Old 05-21-2007, 03:10 AM   #1
Mobutusan
Member#: 118017
2004 WRX Waggin'
Default MOD: DIY Hood Scoop Splitter Deflector
So, I decided to modify my hood scoop splitter and add a deflector to direct more air to the front of the intercooler. I was inspired by a similar mod on scoobymods.com, which I thought could use some tweaking.
*These instructions are based on a stock hood scoop from a 2004 WRX. I don't know about fitment on other years, but I know our stock, baby intercoolers can use all the extra cooling we can get. FYI, when installed, even unpainted, this mod is almost invisible to the untrained eye.
Step #1: Remove hood scoop splitter. Get some thin aluminum or sheet metal, ideally something thin enough to cut with tin snips. (I used the same 0.6mm aluminum sheet that I used for the front license plate delete mod.)
Step #2: Trace out measurements as shown in template, or modify dimensions to fit your particular hood scoop.
Step #3: Using tin snips or similar tool, carefully cut along solid lines only. Do not cut dashed lines; bends will be made there. (See Template)
Step #4: Using a vice or other securing method to make bends to the deflector, make two, lengthwise, 45 degree bends along the horizontal dashed lines. Then, bend all four tabs on the sides, the opposite direction as the first bends, to 90 degrees. These will be the mounting tabs.
Step #5: Test fit into hood scoop splitter and align with the center of the inlet and outlet sides of the splitter as shown. Then drill 2 holes through sides of splitter and deflector or just use self tapping metal screws as it will help keep pieces in place as the other mounting holes are made. (Screws can be replaced later with smaller, better looking nuts and bolts.)
Step #6: Reinstall splitter and be even cooler than before!
PICTURES:
Template:
Deflector:
Fitted and drilled:
Installed:
*Note full extension of deflector to meet top of intercooler for maximum cooling:
Finished product. (Unsightly metal screws can be replaced with smaller nuts/bolts):
[/img]
Mobutusan is offline   Reply With Quote
Old 05-21-2007, 04:56 AM   #2
drain bramage
Member#: 88189
02 the 4door model
shouldbegreenwiththe$pent
i didnt read anything, but i dont like the shiny things. i say paint it black
drain bramage is offline   Reply With Quote
Old 05-21-2007, 07:59 AM   #3
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Nice work, thats my project for next weekend, although I cant extend mine to the IC face due to my IC sprayer nozzles.
STiShawn is offline   Reply With Quote
Old 02-26-2009, 04:55 PM   #4
Team Scream
Member#: 121532
2006 FXT/STi 6MT
01 Aerosim GC8 Coupe
Also you may be able to get a pop-rivet tool in there and avoid the screws altogether.
That and anodize the thing black and you are good to go!
Team Scream is offline   Reply With Quote
Old 02-26-2009, 09:57 PM   #5
MZS14
Member#: 182236
05 WRX Wagon
05 CGM Wgn
Well done, thanks for posting the template
MZS14 is offline   Reply With Quote
Old 02-27-2009, 01:34 AM   #6
trueno16v
Member#: 175170
2005 WRX Wagon
owl + bungee cord= my a$$
On the template, how wide should the bottom flap be? 15 13/16" x what?
trueno16v is offline   Reply With Quote
Old 02-27-2009, 04:40 AM   #7
Mobutusan
Member#: 118017
2004 WRX Waggin'
15 13/16" x 1.5"
I can't believe this got bumped from the dead! Glad you all like it.
SELLING 04/05 STI* hood scoop splitters and AW WRX* hood scoop cheap awhitewrx Engine/Power/Exhaust 8 10-11-2009 09:34 PM
V7 STI hood scoop splitter, WRX hood scoop & splitter, fog lamps and more gling Exterior/Styling 14 06-29-2008 12:34 PM
04-05 wrx Hood scoop splitter and STI SCOOP f1uxx Exterior/Styling 5 10-17-2007 03:47 AM
Hood scoop and hood scoop splitter on 02. kilowhisky Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 04-29-2007 07:07 PM
stock scoop, QR hood scoop splitter, NIB GTech, and SWRT/Prodrive jacket reaubideux Private 'For Sale' Classifieds 7 03-10-2004 08:50 PM
