Old 05-23-2007, 07:47 PM   #1
C o l i n
Member#: 101384
2004 TS
Platinum Silver Metallic
Default Advice on problems after an Accident....
Back Story:
Road was closed, police were turning everybody around at an island in the middle of the road (blind hairpin turn). Cops were hurrying us all through, turn around the island and bam, there's a burgundy xA stopped in the middle of the road. I hit the brakes and swerved right to get out of the way but still clipped her rear bumper. I hit her right rear with my left front.
My Problems Now:
-scratched bumper
-dented fender
-lip of wheel damaged, possible tire damage as well (it was leaking to I had to put on the spare
-while going straight the steering wheel sits about 10deg to the right of normal
-pulls to the left under braking
-seems to track fine while going in a straight line and doesn't pull until the brakes are applied
At first glance, with the spare on, the suspension looks Ok and the wheels don't look out of place. But my pulling issues are far from extreme so I wasn't expected to necessarily have much visible damage (at least w/o getting it in the air and removing the wheels).
I am going to get it looked at by an alignment shop once I have the time, but I'd also like to start getting some opinions from all of you. Maybe common things that fail and would cause my problems? Later tonight I'm going to put the car up on jackstands and check it out, although I doubt I'll be able to see much as I'm still relatively new to subaru suspension.
Any help or advice is greatly appreciated. Hopefully this isn't going to be a huge hassle cause I have to pay out of pocket. Thanks!
-colin
C o l i n is offline   Reply With Quote
Old 05-23-2007, 07:48 PM   #2
C o l i n
Member#: 101384
2004 TS
btw, the car is an 04 TS w/ all stock suspension and steel wheels....
Old 05-23-2007, 09:15 PM   #3
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
kay well...
you probably need
alignment
new tie rod end
other possibilities:
bent strut
bent control arm
you just wont know until you look at it/get it aligned.
good luck
Jamie
Subie Gal is offline   Reply With Quote
Old 05-24-2007, 12:53 PM   #4
romanlynch
Member#: 126684
02 wrx
PLATINUM silver baby
silly question, but is the spare tire full size rim or a doughnut?
romanlynch is offline   Reply With Quote
Old 05-24-2007, 02:23 PM   #5
GFimpreza
Member#: 40674
94 Impreza wagon
1.8L + 657cc's
He's on a doughnut, but I'm pretty sure he transferred it to the rear last night just to limit the variables.
GFimpreza is offline   Reply With Quote
Old 05-24-2007, 02:51 PM   #6
romanlynch
Member#: 126684
02 wrx
its still gonna pull a tinny bit with it on the rear. probably didnt do any damage unless it was like a 25+ mph hit
Old 05-24-2007, 04:54 PM   #7
C o l i n
Member#: 101384
2004 TS
we've got a winner!
Well, I was secretly hoping this was the issue... but didn't want to get my hopes up. It seems that the entire problem was due to the spare tire. I swapped it to the rear, checked all the tire pressures and took the car for a drive. So far as I can tell everything is OK, well at least mechanically. The steering wheel is now straight again and it does not pull at all. So very good news!
Now all I gotta do is get GFImpreza (my bro) to bring my WRX wheels out here so I can get that damn spare off the tire entirely. Then eventually fork over the $$ to get the cosmetic stuff fixed (sucks cause I just had $1600 worth of work done to the front end after someone backed into it).
Thanks for everyone's help!
After an accident Question EJ20(GDB) Vancouver Impreza Club Forum -- VIC 23 04-29-2008 12:56 AM
Rental car after an accident kinkinhood Off-Topic 11 02-05-2008 04:19 PM
this is what happens when people don't clean up debris after an accident... t4nk Texas Impreza Club Forum -- TXIC 14 05-05-2007 04:53 AM
What to do after an accident.. KRL Off-Topic 32 02-11-2007 11:13 PM
sort of OT: Question about insurance deductible after an accident Jersey-Girl Tri-State Area Forum 8 10-12-2004 05:59 PM
