Welcome to the North American Subaru Impreza Owners Club Tuesday May 5, 2015
Old 05-25-2007, 08:23 PM   #1
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
Default Anyone running Delta Cam regrinds in the 2.0l wrx heads?
I see plenty of people running Delta Cam regrinds on NA motors but I can't find anyone running them on a WRX.
I have to pull the heads off my car to fix some issues. While I have it apart again I want to go ahead and upgrade. The stock cams are killing my top end and this seems like a cheap solution.
LiquidForce is offline   Reply With Quote
Old 05-30-2007, 05:10 PM   #2
Ensi
Member#: 90329
05 Sti
Gray
I talked to John over at Delta and he says it would make a big difference, he's supprised us turbo guys haven't caught the wave so to speak
Ensi is offline   Reply With Quote
Old 05-30-2007, 08:03 PM   #3
bboy
Member#: 56468
04 Improved STI
Dirty White
I've been to Delta Cams on a few occasions. I think they are great people. I just always been told to avoid regrinds.
Old 05-30-2007, 08:37 PM   #4
LiquidForce
Member#: 12811
2002 2.5l Wrx
I thought regrinds were more likely to have isssues if more material needs to be added. I was thinking of just getting the bottom of the cam lobe ground down some and then use a bigger shim/bucket to get more lift.
FS New '02 - '05 2.0L WRX Head Gaskets goDonut Engine/Power/Exhaust 0 08-21-2008 08:45 AM
Delta Cam Regrind on the 2.5i AWDDownShift Normally Aspirated Powertrain 12 05-07-2008 06:37 AM
Question on cams for Stock 2.0L WRX Heads naTe02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 04-19-2006 02:45 PM
New 2.5l STi shortblock with 2.0l WRX heads? neversatisfied Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 65 06-01-2005 12:33 PM
2.2+wrx heads need cams as badly as 2.5+wrx heads? Davenow Subaru Conversions 8 04-13-2005 10:52 PM
