Old 12-20-2001, 01:39 PM   #1
CRAZY KEN
Member#: 1176
2012 MB E550 4M
2015 P85D
Default Ground Control Adj. Spring
Do they make an application for MY99 Legacy's 2.5GT...Just a thought...Picking your own spring rates and height kinda sounds nice you know!!!
N E 1 have them on their Legacy?
CRAZY KEN
I'm thinking Ground Control and KYB ... Thanks 2.5GT!!!
CRAZY KEN is offline   Reply With Quote
Old 12-20-2001, 02:53 PM   #2
2.5GT
Member#: 2697
2000 Celica GT-S
Spectra Blue
I figured you'd eventually go for that idea I'm pretty sure MY99 2.5GT had that set up on his car. Not sure if he still does (I think he went DMS) but he might be able to give you a little more insight on them.
I'd talk to somebody at GC and see what their recommendation for spring rates would be.
Jason
2.5GT is offline   Reply With Quote
Old 12-20-2001, 05:40 PM   #3
CRAZY KEN
Member#: 1176
2012 MB E550 4M
2015 P85D
Default CALLED GC
They weren't helpful...Tehy only had applications for Impreza 2.5 RS and WRX!
I will PM MY99 2.5GT though see if he still have the GC!
Thanks,
CRAZY KEN
Old 12-20-2001, 06:07 PM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
The 2.5GT and 2.5RS have essentially identical suspension underpinnings. I'd be willing to bet that the GC coil-over kit would work just fine on your 2.5GT, the person you talked to at GC just doesn't know enough about Subarus to tell you that. Actually, you'd probably be better off ordering WRX stuff, as the rear top mounts in our cars are the same as the WRX but different than the pre-'02 2.5RS.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 12-20-2001, 06:27 PM   #5
CRAZY KEN
Member#: 1176
2012 MB E550 4M
2015 P85D
Default Let me get thi straight...
I should ask them for 2.5 RS' front adj. spring (at what spring rate and height) and a WRX rear adj. spring (at what spring rate and height)
Thanks Pat,
CRAZY KEN
TN: Ground Control Adj. Springs and rear top hats pzary3233 Suspension/Brakes/Handling 15 04-09-2008 03:29 PM
FL: NEW in box Ground Control Adj Springs kit pzary3233 Suspension/Brakes/Handling 2 10-28-2007 11:38 AM
Ground Control Legacy spring rates? seowitz Brakes, Steering & Suspension 19 10-23-2001 01:21 AM
Installing Ground Control/Eibach springs? Bahumut Technical Forum Archive 2 09-04-2000 09:16 PM
best prices for ground control adj springs?? burr101 Technical Forum Archive 3 09-04-2000 05:50 PM
