS 3" turbo inlet with Cobb SF intake
Cobb AcessPort tuned by PDX (mail-in tune)
Walbro 255
Vodoo III MBC @20psi
TGV deletes
ported and coated headers
need2boost is offline   Reply With Quote
Old 05-19-2007, 04:32 PM   #2
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
looks nice but that mail in tune probably doesnt liek some of your mods....like tgv delete and mbc at ptfb
bren wrx is offline   Reply With Quote
Old 05-19-2007, 04:46 PM   #3
06blksubwrx
Member#: 109084
07 4EAT Forester
11.8 @115
Nice trap speed, good for mid to low 12's.
06blksubwrx is offline   Reply With Quote
Old 05-19-2007, 04:53 PM   #4
V6TurboTA
Member#: 9090
09 Forester Gump
02WRX->04STi->09Gump
yeah the car is running great power wise. Once you get your 60' sorted out the car should be flying.
~v6
V6TurboTA is offline   Reply With Quote
Old 05-19-2007, 06:12 PM   #5
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
ACT or an Exedy clutch.. You dont need anything crazy as far as clutch discs go, but I know the exedy clutches like the organic one I have come with an uprated pressure plate and thats really whats going to help you.
Its possible you glazed your clutch launching it on the very first try and that ruined it for the whole night
PaulRex is offline   Reply With Quote
Old 05-19-2007, 07:04 PM   #6
need2boost
Member#: 118163
2006 EWG vf39 WRX
RA TRANNY
yeah my buddy in a 2006 EVO IX ran a [email protected] with just a MBC,Intake and cat-back exhaust, he also had a bad 60' time, his first run was a [email protected] he hit his brakes bad, before the last cone
Old 05-19-2007, 09:02 PM   #7
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
110 traps get me 12.6xx
Old 05-20-2007, 03:42 PM   #8
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
pump or race gas?
seems fast for pump.
Old 05-20-2007, 05:22 PM   #9
mcwop23
Member#: 24589
1995 Mazda RX7
[email protected] w/ LS2
a good launch will put you at 12.3-12.4
mcwop23 is offline   Reply With Quote
Old 05-20-2007, 05:33 PM   #10
Sypher
Member#: 106366
2006 WRX
damn dude nice trapspeed with a better 60FT youde be running very low 12's
Sypher is offline   Reply With Quote
Old 05-21-2007, 11:30 AM   #11
need2boost
Member#: 118163
2006 EWG vf39 WRX
RA TRANNY
this was on pump 93oct,
my main problem right now is the top of 4th in my car is at [email protected]+/- my rev limiter is at that so i need to raise that to about 7400rpms to trap higher. I don't see a problem with that since its the same motor that the 07 sti has.
The Trap is really what i care about " the beauty of the top end"
Old 05-21-2007, 12:09 PM   #12
kn0bby8
Member#: 97644
2006 WRX
I have similar mods and trap anywhere from 109 to 111.6. Just like you I can't get a decent 60ft. The last time I was at the track my clutch glazed over pretty bad. I havn't been back since cause I can't afford to put a clutch in the car. I run into the same problems you are having clutch slips hard when trying to launch high in the rpms or the tires spin. When I launch a little lower in the rpms I bog. I got about 20 or so launches on the clutch and around 18000 on the clock.
kn0bby8 is offline   Reply With Quote
Old 05-21-2007, 12:54 PM   #13
06blksubwrx
Member#: 109084
07 4EAT Forester
11.8 @115
I have the same exact problem, I glazed my clutch on the first run and it ruined the rest of the night. I can't get a good launch, my 60's are anywhere from 1.8 to 2.0, where they use to be 1.69 to 1.7.
Old 05-21-2007, 01:19 PM   #14
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
ouch only 18,000miles.. if your on the stock clutch thats probably why. If you put in an Exedy Stage1 clutch, or comparable uprated clutch disc/pressure plate you'll probably get at least 25-30k out of it even if you do 50 passes at the track from my experience. Plus, if thats your first clutch and your first AWD car you've ever launched you are probably just better at doing it now and thats going to make it last longer anyway..
Old 05-22-2007, 10:39 AM   #15
kn0bby8
Member#: 97644
2006 WRX
To the OP sorry for the highjack...I aint sure if my clutch is shot but it glazed over pretty good the last time i went to the track...so i am afraid to take it back casue i can't afford to do a clutch now.
Old 05-22-2007, 10:40 AM   #16
kn0bby8
Member#: 97644
2006 WRX
I would be happy with a 1.8. It would put me in the 12.5 range on most of my passes.
Old 05-22-2007, 01:32 PM   #17
need2boost
Member#: 118163
2006 EWG vf39 WRX
RA TRANNY
yeah my last run of the night i slipped the clutch out and when i released the clutch pedal the clutch kept slipping all the way in first, It Glazed over pretty bad and when i take off normal it jerks a little in first, not sure if it's going to be toasted or not. I've got 16000 miles on the clock and have had this setup for about 10,000 miles except for the PDX tune.
Old 05-22-2007, 01:37 PM   #18
kn0bby8
Member#: 97644
2006 WRX
Shoot me a PM if you ever make it back to the track. I am dying to go back but am in fear that I will toast the clutch. The symptoms you are having are exactly the same as mine. If you track the car again and it is fine I am definatly heading back!
Just got back from the track -04 STi Stage2 or So!! Benchmark Tuning Proven Power Bragging 50 10-10-2008 05:15 PM
just got back from the track royalking87 Newbies & FAQs 6 08-20-2006 12:05 AM
just got back from the track... LatentWagen Tri-State Area Forum 12 05-30-2004 09:07 PM
Just got back from the track... sdogg3kgt Off-Topic 3 05-15-2004 10:45 PM
Just got back from the track Big Turkey Texas Impreza Club Forum -- TXIC 5 09-19-2003 03:29 PM
