Old 05-21-2007, 11:36 PM   #1
jlam86
Member#: 86822
2004 WRX
Default tire rubbing under hard cornering (left turn only)
Hello everyone,
A little while back, I posted odd noises under hard cornering. I thought they were my new perrin endlinks (rear)...Well, turns out that was PART of the reason. The endlink sat really close to the sway bar and nicked it under hard cornering. Now, I realize the majority of the noise is coming from my passenger rear tire rubbing. HOw do i get rid of this? I have 18 x 7.5 buddyclubs on and although I haven't had this issue previously, I am starting to now. Are my springs starting to crap out on me? and I only experience this when cornering hard lefts. thanx
Justin
jlam86 is offline   Reply With Quote
Old 05-22-2007, 09:30 AM   #2
wrxwhite
Member#: 28632
2011 Legacy 3.6R
Dark grey metallic
rubbing on what? what's the offset on the wheels? What tire size are you running?
wrxwhite is offline   Reply With Quote
Old 05-22-2007, 09:40 AM   #3
jlam86
Member#: 86822
2004 WRX
it's rubbing that black plastic piece that lines the fenders.
225/40/18
offset is +44 i think. i'l double check later today
Old 05-22-2007, 10:14 AM   #4
MasterKwan
Member#: 98961
2003 WRX
What kind of suspension are you running, stock?
Old 05-22-2007, 10:48 AM   #5
Mitsu
Member#: 93557
2002 STid wagon-SOLD
roll the fenders, thats about it, or get a 215 size tire....are you on stock struts, they may have blown
Mitsu is offline   Reply With Quote
Old 05-22-2007, 06:39 PM   #6
jlam86
Member#: 86822
2004 WRX
yes i'm on stock struts and espelir springs.
blown shock? just waht i need hahah
Old 05-22-2007, 08:45 PM   #7
jlam86
Member#: 86822
2004 WRX
i never had this issue before and the driving style hasn't changed so I think i'll just order a new set of struts lol. thanx
Old 05-22-2007, 09:02 PM   #8
Blue5spdWRXWgn
Member#: 93606
2002 WRX Wagon - WRB
2005 9-2X - SGM
Springs don't affect tire clearance.
Blue5spdWRXWgn is offline   Reply With Quote
Old 05-22-2007, 09:08 PM   #9
waktasz
Member#: 86356
2015 s1000r
wheelie monster
LOL.
Tell that to my 275s.
waktasz is offline   Reply With Quote
Old 05-22-2007, 09:19 PM   #10
MasterKwan
Member#: 98961
2003 WRX
How much rear camber do you have? Often bumping up the camber will tuck the wheel and stop rubbing. I'm pretty sure I'm going to have to crank my camber for my 235's.
I hate rolling fenders. One thing I did on my Civic, when I had to roll, is fill in the creased metal under the bent lip with RTV so, it didn't collect dirt and start the fender rusting. Basically the whole bent over lip is one smooth fillet of RTV. Dirt and water just rolls over it.
Old 05-22-2007, 09:51 PM   #11
Blue5spdWRXWgn
Member#: 93606
2005 9-2X - SGM
Originally Posted by waktasz View Post
LOL.
275s, whether or not you rub has nothing to do with the height or rate of the springs.
Old 05-23-2007, 02:56 AM   #12
jlam86
Member#: 86822
2004 WRX
i never had this rub issue until just recently. I'm pretty sure my shock is blown so it's only operating on the spring. Is there a way to check to see if it's blown? or is it all by feel?
'00 2.5RS stutters under hard cornering StiPete Normally Aspirated Powertrain 4 09-19-2009 07:32 PM
Strange noise under hard cornering PitwrkzZ1 Service & Maintenance 0 05-07-2008 09:35 PM
Grinding/Rattling Under hard cornering vikingRS Service & Maintenance 6 04-22-2007 12:17 PM
Why does my steering lock up under hard left to right turning? imprezkid Brakes, Steering & Suspension 5 10-24-2006 04:01 PM
Aftermarket spring, front tire rubbing under load Need Speed Brakes, Steering & Suspension 1 09-14-2004 12:09 AM
