Old 05-22-2007, 12:31 PM   #1
Saucy
Member#: 104507
Haw deeeewdddddd
Default DC-to-AC Power Inverter
So I have one of these:
and my question is..
Instead of using the cig lighter, would I be able to cut off that adapter and just use the power and ground directly somewhere? I'm trying to put that adapter somewhere clean and flush and I want to hide those wires.
I searched around and seen a couple people do it, but I wasn't sure if it was safe/possible.
Any input appreciated.
Thanks,
Getti
Saucy is offline   Reply With Quote
Old 05-22-2007, 12:37 PM   #2
LastResort
Member#: 99289
Yes, just use a good attachment method, and properly insulate. You could probably just tap the cigarette lighter wires for convenience.
LastResort is offline   Reply With Quote
Old 05-22-2007, 12:37 PM   #3
Ironmansixx
Member#: 117003
02 Bugeye
Yes you can with no problems. Make sure you find the right wires for positive and negative. And then properly crimp and heatshrink your connections and you'll be good to go!
Ironmansixx is offline   Reply With Quote
Old 05-22-2007, 12:41 PM   #4
Saucy
Member#: 104507
Haw deeeewdddddd
Awesome, just wanted to double check! Thanks for the quick responses guys!
Old 05-22-2007, 12:42 PM   #5
ekw
OC D
Member#: 92141
2004 STi-WRB on gold
Street prepped by TiC !
I'd think you'd want to tap ACC power.
so make sure that you are in a 12v ACC line,
and check the fuse rating of the line you go in on.
ekw is offline   Reply With Quote
Old 05-22-2007, 12:49 PM   #6
Saucy
Member#: 104507
Haw deeeewdddddd
^^-- will do.
other than the cig lighter.. anyone know, for sure that is, a wire to tap into?
Old 05-22-2007, 12:56 PM   #7
Pohenegamook
Member#: 134262
9 조 ☼
Bobscratch Goldfarb
Pohenegamook is offline   Reply With Quote
Old 05-22-2007, 01:10 PM   #8
Saucy
Member#: 104507
Haw deeeewdddddd
Thanks floyd! I'll send you some bomb from socal.
Old 05-22-2007, 01:27 PM   #9
Saucy
Member#: 104507
Haw deeeewdddddd
found the positive and neg near the fuses, again, thanks guy.
Old 05-22-2007, 03:19 PM   #10
Micker72
Member#: 132820
2005 Impreza RS
I just did this....i took out the outlet and switch, extended the wires, mounted it into the dash and spliced the power into the cigarette lighter
and it came out very clean
Micker72 is offline   Reply With Quote
Old 05-22-2007, 03:23 PM   #11
Letx
Member#: 100655
2003 Wrx
Sonic Yellow
^Nice install
Letx is offline   Reply With Quote
Old 05-22-2007, 03:38 PM   #12
LastResort
Member#: 99289
Just watch the heat in an install like that, without air circulation, you could trip the unit. Looks very nice though.
Old 05-22-2007, 04:14 PM   #13
Saucy
Member#: 104507
Haw deeeewdddddd
thats exactly where im putting it!
BUT
im doing it the other way around (outlet pointing backward, anda i have 2 outlets)
and then im cutting air vents on the sides of the armrest (the sides that are next to the seats) so you wont notice the slits, but it will be able to breathe!
@micker - very very clean job man!
Old 05-22-2007, 04:58 PM   #14
dougkmcse
Member#: 85938
2004 WRX
When tapping wires. I would run straight from the battery. I installed one in my car. I tried just using the cig adapter and my ps2 would not start. It had enough power for the lights but the game disc would not spin. I hard wired to a splitter that has 2 gauge running to. After that the ps 2 works great. This is with the car not running. Micker72 That is an awsome looking install. You have given me some ideas.
dougkmcse is offline   Reply With Quote
Power inverter connected to battery, battery charger plugged into inverter... El Camino Off-Topic 27 08-16-2010 01:48 AM
FS in VA: 2004 STi UTEC, 300W DC to AC power inverter WRXtranceformed Engine/Power/Exhaust 8 09-06-2006 08:33 PM
aftermarket gauges w/ power inverter, what voltage/wires to hook up to? jt1583 General Community 0 07-09-2005 10:10 PM
how many watt power inverter needed to charge a laptop computer? Poe Car Audio, Video & Security 7 04-23-2003 05:01 AM
DC->AC power inverter chkltcow Car Audio, Video & Security 4 11-06-2001 05:03 PM
