#1 |
Member#: 128706
E. Canada
Vehicle:2010 WRX Limited Lightning Red |
I recently got into an accident, curbed my car hard (about 45mph) in rain. I killed my front suspension, hub, lca, bearing, etc and my rim and tire and have some slight curb rash on the rear right as well I guess from understeering into the curb. I've learned my lesson to not drive agressively on those lousy RE92s.
Anyway, the car came back from the dealership yesterday, suspension replaced. I didn't want to buy a new rim and tire from the dealer since they are so overpriced. In the mean time, I was lucky enough to get a 16" steelie and an RE92 off my neighbour that used to have a WRX. The tire is the same as my stock ones, 205/55/16 89V, so that's fine, but the tread depth is different, I don't think drastically, but don't know of a methodical way to check. I am wondering, how long can I drive on this setup? I've got a stock rim coming from a salvage yard, so I won't be on the steelie much longer, but I don't know how long I'll be on the different tread depth tire? I am either going to get some aftermarket rims and tires and use my stock wheels for the winter, or I'm just going to get a good set of all seasons, yet to decide. The car feels fine, the only thing is, I think I hear something from the rear diff during decel, almost like the typical clunk (fairly quiet), but I have been running the TiC klunk killer (comfort) for a couple of months and don't recall that being there before, but paranoia could just be setting in for me. Any advice would be much appreciated, thank you!
#2 |
Member#: 124254
NESIC
Vehicle:2006 06 SGM Slowbaru "The Scoobinator" |
Since you (and I) have open differentials at either end, any difference in rotational speed will be absorbed there, since it's only one tire.
#3 |
Member#: 128706
E. Canada
#4 |
Big Ron
Moderator Member#: 18062
You should drive zero feet on it. Open your owner's manual.....read....
1/4" variance in the outside diameter is all you can go. Anything else....go price a new center differential. |
#5 |
Member#: 96299
Vehicle:All Subaru of Santa |
NOW!
is the correct thing to do, Do not drive any longer or the $$$ goes up! |
#6 |
Member#: 96299
NOW!
#7 |
Member#: 128706
E. Canada
I stopped driving it, plan on getting new tires tonight or tomorrow morning, but that means I have to drive it to the shop to get the tires put on. I really think there's a flaw there if you can't drive on even the spare. So it means if you get a flat, you've gotta call a tow truck and then go buy all new tires? Is this only inherent of AWD systems?
#8 |
Member#: 128706
E. Canada
Picked up a tread depth gauge from my local auto shop. I just did a quick check of all 4 tires and I may have gotten really lucky, but all 4 tires were about 7 to 8/32nds of an inch, including the extra tire I picked up from my neighbour. So I guess I'm fine, but I will double check again later tonight or in the morning.
| Thread Tools | |
| Display Modes | |
| Is running two different treads ok? | pwnx0rz | Tire & Wheel | 46 | 04-20-2011 07:30 PM |
| Any disadvantage to running 2 different size tires on WRX wagon? | Opazone | Tire & Wheel | 8 | 09-12-2005 10:50 AM |
| Differential Problems if you run 2 DIFFERENT size tires??? | Hotrodguru | Transmission (AT/MT) & Driveline | 2 | 01-26-2005 04:43 PM |
| Do tires with different tread depth mess up the differential? | NotFast | Tire & Wheel | 1 | 09-03-2003 06:51 PM |
| Anyone run 225/50/16s? Any problems? | GTLee | Brakes, Steering & Suspension | 4 | 10-27-2001 02:08 AM |
