North West Impreza Club
Go Back   NASIOC > NASIOC Chapters > North West Impreza Club Forum -- NWIC
Old 12-19-2001, 09:25 PM   #1
knight
Member#: 11093
2002 WRX Sedan
Platinum Silver
Default DMS on the way - but need help with install
Hello all -
I've been wondering if anyone can recommend a good shop that takes care of our aftermarket Subaru installs. I've got a couple mods coming up, namely the DMS golds and I'm not confident nor do I have the tools to install them.
Or if anyone does work themselves - I'd love to hear about it.
Thanks.
Knight
knight is offline   Reply With Quote
Old 12-19-2001, 10:03 PM   #2
david2z4
Member#: 1838
2000 Impreza RS BRP
Vishnu Turbo/Tec3
I've installed 5 sets now maybe I can help.
give me a pm.
david2z4 is offline   Reply With Quote
Old 12-19-2001, 11:46 PM   #3
cfwdfw
Member#: 5046
'97 Legacy gt 5 spd
Deep Saphire Blue Sedan
Hi Knight,
If you ordered them through Dave Clark ... his shop is just south of SouthCenter ... I would suggest you consider working with him on the install ... course ... it might take a while to catch him depending upon his schedule ... ... but he knows what he's doing !!!!
I'm sure you would learn a lot from working with him on the install ... and be prepared for the test drive afterwards ... ... depending of course upon time of day and his schedule ...
I certianly learned a few things when we did my legacy ... and suffice it to say ... I'm very pleased with my DMS golds ... and STi top mounts ...
course if David is willing ... that would work too ...
Charlie
cfwdfw is offline   Reply With Quote
Old 12-20-2001, 12:06 AM   #4
Austin
Member#: 7089
2016 STi
Hey Dave, being that you're such a pro...
I installed my DMS Golds with cusco camber plates front and rear. I know camber plates are supposed to make some noise, but my rear passenger coilover makes a *monster* clank... not just the click click of pillow ball mounts, but a big clank, and it's only the rear passenger side. The other three corners make noise, but it's more the metal on metal sound of pillow ball mounts, and not very loud... I've not contacted Dave about this yet... This sound normal to you?
Austin is offline   Reply With Quote
Old 12-20-2001, 12:20 AM   #5
david2z4
Member#: 1838
2000 Impreza RS BRP
Vishnu Turbo/Tec3
Austin, Could be all the parts were not seated and after a drive they are now loose.
Also the one side could be at a different angle and the top perch is hitting the top mount. Don't know how much clearance there is with the cusco mounts.
I PM'ed you.
Old 12-20-2001, 01:09 AM   #6
knight
Member#: 11093
2002 WRX Sedan
Platinum Silver
Dave - I pm'd you.
Charlie - Thanks for the info....
Old 12-20-2001, 12:44 PM   #7
Austin
Member#: 7089
2016 STi
There *should* be ample clearance... I'll take the back seat out and retorque everything again once I get back to Washington. I need to get it done before the 27th, I've got an appt at Fordahl for four wheel alignment/weight balancing.
Old 12-20-2001, 01:32 PM   #8
david2z4
Member#: 1838
2000 Impreza RS BRP
Vishnu Turbo/Tec3
Austin, also make shure the spacer washer that goes between the pearch and top mount is the correct size and that there is no movement in the top mount center hole. Mine was sent with the wrong ones. At the DMS factory there are two "spacer" bins side by side and they just grabbed into the wrong bin when they packed my kit. The two almost look identical, one just has a different diameter.
who knows there may be 10 bins with different sizes. Also maybe the WRX setup doesn't use the same spacer due to the different top mount configuration.
need help with install on 09 wrx last lemming alive AccessPort 3 01-04-2010 08:55 PM
Planning on running 300+ WHP, but need help with supporting mods! DJS_02_WRX Newbies & FAQs 77 10-18-2009 12:39 PM
Need help with installing replacement OEM rear springs on '99 OBS Ski4Ever Impreza Forum 0 06-26-2009 04:36 PM
Need help with installing gauges on A-pillar maxpower_454 Interior & Exterior Modification 1 07-06-2005 01:08 AM
Need help with install on used aps tmic hybrid gti 2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-14-2005 09:36 PM
