Old 05-20-2007, 02:49 PM   #1
Redscoob
Member#: 96662
2002 hybrid wrx
sedona red
Default 2.5 sb with 2.0 heads
i have finally finished getting all the parts for my swap. now i need to put everything back in the car.
STI short block with wrx heads
i have a couple of queston's before i install the heads
-where does the crank have to be set?
-what do i do about the breather on the top of the block?
-whats the best way to make sure all the cams are in time with each other?
Redscoob is offline   Reply With Quote
Old 05-20-2007, 09:25 PM   #2
bobjr94
Member#: 6176
15 WRX, 04 wrb STi
85 wrb BRAT
What swap are you doing? Are you swaping a 2.5 engine into a wrx?
If you are swaping the 2.5 engine into a wrx your compression will be way to high to run a turbo unless you got a new set of pistions for a 2.5 turbo.
You just need to look up a timing belt diagram(its been posted before). The timing marks will be the same with the 2.5 as they were with the 2.0. Make sure the cam gear with the timing sensor lines on the back goes on the top of the passenger side head for the cam sensor to work.
bobjr94 is offline   Reply With Quote
Old 05-20-2007, 11:52 PM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
um .. he means a 255/257 block i assume
2.5 block with 02 wrx heads slprwgn Engine/Power/Exhaust 3 01-16-2008 08:22 PM
Anyone see a 2.5 shortblock with 2.0 heads and TD04 or similar? AcquaCow Built Motor Discussion 27 02-08-2007 01:42 PM
ver 5 sb with usdm wrx heads?? gc835 Built Motor Discussion 6 07-30-2006 07:59 PM
2.5 Litre With Stock 02 Heads MIDNIGHTROCKET Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 04-21-2006 02:36 PM
