Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 12-20-2001, 10:37 AM   #1
Mas
Member#: 8821
2002 WRXagon
WRC Blue
Default OBD-2 Tool trouble shooting
I just received my OBD-2 tool from the group buy and now I have a question. How do you make this thing work?
I'm thinking I must have some kind of hardware (laptop) problem because no one else seems to have a problem with the tool (at least I could not find any posts on this board).
Here's what I've done:
Unzipped software
Entered ID code
Attached ISO cable to the serial port of my 166 Hewlet Packard laptop
Plugged ISO into the OBD-2 port
Turned on Ignition
Launched OBD-2 program
Hit connect on the program
Program comes up with "System Busy"
I've tried launching the program first, connecting, then turning the ignition. Nothing.
(How do any of you start the program and "get connected"?)
I've tried it in my 2000 Celica. Nothing.
I've checked the baud rate of my port to make sure that it matches the baud rate the software is asking for and they are both set at 38.4. Port is set at 1, interface is single, protocol is default SAE ISO.
Any ideas on where I'm going wrong?
Thanks,
Mason
Mas is offline   Reply With Quote
Old 12-20-2001, 12:06 PM   #2
Lo0mis
Member#: 12469
2000 2.5 RS
BRP
Maybe the change the port type (ECP/SPP/EPP) in you laptops BIOS?
Lo0mis is offline   Reply With Quote
Old 12-20-2001, 04:56 PM   #3
Julian
Member#: 1182
MY00 RS
BRP
What happens if you run the program and try to connect without hooking it up to your car?
I assume this unit is supposed to use the parallel port? Most I've seen (and the one I own) use the serial port.
Julian is offline   Reply With Quote
Old 12-20-2001, 05:53 PM   #4
Mas
Member#: 8821
2002 WRXagon
WRC Blue
Sorry you're right it is the serial port (early morning brain fart).
If anyone with the Alex Peper OBD-2 scan tool can post their "normal" connection procedure I'd be interested.
Thanks again,
Mason
Old 12-21-2001, 08:17 AM   #5
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
1. Turn the computer on
2. connect one end to the OBD-II port in the car, and the other to the serial port #1 (used to be known as com1/com3).
3. Open the application
4. Choose "connect"
5. Let it think
6. It connects.
7. Hit data, and click on Send to get all the data from sensors.
Is your serial port disabled? What OS do you have? The application is designed for Win 3.1, 95, 98 and may work on 2000. No NTs.
tmat3 is offline   Reply With Quote
Old 12-21-2001, 10:34 AM   #6
Mas
Member#: 8821
2002 WRXagon
WRC Blue
I'm using a win 95 laptop so the OS should be compatible.
As far as I know the port isn't disabled, although I'm not sure how I could tell. I went into the device manager and there are no conflicts with the port, and the box for "disable device" isn't checked. In the properties for com 1 it lists "Port settings" I set the baud rate for 38.4 (it was defaulted at 9600) but I've left all the other settings at the default, Data Bits = 8, Parity = None, Stop bits = 1, Flow control = None.
At what point in the process do you turn the ignition "on", does it matter when, does the car need to be running?
Old 12-22-2001, 01:15 AM   #7
Mas
Member#: 8821
2002 WRXagon
WRC Blue
I'm now starting to think that maybe he sent me the wrong connector plug. I looked at my OBD II plug in my car and there does not seem to be receptacles in places where the plug has pins.
If you look at the connector it's shaped like a "V" (wide at the top skinny at the bottom" from left to right on the top level I would number them 1-8 and the bottom row would be 9-16.
On my onnector I have pins in 2,4,5 and 9,10
Is this what everyone else received?
Thanks,
Mason
Old 12-24-2001, 06:51 AM   #8
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
You got the right connector.
Is your ignition key at the on position without the engine running? After you connect the wires between the car and the computer, turn the key to the "on" position. Then, click "Connect".
Old 12-24-2001, 11:12 PM   #9
ylexot
Member#: 6878
2002 MBP 2.5RS
1994 GMC Sonoma
How did you enter the ID code before launching the program?
The first time you try to connect, you terminate connection. Then it pops up a save dialog. Cancel that and it should pop up the window for the User ID #. At least that's how I did it.
ylexot is offline   Reply With Quote
Old 12-26-2001, 08:26 AM   #10
KGreb
Member#: 13463
2012 Chevy Volt
Default One more thing to try
Make sure you don't have any software open that's accessing the serial port. I had a palm pilot hotsync program running in the background of my laptop that would conflict with the OBD-2 scanner. Shut down the hotsync program and logging worked with no problem.
Good Luck!
KGreb is offline   Reply With Quote
Old 12-26-2001, 06:33 PM   #11
XazerpmiX
Member#: 8605
2001 2.5 RS Coupe
I can't get mine to work too
What do I enter as my User ID?
Also the Laptop I'm using has Win2000 on it, is anyone else using win2k with their OBD scanner?
Mike
XazerpmiX is offline   Reply With Quote
Old 12-26-2001, 11:28 PM   #12
BigKuma
Member#: 13060
2000 Impreza 2.5 RSt
Arrow Mine works, but ...
The first question I had was "What is my ID? "
Then I found it at the bottom of the e-mail with
subject:
"Notification of Payment Received".
(So you get it when you pay).
Then I had some timeout problems, I got possible solutions from .HLP file and from Alex himself, but I did not try them yet.
I have MY00 2.5RS and Dell Laptop w/ WinXP.
