Welcome to the North American Subaru Impreza Owners Club Tuesday September 1, 2015
Old 05-22-2007, 07:16 PM   #1
Jasper
Member#: 80136
2006 Ford F-150
Default sources of high-pressure oil lines/possible leaks on the pass side of the engine bay
CN: huge plume of gray smoke. oil spattered all over the bottom of the car, concentrated on the passenger side of the car (cradle is coated, as well as the pass side of the oil pan, RF wheel well, wheel, strut, brakes, LCA,).
oil feed line for the turbo appears to be intact (as well as not being coated in oil). the oil drain line on the bottom of the turbo also appears to be intact.
half moon gaskets are also intact.
nothing above the turbo itself has any oil on it.
lost a LOT of oil in ~ 1mile of desperately trying to get to my exit (and off the highway), watching my oil pressure drop from ~80psi down to ~ 23-24psi before i shut the motor off and coasted, fearing spinning a rod bearing
i KNOW something let go, but its not internal. theres no oil crud anywhere inside the exhaust tip, so it wasnt burning it.
it has to be something under a decent amount of pressure to lose that much oil that fast. and unfortunately, refilling the oil and starting the motor to try to find the leak is out of the question. i live in a townhouse, and though we own it, as well as our garage and driveway, my neighbors would have a field day with me if i let oil pour down the street. that, and i really dont wanna crawl under the car if its gonna be spraying everywhere.
any ideas?
UPDATE!!! FOUND THE LEAK
ProSport oil temp sender disintegrated.
Jasper is offline   Reply With Quote
Old 05-23-2007, 01:21 AM   #2
remowgn
Member#: 41149
04 09 FXT
SSM
you have any gauges or other mods to the oil system? Any oil on the top of the block?
remowgn is offline   Reply With Quote
Old 05-23-2007, 08:49 AM   #3
MasterKwan
Member#: 98961
2003 WRX
Fill it, Lay down a tarp or newspapers, have someone crank it while you're underneath, make them turn it off when you notice where the leak is.
First thing I'd suspect is the oil filter/oil cooler.
Old 05-23-2007, 08:57 AM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...how about the banjo where it feeds from the head???
Uncle Scotty is online now   Reply With Quote
Old 05-23-2007, 09:12 AM   #5
jupiterrex
Member#: 119970
2006 WRX Wagon
Grocery Getter!
if you have a oil pressure gauge, check the spot that is taps into the block. I had two pressure senders fail on me and it did the same thing, but not as bad. check it, that may be your problem.
jupiterrex is offline   Reply With Quote
Old 05-23-2007, 09:18 AM   #6
Gfunk720
Member#: 42549
E92 M3 M\\\
VW Sportvagon Oilburner
Jasper, not sure where to get them but my GF's father has these mats that are made for soaking up oil which would work well in your situation. They are actually made of chicken feathers, which after Exxon Valdez, we know suck up oil...
I am having a similar problem, however with much less oil loss. I would check the oil pan/drain plug area, as my symptoms are similar and my leak is coming from my oil temp. sandwich adapter. It literaly has coated everything 2ft. back from the oil filter with oil(mostly on the passanger side), which I can smell burn when I stop. It only happens when the car is warm though and the oil pressure is high...
Gfunk720 is online now   Reply With Quote
Old 05-23-2007, 03:46 PM   #7
Jasper
Member#: 80136
2006 Ford F-150
there's residual oil from a previous leak i had (i attempted to recirculate the breather in the center of the block on the 207. ALWAYS leaked. Ron @ Axis said it'd be fine to just plug it, so thats what i did, and low and behold, no more oil leak (at least for the last ~ 2 days. seems as soon as i fixed one leak, i gained another)
i'll check it, but the area around the filter is, surprisingly enough, dry.
that was my first guess. i figured the stock hardline to the turbo failed (it's been reused at least half a dozen times, probably more, and has been tweaked at least a dozen times, but, once again, oddly enough, the banjo on the head was almost totally bone dry, and theres no cracks in the hardline that ive been able to feel thus far.
already checked it. i have a brass t-fitting on the rear galley, and the oil pressure sender is remotely located via stainless line and -AN fittings. and, once again, bone dry.
this happened on the highway. 1/2mile cloud of gray smoke behind me, so the engine was already up to temperature, and the oil (10w40 dino) was up to temp. (oil temp @ the time of failure was approaching 220*F)
Old 05-23-2007, 07:51 PM   #8
Jasper
Member#: 80136
2006 Ford F-150
update: yea this leak is freakin massive
took 4.5qt's to top it off
oil POURS right off the center of the cradle, so i was thinking, rear main seal went? but the teeth on the flywheel (looking @ it from under the car) appear dry.
what the hell can dump a 1/2qt of oil onto the ground in ~ 8-10seconds of idling.
Old 05-24-2007, 08:54 AM   #9
CTKAG
Member#: 15001
STi V8 Spec C Power
NESIC TrackH0z # 10
You didn't blow one or both(if you have the AVCS heads) of the breather hoses off of the passenger head, did you? With the center breather tube plugged, you're going to have a lot more crankacse pressure trying to get out. You already know how much oil the center breather pumps out.
Otherwise - check valve covers & AVCS oil line (if present). I've had the oil return hose push off of the return line to the engine as well.
