Old 05-20-2007, 11:56 PM   #1
Robstunner
Member#: 134222
2015 WRX Limited
ISM
Default 02 Fuel leak. i dont think its the common leak!
ok, so i got the leak fixed at a shop (the normal TSB leak). today was about 50-60 degrees out and i smelled gas. so i just assumed the hoses were loose or something(from the TSB fix). drove back home, stuck my head on the engine bay and smelled gas. kinda the same spot but kinda not..... its like its coming from behind the alternator almost like its under the intake manifold. its smell-able from the fuel regulator area, but ALOT stronger around that alternator.
any help? ill pull off the intercooler tomorrow to see if i can get behind it and see whats back there.
thanks
rob
Robstunner is offline   Reply With Quote
Old 05-21-2007, 12:00 AM   #2
redrex2002
Member#: 118915
2002 wrx
srp
i had a really nasty fuel leak one mourning on the way to work so bad i droped half a tank of gas on the highway on a 18 mile drive and the fuel was comming out from where the rubber fuel lines enter the metal fuel railes i guess the rubber shrank and one side was shooting foreward and one backward i would check there it was just a simple fix of tightening up the clamps
redrex2002 is offline   Reply With Quote
Old 05-21-2007, 12:23 AM   #3
Robstunner
Member#: 134222
2015 WRX Limited
ISM
wheres that at? under the middle of the mani or were?
Help!! i dont think its sparkplugs! MabeWrx Newbies & FAQs 10 05-19-2010 04:59 PM
Dont think its detonation. Dan17z Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 05-21-2007 12:40 PM
02 WRX, What do you think its worth? jason t Vancouver Impreza Club Forum -- VIC 17 02-17-2007 12:38 PM
Weird Knock noise, dont think its engine knock mlotek Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-14-2006 09:12 PM
Bush>a Monkey??? (I dont THINK its wtlw) Davenow Off-Topic 9 04-22-2004 09:20 AM