I have a blue router (dual Ford/ISO connector).
BTW: If anyone else is trying to get the software to work with a Mac ( Virtual PC ) let me know. So far I got nothing. Something to do with Pin8 on the DIN8 to DB9 machintosh serial connector adapter I suspect.
BigKuma is offline   Reply With Quote
Old 12-29-2001, 02:20 AM   #13
dwmoss_68
Member#: 6030
04 Gold FXT
07 WRB FXT Sport
Question silly question
ok... where do i find the connection for the cable for a 02 wrx?
pictures or links to pictures?
dwmoss_68 is offline   Reply With Quote
Old 12-29-2001, 08:42 AM   #14
ylexot
Member#: 6878
2002 MBP 2.5RS
1994 GMC Sonoma
It's directly beneath the steering column. Just look around there and you'll find it.
Old 01-13-2002, 02:12 PM   #15
selector37
Member#: 10370
I've actually been trying to build a laptop interface for OBD-II over the last few months, and it has really sucked. I've gotten full communication with my friend's S2000, but my WRX stops talking for no reason, and I've never gotten even the most basic response from any Toyota. My advice would be to try it on a Honda, and if it works there, then you know that your laptop setup is OK.
selector37 is offline   Reply With Quote
Old 01-18-2002, 01:09 AM   #16
QA Guy
Member#: 6739
I got the PWM and ISO combo one from obd-2.com. I haven't tried it on my WRX yet, just on my Mystique. Sometimes it will connect the first time. Other times it takes 5 or 10 tries to detect properly.
You might try getting together with some I-club members from your area to figure it out in person...
QA Guy is offline   Reply With Quote
Old 01-18-2002, 02:11 AM   #17
BigKuma
Member#: 13060
Default PMW and ISO OBDII
When you get that combo, software defaults to
the Ford settings. So I had the same disconnect problems.
This is what Alex recommended for me:
In options gateway protocol increase ISO speed to 125, byte time to 5
and message to 35. Increase timeouts to 2 and check auto-recoonect.
Also, similar thing is sugested in the program help file.
Although, I still get disconnects, it is much less frequent now.
Old 01-18-2002, 03:07 AM   #18
QA Guy
Member#: 6739
Thanks!
I've made the changes and will try it out the next time I have a problem (hopefully not soon) or when I feel like seeing what the car is doing in a bit more detail.
Old 01-20-2002, 01:08 AM   #19
stereo_rs
Member#: 9139
Question where can I order one?
Hello ~ guys
do you know where can I locate a ODB2 scaner ??
thanks!
stereo_rs is offline   Reply With Quote
Old 01-20-2002, 01:27 AM   #20
QA Guy
Member#: 6739
The two that get the most mention are the Harrison and Peper ones.
Search for:
"Harrison" and/or
"Alex Peper" (obd-2.com) and/or
"obd2 and scanner"
You will find lots of info.
I have also seen and used the AutoXray, though not on a Subaru. There are many other ones, too.
I got the one that Alex Peper sells on a group buy. I use it with a laptop. It works pretty well, though there is little to nothing specific to Subaru that I know of in it (all generic obd2 info). You can get them in a group buy of 20 people for $73 and up, depending on options. The software is free to download.
Old 01-24-2002, 07:28 PM   #21
Dave_MacKinnon
Member#: 10823
2007 STi
Dave_MacKinnon is offline   Reply With Quote
Old 01-24-2002, 09:58 PM   #22
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
I have the AutoXray unit and it works very well on the WRX and other OBDII Subarus. Mine was a few years old and the older software did not initially work on my car but I was able to send it back to them for a free upgrade (free except for a nominal shipping fee). A new one purchased now will have the current software and will work fine.
Unlike the PC-interface units the AutoXray is plug-and-play and will read out stored codes with a plain-english description. It will also clear codes and can provide real-time sensor and status readouts.
It's not cheap but definitely worth having if you have any interest in diagnosing your car and avoiding shop visits and an absolute must if you are doing any mods.
Old 01-25-2002, 12:21 AM   #23
BigKuma
Member#: 13060
Arrow Codes
Codes can be viewed on the Codes tab.
Hit "Request" and then "History" button if
you don't see anything. (might need to
do it a couple of times)
I saw two different codes come up so far:
Something about too high Manifold pressure
and something about Catalitic converter
system not working efficiently.
(After market turbo kit).
Old 01-29-2002, 10:56 PM   #24
motorob
Member#: 2878
06 Evo IX MR
What KGreb said, that's often the problem.
motorob is offline   Reply With Quote
Old 01-29-2002, 11:03 PM   #25
BigKuma
Member#: 13060
Default O2 sensor reading
Has anyone got anything usefull from the O2 part of the program ?
All I can get is the Bank1 sensor2 voltage, but that's not very interesting, since that is the sensor after the cat.
I wanted to use the O2 reading to tune the RRFPR.
FS: OBD-2 scan tool AKSubie Alaskan Impreza Club Forum -- AKIC 11 01-24-2004 08:45 PM
Can you use OBD-2 scan tool to tune S-AFC? 2.5GT Normally Aspirated Powertrain 6 04-03-2002 05:07 PM
Lets Talk OBD-2 Scan Tools!! djerickd Service & Maintenance 8 02-11-2002 10:29 PM
obd-2 scan tool will not connect MTREX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-04-2001 12:05 AM
Need help!!! OBD-2 scan tool probs on a 99 [email protected] Technical Forum Archive 3 08-27-2000 03:10 PM
