Welcome to the North American Subaru Impreza Owners Club Tuesday January 27, 2015
Old 05-23-2007, 04:24 PM   #1
Douginss
Member#: 80727
1992 Accord
I miss my Subaru!
Default Clutch not disengaging
Okay so here is the story. 03 WRX with 93k on it. I replaced my stock clutch with an ACT streetlite flywheel and a spec stage II clutch about 15000 miles ago. Everything when fine and I have not had a hint of problems with it. I actually love the lightweight flywheel.
Couple of nights ago fiancť drives the car home, says nothing was wrong. I get in the car to leave the next morning and the clutch will not disengage. It still has pedal pressure, seems like the normal amount. After looking at the fork, it seems to me itís not moving as much. I bleed the clutch and nothing so I swapped a new master and slave cylinder on it. There were no leaks on either but just to be safe. New fluid all the seals are cleaned and nice I bled it correctly and everything else. The clutch pedal seems solid and when itís pumped up the clutch doesnít get harder or anything and the slave doesnít drift back, just stays rock solid.
I adjust the masterís rod to the pedal out as much as possible to try and get more fork movement but it does not help. The pressure plate moves out when the clutch is depress but there is about a 1/4Ē between the TO bearing and the fingers on the plate. I can see the metal piece that holds the snap ring in pulls out with it. I can push the TO bearing back against the pressure plate but it will not lock there and the fork pulls it back out with no problem. So when the pedal is pushed in the TO moves for ~1/4Ē then the pressure plate moves. Is this where my extra slop is that doesnít allow the clutch to release?
So I have a few ideas on what could be wrong:
Extra slop in pressure plate allows TO bearing to slide out ľĒ and not enough travel to make it release.
Master cylinder was bad originally and now put the wrong on it (long shot here, itís got the same bore and looks identical)
Iím not adjusting the clutch properly. I wouldnít think this would be it since it worked fine in the past and just stopped working like it did.
So now Iím stuck. Before I rip the tranny apart to find out itís the pressure plate any ideas?
TIA, Scott
Douginss is online now   Reply With Quote
clutch not disengaging! ride918 Transmission (AT/MT) & Driveline 31 04-09-2013 04:05 PM
clutch not disengaging, normal pedal jeffdg Transmission (AT/MT) & Driveline 3 08-12-2009 02:54 PM
Clutch not disengaging? ezoq Transmission (AT/MT) & Driveline 3 07-02-2006 04:14 AM
Help, clutch will not disengage BADWRX Transmission (AT/MT) & Driveline 4 08-20-2002 03:56 AM
Clutch will not disengage?! dead-eye Transmission (AT/MT) & Driveline 10 09-22-2001 02:27 PM
