Old 09-09-2008, 08:57 PM   #51
yohy
Member#: 184195
Here we go again. I posted a couple weeks ago with regards to my '97 Legacy experiencing the "new rotor grinding against the backing plate" issue. Well the car that just replaced the '97 is a '03 Impreza RS with 50K on it. I did a complete brake job, pads/rotors/hardware on the '03, the fronts went fine, no problems at all. On to the rears, no problems with the removal or install. Take it out for a test drive and on the first left hand turn I get the dreaded grinding noise, right hand turn, no problem...just the left. Back into the garage, up on jack stands, pull the right side apart and bingo, the shiny spot on the bottom of the backing plate. At least now I know what to do..grab the Rotozip with a grinding wheel on it, a few passes around the "wear" spot. Re-assemble that side, back out on the road...and silence.
So thanks to all that have posted on this thread. The first time I experienced it I freaked out wondering what the heck I did wrong. This time I was prepared and it took about a minute to correct the issue.
yohy is offline   Reply With Quote
Old 09-10-2008, 08:30 PM   #52
ScoobySnacker
Member#: 105303
2003 WRX
Well i finally got around to tearing it apart and it seems like this will be my problem. Now on to the pictures:
Backing Plate:
Rotor (notice the glossy ring):
After cutting a little:
I havn't been out to see if this fixed the problem but i bet it will. I will post back once i take it for a drive...
ScoobySnacker is offline   Reply With Quote
Old 09-17-2008, 08:41 AM   #53
sunfps
Member#: 37076
2002 Impreza WRX
Well this sounds like the same issue I'm having. Thursday will be nice here and I think I'll be doing some investigating.
sunfps is offline   Reply With Quote
Old 09-23-2008, 02:36 PM   #54
fatgroundhog
Member#: 44942
Great thread. Replaced the rotors Sunday, problem showed up today. Just glad it ain't the bearings.
fatgroundhog is offline   Reply With Quote
Old 11-06-2008, 07:57 PM   #55
atenzany62
Member#: 163172
bump for this thread and post #36!! been having this problem with stock wheels, stock worn rotors.. got 17" wheels and just installed new powerslot rotors... still hear the grinding sound. hopefully my friend can have the time to check on the rear brakes tomorrow
atenzany62 is offline   Reply With Quote
Old 11-13-2008, 10:10 PM   #56
atenzany62
Member#: 163172
grinded out both sides on the backing plate. polished all the rust off too. NO MORE GRINDING when i turn WOOOT!!!
Old 02-19-2009, 06:51 PM   #57
mzdrati
Member#: 51993
I'm glad I could help with my write up. God knows I owe this community something of value, after all of the great tips and advice I've gotten from this site over the years. Subaru should issue a recall on this issue, but since it takes a few years to show up, I'm guessing the cars that are affected are mostly out of warranty, so the owners have to foot the bill for the (simple) repair.
mzdrati is offline   Reply With Quote
Old 02-23-2009, 09:21 PM   #58
CTman
Member#: 203632
2002 Impreza 2.5RS
Really bad repaint Black
Thumbs up
1st post and total sub noob
After test driving my 2002 rs before the purchase and noticing horrible rear brakes I had the garage replace them before the sale. A few days later after picking up the car(tonight actually) I'm driving home with the wife following just in case and I hear this exact grinding sound. Sounded just like bare rotors on spent pads but ony while turning hard and slow. I was pissed but finished the trip home. Thank you hardily for easing my mind. The dremmel will be whipped out in the near future.
CTman is offline   Reply With Quote
Old 02-24-2009, 05:15 PM   #59
wrxracer519
Member#: 149890
09 Forester
Green
I had this happen recently also. I replaced all four knuckle and hub assemblies with new bearings and seal. I got it all back together and on the first right turn, the driver rear wheel made the scraping noise.
I took the wheel off and couldn't see any major markings. I asked a friend who is a mechanic about it and he said to check the backing plate. Sure enough i saw the clean scrape mark.
I took a large flat tipped punch and tapped around the area. Made sure i didn't warp any other parts of the plate and reinstalled everything. No more sound. I wish i saw this thread first cause i would have fixed it the night it happened, not the next weekend.
wrxracer519 is offline   Reply With Quote
Old 03-01-2009, 09:43 PM   #60
Addict
Member#: 88434
2006 Maxima 3.5SE
Super Silver Color
Great thread. Time to break out the die grinder.
Stock rotors didn't make the sound, but the replacement one does (passenger rear). Annoying. I hate brake work as it is.
Addict is offline   Reply With Quote
Old 03-02-2009, 03:10 PM   #61
REX8
Member#: 24038
Originally Posted by ciper View Post
Did you not read post number 36?
And actually, post 25 was in well before that even...
Old 05-16-2009, 08:15 PM   #62
CEGLEX
Member#: 201976
2003 WRX Sedan PSM
Stage 2
Thanks to everyone who has added tips to this thread through the months. I bought an 03 WRX four months ago, and a persistent rubbing noise had gotten worse and worse on the passenger rear side each time I took a hard left turn.
Today, while doing other maintenance, I decided to take the wheel, caliper, and rotor off to check it out. Sure enough, the inner backing plate had a very clear (silver/metal) worn spot at about the six o'clock position, about an inch long. And the back inner edge of the rotor was worn bright silver as well from the contact. I got out my Dremmel, ground the metal down on the backing plate in the zone where it was making contact, and bingo, the problem is gone. Now I know what expect if it surfaces again on any wheel.
For those who want to take this quick fix on, just be sure you have some sturdy grinding wheels on hand for your rotary tool, as the backing plate metal will work them over. I've read of other "fixes" like hammering or bending the backing plate, but I wanted to "sculpt" it a little more.
