Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Suspension/Brakes/Handling
Old 05-26-2007, 12:28 AM   #1
fastseven
Member Sales Rating: (4)
Member#: 41939
2001 RS 2.5
BRP
Impreza GC8 Need assistance with brake issue
Came home in the 01 RS and noticed a brake smell. Well, I checked the right rear brake and it was extremely hot. I just got off the highway so no stop and go traffic and the other brakes were fine. What could cause this brake to stick and what is the possible solution?
fastseven is offline   Reply With Quote
Old 05-26-2007, 10:04 AM   #2
fastseven
Member#: 41939
2001 RS 2.5
BRP
Anyone??
Old 05-26-2007, 11:18 AM   #3
Butterz
Member Sales Rating: (25)
Member#: 21205
2004 Poopwagon
2010 135i
Maybe you've got some air in the lines. When is the last time you have bled/flushed the whole brake system?
Butterz is offline   Reply With Quote
Old 05-26-2007, 11:20 AM   #4
finnRex
A. Moderator
Member Sales Rating: (6)
Member#: 21095
RIP KTH & LMFH
'09 Crystal red Tintcoat
Seized caliper, sticking slide pin are two good possibilities.
Mika
finnRex is offline   Reply With Quote
Old 05-26-2007, 12:18 PM   #5
texas05sti
Member Sales Rating: (24)
Member#: 126242
2005 STi/2012 GTR
TXIC's most loved
you may have a clogged line....replace your lines with braided lines and flush teh entire system, you should be good then.
texas05sti is offline   Reply With Quote
Old 05-27-2007, 07:11 AM   #6
jpbpro
Member Sales Rating: (3)
Member#: 36155
03 WRX
Platinum on Gold
Isn't that where the ebrake is too? Its probably the caliper, but I thought I'd throw that out there too. Could be the ebrake has been maladjusted.
jpbpro is offline   Reply With Quote
Old 05-27-2007, 08:27 AM   #7
Fathead
Member Sales Rating: (20)
Member#: 91842
2008 Titan Crew
Mika
Yeah, what he said. Have you had brake work recently?
Fathead is offline   Reply With Quote
Old 05-27-2007, 12:42 PM   #8
H.K. Phooey
NASIOC T-Shirt Crew
Member#: 35509
2010 SuperChargedJag
Pewter
Any news on what it was?
H.K. Phooey is offline   Reply With Quote
Old 05-27-2007, 01:01 PM   #9
fastseven
Member#: 41939
2001 RS 2.5
BRP
No word. I replaced the rear pads 3 weeks ago because the passenger side rear was metal on metal. The driver's side was hardly worn from when I replaced them a year and a half ago. I am thinking it is a siezed caliper. I will have to get dirty tomorrow and take the thing apart. It should be fun since I have no idea what to do. But, how hard can a rear brake be??
Old 05-27-2007, 01:11 PM   #10
finnRex
A. Moderator
Member#: 21095
RIP KTH & LMFH
No biggie. Grab a big pair of channel locks and see if you can move the piston in with it. If you can, then the caliper's good. If not, replace caliper. Also, make sure to lubricate the slide pins.
Mika
Old 05-27-2007, 02:02 PM   #11
fastseven
Member#: 41939
2001 RS 2.5
BRP
How much is a caliper??
When I changed the pads, the piston moved back when I squeezed it with the disc brake wrench I have.
Old 05-27-2007, 02:31 PM   #12
Hotrodguru
Member Sales Rating: (8)
Member#: 37210
2002 Tarmac Bugeye
2012 Hyundai Veloster
I would check the ebrake, if not mistaken it'll use a drum mechanism.
Hotrodguru is offline   Reply With Quote
Old 05-27-2007, 02:48 PM   #13
Fathead
Member#: 91842
2008 Titan Crew
Did you lube the pins/slides at that time? I've bypassed this step before and paid w/uneven pad wear. Sticking pin(s) may have caused the uneven wear before as well. BTW, was either pad (inside vs outside) worn more then the other when you changed them?
I'm not ignoring the potential of an e-brake problem. . . it's just that I've seen the sticky-pen problem more.
Old 05-27-2007, 10:19 PM   #14
fastseven
Member#: 41939
2001 RS 2.5
BRP
Yes, the outside pad was worn much worse than the inside.
Old 05-27-2007, 10:46 PM   #15
Fathead
Member#: 91842
2008 Titan Crew
OK I'm putting all my money ($.02) on the pins. Pull 'em, clean & lube 'em, make sure pads are still serviceable, and reassemble. Check caliper motion and e-brake operation just in case, but I still blame the pins.
BTW the uneven wear will just get worse and worse unchecked. This problem on another vehicle resulted in a premature pad failure, costing me 2 rotors and a caliper.
Old 05-29-2007, 07:54 AM   #16
STi_VIII
Member Sales Rating: (2)
Member#: 72957
2004 EJ257 VF37 51E
w/ TypeRA Roof Vent & Lip
Why is this in the "Vendor 'For Sale' Classifieds" forum?
STi_VIII is offline   Reply With Quote
I need assistance with a google search MikeCee Off-Topic 31 06-27-2009 08:32 PM
Need Help With Braking Issue Brisky Brakes, Steering & Suspension 23 01-03-2009 06:26 PM
I NEED assistance with my fiberglass enclosure scoobydude42 Car Audio, Video & Security 4 08-12-2005 04:12 PM
OT: Need assist. with tuning from log. Please help. schwarzenegger Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 12-14-2003 07:09 PM
Need help with Brake pad/rotor issue? Jasno999 Mid Atlantic Impreza Club -- MAIC 11 04-30-2002 09:57 PM