-Keith-
CTKAG is offline   Reply With Quote
Old 05-24-2007, 02:18 PM   #10
SBW
Member#: 38469
07 LGT spec-b
Crystal Grey Metallic
my first guess would have been the banjo feed, or return, but if they're both fine, could something be blocking the return in the drain tube itself and be spraying it?
I've screwed up the banjo bolt myself more than once, but never had oil spray like you describe all over. Just a leak to the oil feed or return would dump out, but not spray.
SBW is offline   Reply With Quote
Old 05-24-2007, 04:52 PM   #11
Jasper
Member#: 80136
2006 Ford F-150
i think the spray was moreso related to the fact that i was going ~ 80mph down the highway when it let go. oil just POURS now. i talked with Ron @ Axis, and he seemed rather sure it was the oil return from the turbo, so i'll be hose-clamping that today, and seeing if that fixes my leak.
Old 05-24-2007, 04:57 PM   #12
SBW
Member#: 38469
07 LGT spec-b
speeding! shame on you! good luck, let us know what you find.
Old 05-28-2007, 02:37 PM   #13
Jasper
Member#: 80136
2006 Ford F-150
hoseclamped both sides of the turbo drain line. didnt replace the hose because i was (hoping) for a quick fix. oil is still pouring off the center of the crossmember.
WHAT THE HELL ELSE IS DOWN THERE!
Old 05-31-2007, 12:09 AM   #14
mywRx04
Member#: 139010
WRX Blue/MY04
cobb tuned / stage3
hi, yesterday i had the same problem (oil leak), i was thinking the oil hardline is broken, because the 2 washers are good,actually i have a vf 22(wrx 04), so if i install a different oil line(adapter and hose), is most better than the stock oil hardline??????????
gracias
mywRx04 is offline   Reply With Quote
Old 05-31-2007, 09:00 AM   #15
SUBYS R US
Member#: 99591
2003 18g w/38EWG
PSM(siver)
Im getting my car towed for the same problrm right now
SUBYS R US is offline   Reply With Quote
Old 05-31-2007, 04:13 PM   #16
Jasper
Member#: 80136
2006 Ford F-150
wont know until you clean it all off, climb under there, and start the car.
i still havent found mine. its somewhere right above the steering rack, making it VERY difficult to see/find.
im *hoping* the dipstick perhaps popped out of the oil pan?
Old 05-31-2007, 07:37 PM   #17
SUBYS R US
Member#: 99591
2003 18g w/38EWG
PSM(siver)
Lokks like my copper washer on the oil feed line off the block was gone and I hope a new one will fix the problem.
Old 05-31-2007, 10:14 PM   #18
Jasper
Member#: 80136
2006 Ford F-150
FOUND THE LEAK
god damned ProSport oil temp sender disintegrated. came out in 2 pieces, and a chunk of the barrel is missing.
pic:
http://i135.photobucket.com/albums/q...emp_sender.jpg
Old 05-31-2007, 11:16 PM   #19
WRXDriftR
Member#: 65065
04 WRX/ STi Hybrid
6MT, VF43
oh damn! hope nothing is damaged. I doubt theyll cover your motor on their warranty
WRXDriftR is offline   Reply With Quote
Old 06-01-2007, 12:14 AM   #20
mywRx04
Member#: 139010
WRX Blue/MY04
cobb tuned / stage3
good luck..., i need replace the oil line because is broken.....
Old 06-01-2007, 07:47 AM   #21
SBW
Member#: 38469
07 LGT spec-b
Originally Posted by Jasper View Post
FOUND THE LEAK
thats great that you found it, probably a huge weight off your shoulders.
Old 06-01-2007, 03:57 PM   #22
Jasper
Member#: 80136
2006 Ford F-150
you aint kiddin!
it looks like once the actual thermocouple broke loose of the metal barrel, the oil pressure alone broke through the barrel part of the sender. yes, a chunk is missing, but its pushed OUTWARDS from the motor. that piece probably got shot onto the top of the block somewhere, or more likely, right out of the engine bay and somewhere on I-95 north.
Old 06-01-2007, 05:02 PM   #23
Cation
Member#: 88779
00 E55 AMG
WOWZA! Glad I have mine in my oil pan drain plug after seeing that!
Cation is offline   Reply With Quote
Old 06-01-2007, 06:27 PM   #24
SBW
Member#: 38469
07 LGT spec-b
you aint kiddin!
thats the only thing I was worried about...a piece of the sender going in, but thats highly doubtful considering the pressure.
I'm glad I am not the only one who'd lose sleep over something that hard to find. I have, myself, a very small leak in that same area, and Im wondering if its my newly installed greddy sender, I RTV'ed it and used teflon tape, and I think there was loc-tite on the threads but I can't imagine where else it would come from.
Of course, I forgot one of the copper washers when I put my braided oil feed line, just like last swap, and spilt oil just like you described, except in a much more demeaning fashion.
need vf39 or tdo4 high pressure oil line. Kamikaze03084 Texas Impreza Club Forum -- TXIC 0 07-10-2009 10:47 PM
smoke coming from engine bay. oil residue in between hot and cold sides of turbo. ted dibiase Built Motor Discussion 4 05-22-2008 10:51 AM
What is the oil-leaking, 2 bolt plate on the rear side of the head? SubarNoober Legacy Forum 3 02-02-2008 09:14 AM
Location of high pressure fuel line ? boost4life Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-22-2006 08:47 AM
Help please...much oil leaking from pipe on pass. side of firewall Danno Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 08-31-2003 05:26 PM