Once again, thanks NASIOC and Scoobymods!!!!! I've been able to do so much on my own with this car. I haven't had a dealership or repair shop do anything other than mount new tires and do an alignment.
CEGLEX is offline   Reply With Quote
Old 05-16-2009, 08:51 PM   #63
ranger5oh
Member#: 77752
5Sti 2005 Sti
I think this is the problem I am having! Halleluleah! I replaced my rotors today, and blammo.... grinding noise from left rear when I make right turns, and no noise any other time.
Thanks to everyone who has posted on this thread... I think this just saved me a trip to the stealership. Im gonna check it out tomorrow evening.
ranger5oh is offline   Reply With Quote
Old 05-16-2009, 09:28 PM   #64
Sonnyblk
Member#: 164505
06 WRX TR
CGM
Just replace my pads and rotors today and I have a grinding noise when I turn left but on seems to be at a low speed when i dont press on the break. At a higher speed I dont hear it. If I brake then turn right i dont hear it either. I installed Stop Tech rotors and Endless Vita pads.
Sonnyblk is offline   Reply With Quote
Old 05-16-2009, 09:32 PM   #65
CEGLEX
Member#: 201976
2003 WRX Sedan PSM
Stage 2
Yep - take the rotor off and look closely at the backing plate. If that is the problem, the freshly rubbed metal will be obvious - bright silver. On your new rotors it might be harder to see. The rubbing I had was also at slower to moderate speeds, and when I was NOT braking. Simply a pronounced turn caused the noise. Check it out - I hope this is what you are experiencing because it is a pretty easy fix.
Old 05-16-2009, 09:37 PM   #66
Sonnyblk
Member#: 164505
06 WRX TR
CGM
^^^ Thanks will do tommaro how much should it be bent back i have dremmel tool but if the chisel and hammer is better i will use that.
Old 05-16-2009, 09:50 PM   #67
CEGLEX
Member#: 201976
2003 WRX Sedan PSM
Stage 2
I didn't bend mine; I just used a few different Dremmel grinding heads to get the job done. I took my time and made everything nice and smooth. Don't rush it if you are grinding or you will destroy the Dremmel. Let us know what you find when you pull the rotor and whether or not this is the fix for you. Good luck!
Old 05-17-2009, 10:13 AM   #68
sunfps
Member#: 37076
2002 Impreza WRX
I replaced the rotor and pads about 3 weeks ago. I also grinded down the backing plate. The noise is back though, not as persistent as before, but still apparent.
I'm not sure what else to do. Take everything off again and grind more?
Old 05-17-2009, 10:54 AM   #69
BIGSKYWRX
Member#: 7958
09 GH B+
see if there is still evidence of rubbing (likely) and if so remove more
Old 05-17-2009, 03:28 PM   #70
viper74656
Member#: 84758
'04 WRB WRX
I've ground mine down a couple times now since I swapped rotors and the noise has decreased quite a bit. Just a bit more to go I suppose...
viper74656 is offline   Reply With Quote
Old 05-18-2009, 12:43 PM   #71
discounteggroll
Member#: 57295
anyone in the CT/NY area want to assist me with this? I put new rotors in yesterday and get a grinding noise at low-speed right hand turns.
brake work gives me the chills and if someone who can provide a hand and their knowledge would be great.
discounteggroll is offline   Reply With Quote
Old 05-18-2009, 12:55 PM   #72
yohy
Member#: 184195
discounteggroll, if you just did rotors, you can fix this problem. Read through the posts and you will find many ways to attack the problem, most just grind the spot where the "rubbing" occurs. If it happens on a slow right hand turn, I would start with the left side (that side will load up on a right turn). Pull the rotor and I'll bet you will see a shiny rub spot on the backing plate at the 6 o'clock position. File, grind, sand that spot, reassemble and the noise will be gone.
You can do it, really. I had the problem first on my '97, thought somehow I had screwed up a wheel bearing. After pulling the rotors off TWICE, I finally saw the spot that was rubbing. It was only after that I found this thread and realized just how common an issue it was. So when it happened on my '03, I knew exactly what it was and how to fix it.
Old 05-28-2009, 10:30 AM   #73
SleepyWeasel
Member#: 192060
2004 WRX
Default i hope this is it!
Wow this looks like this could be the problem I'm having!
Thank you to rexfan and viper74656 for pointing me here.
Gonna check it out right now and see if there is contact/rubbing.
Will update afterward!
SleepyWeasel is offline   Reply With Quote
Old 05-28-2009, 01:41 PM   #74
ULL_WRX
Member#: 201252
I had the same problem occur after an Autox even this weekend. I have been looking for every possible thing that it could be besides the wheel bearing and sure enough when I pulled the rotor off I had the same wear issue, time to get the cut off wheels.
ULL_WRX is offline   Reply With Quote
Old 05-28-2009, 11:41 PM   #75
Badmunky
Member#: 143391
2007 WRX TR
R.I.P Paul! :(
I'll be pulling mine apart to check them tomarrow as I think I am having this problem. I have been trying to find a growling sound coming from the rear brakes for 2 months.
15K on the car and 2 winters so far.
Ill post back with what I find.
Badmunky is offline   Reply With Quote
Help me find an alternative to this watch redapex Off-Topic 38 12-17-2008 09:19 PM
Moderators, I want an answer to this. Davenow Off-Topic 90 03-10-2006 06:17 PM
I did search, but i couldn't find an answer. Black-X Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 02-27-2004 11:02 PM
Cannot find the answer to this simple question Stilletto Interior & Exterior Modification 2 07-30-2002 09:59 PM
I need an answer to this question.... WRX_02_227 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-28-2001 04:24 AM
